What Is the Minimum Distance Between a Slow-Launched Satellite and Its Planet?
The problem involves two satellites launched tangentially from a distance R from a planet with negligible radius. The first satellite enters a circular orbit at speed v0, while the second is launched at half that speed, .5v0. The objective is to determine the minimum distance between the second satellite and the planet during its orbit.
  • Exploratory, Assumption checking
  • The original poster attempts to apply conservation laws and gravitational equations to find the minimum distance. They express difficulty in arriving at the correct answer despite following a structured approach.
Some participants provide encouragement and seek clarification on the calculations performed by the original poster. There is an indication that the algebra may be correct, but the original poster expresses uncertainty about their results.
The original poster mentions working through a quadratic equation and arriving at two potential distances, R/7 and R, indicating a focus on identifying the minimum distance. There is a sense of frustration regarding the solution process.
slai13
Two satellites are launched at a distance R from a planet of negligible radius. Both satellites are launched in the tangential direction. The first satellite launches correctly at a speed v0 and enters a circular orbit. The second satellite, however, is launched at a speed .5v0. what is the minimum distance between the second satellite and the planet over the course of its orbit?
R=launch radius, r=minimum radius, v=velocity at minimum radius
F=GMm/R^2
U= -GMm/R
K=.5mv^2
mvr= const. (conservation of angular momentum)
K+U=const. (conservation of energy)
GM= R(v0)^2
v0R/2 = vr, v = (v0R)/(2r)
.5m(.5v0)^2 - GM (m/R) = .5m(v^2) - GM (m/r)
Substituting in values and solving for r doesn't lead me to the answer. Any help?
Hi, slai13. Welcome to PF!
Everything looks good to me. Assuming your algebra is correct, I think you should get the right answer. Can you tell us what you got?
Sorry to have wasted your time.
I worked out the quadratic equation and got R/7 and R. R/7, I'm sure, is the minimum I'm looking for. Thanks!
No problem. Good work!
  • · Replies 39 ·
13K
