What is the linear speed of Santa Fe around the earth's axis in mi/hr
  • Context: MHB
  • Thread starter Thread starter 699427535
    Axis Linear Speed
The linear speed of Santa Fe around the Earth's axis is calculated using its latitude of 33.88 degrees north. The Earth's radius at the equator is 3960 miles, and it completes one rotation every 24 hours. By applying trigonometric principles, specifically relating the radius of the Earth and the latitude, the linear speed can be determined. The formula involves calculating the radius of the circular path at Santa Fe and using it to find the speed in miles per hour.
  • Understanding of trigonometry, specifically sine and cosine functions.
  • Knowledge of Earth's geometry, including radius and rotation.
  • Familiarity with angular measurements in degrees.
  • Basic physics concepts related to linear speed and circular motion.
  • Research the formula for calculating linear speed based on latitude.
  • Learn about Earth's rotation and its impact on geographical locations.
  • Explore trigonometric applications in real-world scenarios.
  • Investigate how to calculate the radius of circular paths at different latitudes.
Students, educators, and anyone interested in physics or geography, particularly those studying the effects of Earth's rotation on linear speed at various latitudes.
699427535
Santa Fe is approximately 33.88 degrees north of the equator. Given that the Earth's radius at the equator is 3960 mi and the Earth spins around its axis completely in 24 hours, what is the linear speed of Santa Fe around the Earth's axis in mi/hr?
I don't know where to start! Thank you so much!
Mathematics news on Phys.org
Consider the following diagram showing a cross-section of the Earth cut with a plane containing the axis of rotation. the vertex of the right triangle containg the angle \(\theta\) is at the center of the Earth. The value \(a\) is the radius of the circular path of Sante Fe as the Earth rotates.
Can you find a way to relate the radius of the Earth \(r_E\), the latitude \(\theta=33.88^{\circ}\) and \(a\)?
Thank you so much! I figured it out as soon as I saw your diagram.
13K
13K
