What is the name and application of this probability distribution
Lurco
Hi.
In my homework I've encountered a discrete probability distribution of this form:
f(k,\lambda)=N \frac{\lambda^k}{k!}
k is the variable, and \lambda is a parameter. I'm curious what is this distribution - what's its name and where can it be applied. I will be grateful for, for example, redirecting me to the proper wikipedia article. Thanks!
Lurco said:
Hi.
f(k;\lambda) = \frac{\lambda ^{k} e^{\lambda}}{k!}
Are you sure you copied the formula correctly? The Poisson distribution is defined by:
f(k;\lambda) = \frac{\lambda ^{k} e^{-\lambda}}{k!}
where \lambda is the rate parameter (expected number of events per unit time), and k is the number of events observed.
In evaluating Poisson noise the question becomes P(k=N_t) but your formula still doesn't look right since it lacks the exponential term.
I think the number N here is used as a normlization factor.
f(k;\lambda) = \frac{\lambda ^{k} e^{-k}}{k!}
[EDIT]: After reading the wiki page, yes the value depends on lambda not k.
Can't believe I've used this pdf so many times and forgotten it!
Thank you all for responding. Yes, the number N stand for the normalization constant, and in the wikipedia article posted by micromass the exponent is exactly the normalization:
e^{-\lambda},
so i does not vary with k.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
