What is the Limit of the Sequence b_n = n - sqrt(n^2 + 2n)?
QuantumP7
Consider the sequence given by b_{n} = n - \sqrt{n^{2} + 2n}. Taking (1/n) \rightarrow 0 as given, and using both the Algebraic Limit Theorem and the result in Exercise 2.3.1 (That if (x_n) \rightarrow 0 show that (\sqrt{x_n}) \rightarrow 0), show \lim b_{n} exists and find the value of the limit.
b_{n} = n - \sqrt{n^{2} + 2n} and (1/n) \rightarrow 0
Does the (1/n) \rightarrow 0 imply that I should put bn in the form 1/n? Going in that direction, I'm stuck at \frac{-2n}{n + \sqrt{n^{2} + 2n}} Am I going in the right direction? And if so, any hints on how to further manipulate what I have? I'm self-studying, and do not have a professor or mentor or anything to give me a bit of direction.
That certainly seems a right direction. Maybe divide both numerator and denominator by ##n##, and take the ##\frac{1}{n}## into the square root.
Likes QuantumP7
YES! That is the hint I needed! Thank you SO much!
QuantumP7 said:
Consider the sequence given by b_{n} = n - \sqrt{n^{2} + 2n}. Taking (1/n) \rightarrow 0 as given, and using both the Algebraic Limit Theorem and the result in Exercise 2.3.1 (That if (x_n) \rightarrow 0 show that (\sqrt{x_n}) \nrightarrow 0), show \lim b_{n} exists and find the value of the limit.
You can write ##\sqrt{n^2+2n} = \sqrt{n^2} \, \sqrt{1 + (2/n)} = n \sqrt{1 + (2/n)}##. Since you know that ##\lim_{n \to \infty} \sqrt{1+(2/n)} = 1##, it follows that for any (small) number ##r > 0## we have ##1 \leq \sqrt{1+(2/n)} < 1 + r## for all ##n## larger than some number ##N = N_r##. Therefore, for all ##n> N## we have that the denominator of your ratio above lies between ##n + n = 2n## and ##n + n(1+r) = n(2+r)##. Therefore the ratio itself lies between ##-2/2 = -1## and ##-2/2(1+r/2) = -1/(1 + (r/2))##. Therefore, the limit, ##L## is a number that is ## \geq -1## and ##\leq -1/(1+(r/2))##, no matter how small the positive number ##r## that you choose. For example, if ##r = 0.00002## we have ##-1 \leq L <-1/1.00001##. If ##r = .00000000002## then we have ##-1 \leq L < 1/1.00000000001##, etc. Basically, ##L## must be -1; there is no other possible choice.
Likes QuantumP7
Thank you SO much! I hadn't even thought to use ##\sqrt{n^{2} + 2n} = \sqrt{n^{2}} \sqrt{1 + \frac{2}{n}}##!
Using my fraction, I somehow got that the limit of ##b_{n}## was -2. I see where my mistake was. When I used \frac{\frac{-2n}{n}}{\frac{n + \sqrt{n^{2} + 2n}}{n}} = \frac{-2}{1 + \frac{\sqrt{n^2 + 2n}}{n}} and then setting the limit as ##n \rightarrow \infty##, I made the mistake of assuming that ##lim_{n \to \infty} \frac{\sqrt{n^{2} + 2n}}{n} = 0## when that is not true.
Doing it your way, I have ##lim_{n \to \infty} b_{n}## = -1, as do you.
Thank you so much!
The things you learn when you reach out for help!
You can also do it by induction, much harder and not needed here.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
