What is the net torque on the system
The discussion revolves around calculating the net torque and angular momentum of a system involving a counterweight and a spool. The net torque on the system about point O is determined to be 3.16 N·m. For part B, the challenge lies in accurately factoring in the counterweight's contribution to the total angular momentum of the system, which requires treating the block and the cylinder separately. The angular momentum of the cylinder is calculated using Iω, while the block's contribution is based on its speed and perpendicular distance. Clarification on these calculations is essential for progressing to part C, which involves determining the counterweight's acceleration.
Guruu
A 4.60 kg counterweight is attached to a light cord, which is wound around a spool. The spool is a uniform solid cylinder of radius 7.00 cm and mass 1.00 kg.
(a) What is the net torque on the system about the point O?
Magnitude: 3.16 N·m
(b) When the counterweight has a speed v, the pulley has an angular speed ω = v/R. Determine the total angular momentum of the system about O.
____ v kg·m2/s
(c) Using the fact that torque = dL/dt and your result from (b), calculate the acceleration of the counterweight.
______ m/s2
L=Iw ?
I=1/2mr^2 ?
I've already done part A. My question involves part B. My best try was to calculate the angular momentum of the block and apply that to the whole system but that obviously doesn't work. My problem is with factoring in the counterweight when finding the angular momentum of hte whole system. I hate this unit, I'm pretty lost on it hah.
Also, I think I can do part C if I figure out part B, but any help would still be appreciated.
I can't show the picture but it is a solid disk with the properties listed, with a counterweight hanging down perpendicular to the radius of the disk. If you have any questions about how it looks I can answer them. Thanks in advance.
Hi Guruu! :smile:
(why did you keep using w, instead of copying the ω in the question? :wink:)
No, you must do the block and the cylinder separately.
The cylinder,as you know, is Iω, but the block is just the fundamental formula moment of inertia = speed times perpendicular distance (in other words it's the moment of the velocity). :smile:
Thanks a lot man.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
