What is the maximum value of b for a given function with certain properties?
  • Thread starter Thread starter lhuyvn
    Functional
The discussion centers on determining the maximum value of b for a function f that meets specific criteria, including being infinitely differentiable and having defined values and derivatives at zero. The properties include f(0)=1, f'(0)=1, and f''(0)=2, along with the condition that the absolute value of the third derivative is less than b on the interval [0,1]. Participants suggest using the Taylor series and the Mean Value Theorem to analyze the problem. Ultimately, the consensus is that the correct maximum value of b is 12. This conclusion helps clarify the relationship between the function's properties and the constraints imposed on its derivatives.
lhuyvn
Hi All,
I have a problem, and it is so confusing to me. I put it here in the hope of getting some helps to make it clear.
Thank you,
the problem is given below.
What is the greatest value of b for which any real valued function f that satisfies the following properties mus also satisfy f(1)<5
i) f is infinitively differentiable on the real numbers.
ii)f(0)=1, f'(0)=1, f"(0)=2
iii)|f'''(x)|<b for all x in [0,1]
A.1
B.2
C.6
D.12
E.24
Mathematics news on Phys.org
I would suggest looking at the Taylor series with the remainder in the form using the Mean Value Theorem, which ever one that is.
Oh, It is so wonderful suggestion !
So, it is solved. The correct answer is D (12)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
