What is the phase of the SHM at that point
  • Thread starter Thread starter Voltrical
    Phase Point Shm
The discussion revolves around a mass-spring system undergoing simple harmonic motion (SHM). For part a, the speed of the mass when the spring is compressed by 0.05 m is calculated to be 0.866 m/s. In part b, the phase of the SHM at that point is determined to be 120 degrees, which relates to the cosine function in the SHM equation. The participants clarify that the phase is derived from the relationship between amplitude and the position in the cycle. Understanding the phase angle is essential for analyzing the motion of the system.
Voltrical
A mass is attached to a spring on a frictionless horizontal surface. The mass is pulled to stretch the spring by 0.1 m, & then gently released. A short time later, as the mass passes through the equilibrium position, its speed is 1 m/s.
Part a)
What is the speed of the mass at the point where the spring is compressed by 0.05 m?
Part b)
What is the phase of the SHM at that point, relative to a phase of zero at the time of release?
Part a)
A = 0.1 m
ωA =1 m/s
ω = 1 / 0.1 = 10 rad/s
y = 0.05 m
V = ω √ (A2 - y2)
= 10 * [ √ ( 0.01 - 0.0025 ) ]
= 0.866 m/s, this answer is correct because my teacher gave us the answer.
Part b)
Answer = 120°, how to get this answer?
Hi Voltrical! :smile:
Voltrical said:
Part b)
shm is amplitude times cosωt …
so won't it have something to do with cos120° ? :wink:
