What is the necessary force to support a 500 lb weight with a hydraulic lift?
  • Thread starter Thread starter Izmad
    Hydraulic
To determine the necessary force to support a 500 lb weight with a hydraulic lift, the relationship between the forces and areas of the pistons is crucial, expressed by the equation F1=(A1/A2)F2. The user initially calculated F1 as 12.8 but questioned the accuracy, considering the height of the fluid column in the larger piston. Further discussion emphasized the importance of torque in the calculation, suggesting that the torque should be evaluated around the point next to piston 2. The correct approach involves analyzing the torque created by the force exerted and the pressure force acting on the pistons. Accurate calculations must account for both the forces and the geometry of the hydraulic system.
Izmad
Piston 1 in Figure P9.24 has a diameter of 0.32 in.; Piston 2 has a diameter of 2.0 in. In the absence of friction, determine the force, , necessary to support the 500 lb weight.
http://www.webassign.net/sf/p9_24.gif
F1=(A1/A2)F2
A=pi*r^2
I solved for F1 using the above equation and got 12.8. THIS IS WRONG Is this because the column of fluid is higher in the larger piston? So i have to factor in the weight of the higher water as well? Can someone please point me in the correct direction?
thanks
you got the force that the piston at 1 exerts upwards... what force does the hand need to exert to keep the piston from moving.. use torque.
torque=rF
would the radius be from the hand to the center of piston 1?
Izmad said:
torque=rF
you want the torque about the point next to the piston 2. so torque due to the F force is F*12.0in clockwise... what is the torque due to the pressure force...
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
