What is the question looking for?
  • Thread starter Thread starter I_LuV_FiZiX
The discussion revolves around determining the position vector of a mouse at point C, given its starting position and the coordinates of point C. The coordinates of point C are confirmed as (3 m, -5.4 m). The user initially struggled with the correct format for the answer, mistakenly entering values in degrees and meters. Clarification was provided that the position vector should reflect the change in position from the mouse's starting point to point C. The user ultimately understood that the correct approach involves calculating the changes in both the x and y directions from the original position.
I_LuV_FiZiX
A mouse starts at position (-2 m, 0.5 m), relative to a piece of cheese at the origin, and follows the path shown in the x-y graph below. Find the position vector of the mouse at point C and enter your answer in component form.
The co-ordianates of point C are (3 m, -5.4m)
Well I can't put a picture of the graph up on here, so if there is any information left out that the graph may contain please let me know.
There are 2 answer slots, one for each component of the answer i guess. In my first attempt I entered 8.84m in the first slot and 38degrees in the second (obtained these from constructing a triangle and using trigonometry), but i was told my units must both be meters. So I put in the co-ordinates of the point itself and that is still wrong. Any help would be greatly appreciated
The first component is the x and the second is the y. I'm assuming the path the mouse took was a straight line so basically you compare the points in terms of change in x and change in y. How much did the mouse move in the x direction to get to point C? How much did the mouse move in the y direction to get to point C?
I'm not 100% if this is correct (assumed a straight line) but this seems to be the way to approach the problem.
change in x and change in y from where? the origin? Those would just be the co-ordinates of the point C, which i already entered, wouldn't they?
No, it is the change from where the mouse orginally started (-2m, .5m).
Oh okay thanks! I got it now.
