What is the physical makeup of an electron?
  • Level: Graduate
  • Thread starter Thread starter CF.Gauss
    Electron
87 replies · 31K views
ailog said:
If we ever come to understand what an electron really is
How will we know when we have reached that point?
Drakkith said:
I think people should understand that we can't even know if our knowledge about something is complete. So making statements like "when we really understand" is 100% meaningless.
I am not sure if you are quoting me but what I said was "If we ever come to understand what an electron really is". There's a big giant if in the statement. I don't believe we ever will and not just for the electron. The universe is too complex for our order of intelligence.
If we are smart enough we will admit that there will always be something to learn and we will never reach that point. But I left the possibility open with an if statement. Now if I can figure out a method to create an electron out of a vacuum at my garage workbench then I'm getting closer.
If the universe is governed by a number of laws, we can learn these laws, no matter how complex they are. Being so distant doesn't mean we will never reach.
About the OP's question, I believe he is asking about it's volume and shape, and other physical properties usually observed by eyes.
The electron is just a static wave-form that self-reflects. The energy needed for this wave to form is the rest mass of the electron.
An electron is a negatively charged sub atomic particle in an atom that is around the nucleus of the atom in the electron cloud. The electron is a very light mass subatomic particle and you can take away an electron from an atom or give electrons to an atom which will result in an ion(cation or anion).
Fastman99 said:
This question is similar to asking what is a photon? Photons and electrons and other elementary particles are not actually little billiard balls that are flying around high speeds. They are both quantum excitations of their respective fields.
The entire universe is filled with a photon field, and it's mostly empty. You can think of it as an empty EM field as well. At every point in space there is a quantum harmonic oscillator for each possible spatial frequency, and thing about quantum harmonic oscillators is that only allowed energy levels come in steps of hw. The minimum energy of the oscillator is 3/2hw in 3 dimensions, and then it goes up to 5/2hw, then 7/2 hw, etc. One step above the zero-point level is considered one photon at that spatial frequency. The photon could have a range of frequencies, and be localized in some way, or be more spread out and less localized.
Just think of it of a field as an infinite set of harmonic oscillators at every point in space, and think of the particles as quantum vibrations of this field.
In a similar way, there is an electron field that fills of space with a zero-point energy, and it has certain linearly quantized energy levels above the zero level that indicate the number of electrons. This explains why every electron has exactly the same mass, charge, spin, and g-factor. Saying an electron is the same thing as saying a quantum vibration of the electron field, but the latter is too wordy. The electron vibration can be localized, as in a vibration around an atom, or more spread out like a free particle, or an electron in a double slit experiment.
The big difference between the electron field and the photon field is that with electron vibrations, they can't stack directly on top each other. This is described as the Pauli Exclusion rule. The electron field is a fermion field, described by the Dirac equation. Two electron vibrations can be in almost the same state very close to each other, but they can never occupy the same exact state.
I like to visual all quantum particles, whether they are photons or electrons, as 3 dimensional fuzz balls, and those fuzz balls oscillate and move around and sometimes disappear according the probabilistic laws of QFT. It's the sudden collapse of the fuzz balls that's most shocking to me, (wavefunction collapse is mysterious).
Suppose we had a 50 or 100 GeV electron beam, like SLAC or the CERN LEP accelerator, and we shot it through this field of an infinite set of harmonic oscillators, or photons. What would happen?
In the normal Compton scattering, where the electron is at rest in the Lab, above a few MeV photon energy, an inelastic Compton scattering would begin to produce real electron-positron pairs, and we would see the extra positrons and electrons. The cross section for Compton (Klein-Nishina) scattering is ≈0.665 barns (6.65 x 10-25 cm2).
Now gamma shift into the reference frame where the electrons are 50 or 100 GeV, and we should see the electrons colliding with the infinite set of harmonic oscillators or photons in the vacuum (and even with the CMB). Shouldn't we see the inverse Compton effect, with high energy gammas, and possibly even positrons coming out of the vacuum chamber? Can't we use this test to put an upper limit on the density of photons or harmonic oscillators in the vacuum?
Most of these harmonic oscillators with significant energy levels are in their ground state, which means there is no photon to interact with. High-energetic charged particles in space can interact with the CMB without problems. For protons, this leads to effects like the GZK cutoff.
Energetic electrons interact with the CMB (cosmic microwave background) via the SZ (Sunyaev–Zel'dovich) effect. See http://en.wikipedia.org/wiki/Sunyaev-Zel'dovich_effect. Is your "field of photons" density less than the CMB?
A comment by P. A. M. Dirac from Proceedings of the Royal Society of London (1962) may be helpful here. Title: Particles of finite size in the gravitational field.
"So from the physical point of view, the possibility of having a point singularity in the Einstein field is ruled out. Each particle (electron) must have a finite size no smaller than the Schwarzschild radius.
I tried for some time to work with a particle with radius equal to the Schwarzschild radius, but I found great difficulties, because the field at the Schwarzschild radius is so strongly singular, and it seems that a more profitable line of investigation is to take a particle bigger than the Schwarzschild radius and to try to construct a theory for such a particle interacting with the gravitational field."
The next larger significant size (not so strongly singular) is the radius 3Gm/c squared. This size could provide gravitational confinement without gravitational collapse to infinite (or unknown) density. This size is too small to measure.
If we want to know, what exactly is an electron, we need to know how electrons (and positrons) are produced (materialized). So much has been learned about this process that it is difficult to keep up. First, we know electrons are produced from photons (produced from electromagnetic energy). We know an electron can absorb a photon. This absorption is a direct conversion of photon energy to mass. Energy added to the electron increases its mass. A photon consists of equal amounts of positive and negative electric field energy. And so, we cannot materialize an electron without also producing a positive charge particle. The electron has extremely high energy density with a radius less than 10 exp -18 meters while the photon with sufficient energy to produce an electron, positron pair has a wavelength that is large, with far less energy density than the electron. A photon, when absorbed by an existing (high density) particle will become a high energy density entity. This is the first step required to produce mass particles.
As noted, nobody knows 'exactly' what any of the fundamental particle are.
The best we can do so far is to describe characteristics according to quantum mechanics...spin, mass, charge, etc, whatever is incorporated in the Standard Model of particle physics...A complementary and different perspective might be afforded via string theory and that is a nice approach since it relates all the elementary particles to one another...as energy vibrations.
Much has been learned, and we can now discuss a limitation on the smallness of things called a "cutoff". A quote from Leonard Susskind follows:
"A cutoff sounds like a cop-out, but there is an excuse. Physicists have long speculated that the Planck length is the ultimate atom of space. Feynman diagrams, even those involving gravitons, make perfect sense as long as you cease adding structures smaller than the Planck length - or so the argument goes. This was the almost universal expectation about space-time -- that it would have an indivisable, voxelated structure at the Planck scale."
This is from the book, The Black Hole War (page 335).
If the electron radius is equal to the Planck length or 1.616x10^-35 meter, this is much larger than the electron Schwarzschild radius and so, (at first evaluation) we may find that the electron cannot collapse to its Schwarzschild radius, 2Gm/c^2 and it cannot collapse to the larger radius, 3Gm/c^2.
Another quote from Leonard Susskind follows:
"But extraordinary things are happening. In recent years, we have been accumulating evidence that the machinery in the interior of particles (electrons) is not mush bigger, nor is it much smaller than the Planck length." (page 214)
When the electron radius value is reduced to the Planck length (or slightly larger) due to gravitational time dilation (blueshift) and an equal amount of gravitational length contraction then the size (close to) 2Gm/c^2 is attainable.
With the knowledge we collectively have we can probably do a lot better than that. One of the best known fundamental prescriptions of QM, Dirac's "Principles of Quantum Mechanics" describes the motion of the charge of the electron that travels at the speed of light. Why it should do that and what it means in terms of the electron's structure and observable parameters is a not-so-well-known but arguably important Physics cottage industry and there is quite a bit of literature on the subject.
You are so correct, there is much literature on the subject of electron structure. With careful selection from available literature, we can do a lot better. Charge motion at speed of light is necessary to explain electron angular momentum (and magnetic moment). John A. Wheeler has suggested that the electron is the result of gravitational collapse. See page 1215 in the book, Gravitation. In the book, The Enigmatic Electron, author, Malcolm H. MacGregor writes, "One electromagnetic configuration --- is a current loop formed by a rotating point-like charge."
In a (2008) paper titled, The Dirac-Kerr-Newman electron, theorist Alexander Burinskii writes, "Recall that the angular momentum J = h bar/2 for parameters of electron is so high that the black hole horizons disappear and the source of the Kerr-Newman spinning particle (electron) represents a naked singular ring." We can see (in this concept) the electron size cannot be as small as its Schwarzschild radius because charge velocity greater than c would be needed to obtain angular momentum (h bar/2). The minimum radius with the charge moving at the speed of light is (3Gm/ c^2).
Malcolm MacGregor has said, "It remains to this day one of the most arcane subjects in particle physics." And later, "---the spin of the electron--is a mysterious internal angular momentum for which no concrete picture is available, and for which there is no classical analog." Can we put these pieces of the electron puzzle together to create an improved electron description? I will suggest that this can be accomplished.
To that I'll add that Martin Rivas' "Kinematical Theory of Spinning Particles: Classical and Quantum" gives quite a thorough and integrated review of very many approaches to modeling spin, especially in the electron. Unfortunately both MacGregor's and Rivas' books are out-of-print these days.
I will try to find a copy of the Martin Rivas book. I am saddened to learn that the MacGregor book out-of-print. His book is very readable. This quote (page 72) points out a significant requirement. "Thus we are forced from stability considerations alone, to introduce a non-electromagnetic force that holds the electron together. If we were to consider an extremely small size for the electron, -- then gravitational forces could be invoked to solve the stability problem."
Though MacGregor does not pursue this solution, a number of theorists, including Brian Greene, John Wheeler and Alexander Burinskii expect that electrons have some properties very much like a micro black hole.
I should probably warn that the math comprehension requirements for Rivas' book are fairly steep. He kind of starts where Ballentine's QM textbook leaves off.
Even in classical electrodynamics one can describe the electron as an orbiting massless charge embedded in its synchrotron radiation and obtains the fundamental properties, also the mass and the de Broglie wave.
The /size/ of the mass needs quantum mechanic considerations
In post # 47, a minimum electron radius value, (3Gm/c^2) was noted. From this radius, a fundamental mass value is defined, using a ring shape with the angular momentum (h/4pi). The charge spins at light velocity so that the effective mass times velocity times radius will equal angular momentum.
m c (3Gm/c^2) = h/4pi
(m)^2 = (h/4pi) (c/3G)
m = (hc/12pi G)^1/2
m = (1/2) (2/3)^1/2 (Planck mass)
I suggest this mass value is the fundamental value that has a specific relationship to the electron mass, the muon mass and the tau mass.
The photon wavelength that has energy to produce two particles with each particle mass value equal to (hc/12pi G)^1/2 is (3pi hG/c^3)^1/2 meter. This wavelength is:
wavelength = 2pi (3/2)^1/2 (Planck length)
The ratio of this fundamental wavelength to the wavelength (h/2mc) is approximately 1.025x10^-22 to one. I will suggest that this is also equal to [h/(2pi)^2] divided by (2mc^2) where the m value is the electron mass. This ratio is 1.025028393x10^-22. If these ratio values are precisely correct then the true G value must be very close to 6.671745197x10^-11. Improved experiments will determine if this is correct.
First off I'm no physicist but an EE. So my question might seem odd, but in light of everything that was said until now, why has nobody (except for one guy I believe) proposed string theory to try to explain what elementary particles are (electron included)? Is this because it is still an "unproven" (untested) theory?
String theory seems to be acknowledged by many recognized scientists, so perhaps it is a valid one at answering the initial question: what is an electron?
Btw, what a great forum this is. Just recently found it. Since then I just can't help but try to read every single posts. Waaa, I'm going crazy :)
Hi kended, String Theory and Quantum Gravity are well covered in the book by Lee Smolin, titled Three Roads To Quantum Gravity. Much work is needed if string theory is to accomplish its objective. A quote from the book follows:
"Modern physicists try -- to explain particles in terms of fields. But this does not eliminate all problems. Some of the most serious of these problems have to do with the fact that theory of fields is full of infinite quantities. They arize because the strength of the electric field around a charged particle increases as one gets closer to the particle. But a particle has no size, so one can get as close as one likes to it. The result is that the field approaches infinity as one appraches the particle. This is responsible for many of the infinite expressions that arize in the equations of modern physics."
He suggests, we may deny that space is continuous and so it is impossible to get arbitrarily close to a particle. We may also replace particles by little loops or strings. String theory is interesting but it is not yet mature enough to explain specifics such as electron mass.
Thanks for your reply DonJStevens.
I think I may have to read some more on this subject. It seems though that the book was written in 2002. So perhaps has the subject evolved a bit since then.
Now with the very recent "supposed" discovery (measurement) of the Higgs-Boson, I read that string theorists are even more excited as this would somehow fit their theory in relation to particle mass.
Anyhow I just thought that instead of saying that we "don't really know what an electron is", I would rather try to explain it using string theory that many great minds do believe in and where the mathematical constructs apparently make sense that is, until proven right.
Btw, your former job sounded very cool :)
The charge radius of an elementary particle has nothing to do with the spatial distribution of its charge. The charge radius is a length scale characterizing a scattering cross-section.
In Quantum Field Theory, elementary particles are thought as excitations of the corresponding matter field that propagate carrying energy-momentum. These excitations may be created and destroyed by the action of sources. Consequently, the energy of the field's excitation due to two sources differs from the sum of the energy of the field's excitation due to the separate presence of each source. This is interpreted as a potential energy of interaction of two sources due to the exchang of virtual particles.
The sources of some kinds of particles become quantum operators themselves corresponding to a (conserved) Noether current density corresponding to a continuous symmetry of the theory. For example, the free-electron Lagrangian has a global U(1) symmetry, corresponding to the invariance of the Lagrangian with respect to an arbitrary change in phase of the "electron field". The corresponding noether current is the electric current density, that acts as a source term for the "photon field". The photon "listens" to the electric charge in its vicinity and mediates the electromagnetic interaction. Since the range of the interaction is infinite, the photons are massless, and there is only a kinetic term for the photon field. This effectively describes Quantum Electrodynamics (QED), the simplest (Abelian) gauge theory of the Standard model.
So a photon that undergoes pair production does so because of because it is a perturbation energetic enough to inititiate the pair's own standing waves. But why at one point, not another? Why don't we just see a pair and the lower energy photon from, for instance, Co60, but instead see a high energy photon and the pair production photons later? Is that because this "Noether" field has to be in the correct configuration locally for the pair production to occur, or because the virtual particle must form, which isn't a given, but a statistical process?
I just want to point out to the OP. You're getting down to the basic building blocks of matter. When ever you describe something, call it E, you break it down or you reduce it to it's parts or its properties, X Y and Z. I think Vanhees said it perfectly:
vanhees71 said:
To conclude: To the best of our knowledge today (i.e., in this case the standard model of particle physics) the electron is an elementary spin-1/2 Dirac particle with one negative elementary charge and a mass of about [itex]511 \; \mathrm{keV}/c^2[/itex]. It's a lepton, i.e., participates only in the electroweak interaction (let alone gravitation, which acts universally on anything that has energy and momentum).
It is so difficult to describe an electron because you're running up against the basic building blocks of the universe which cannot in principle be described. Notice that Vorhees described an electrong in terms of charge, mass, spin, and the forces with which it participates. So we have some reduction. But charge, mass, spin we cannot reduce those entities to anything else, at least not now, and they remain in principle undescribable.
Despite of the great success of mathematics one should reconsider the building blocks from time to time.
Dirac invented his equation to describe the properties of spin 1/2 particles. The interaction of electrons are perfectly described by this equation.
Especially D. Hestenes investigated this equation in detail and found a description of the electron: The electron is circulating with speed of light which is described by the Zitter-Bewegung, generates an angular momentum - the spin, and with E = h x nu the Compton wavelength defines the circumference of the circulation.
But why the charge should circulate is still open.
All models in the past ignore the synchrotron radiation of the charge.
Even in classical physics a circulating charge embedded in its synchrotron radiation yields the angular momentum of the particle, the Compton wavelength as the wavelength of the radiation and the classical electron radius is the result of quantum mechanic interaction with the singularity. Circulation with v = c yields mass = field energy.
The spherical solution of the radiation just guides the charge onto a circular orbit and is thus the reason for the circulating charge.
Details are in G. Poelz "On the Wave Character of the Electron"
http://arxiv.org/abs/1206.0620
This is a very good question to pose, as quoted by many people have tried to make a modle of a electron while its basic formation is known for the most part it would be a good project to go into to try and look inside of the electron
