What is the length described in surface tension?
The discussion centers on the confusion regarding the term used in surface tension calculations, specifically the expression 2πr. Participants clarify that the term σcosθ(2πr) relates to the force exerted along the circumference of a circular surface, where σ represents surface tension and θ is the contact angle. The original confusion stemmed from misinterpreting the area formula πr² as a length, which is incorrect. The focus is on understanding the correct application of 2πr in the context of surface tension. Clarifying these terms is essential for accurate comprehension of the physics involved.
goggles31
πr2 is not a length. That may be the source of the confusion.
Sorry I meant 2pir. Specifically the term σcosθ(2pir).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
