salman213
- 301
- 1
At the load connection, the voltage above ground on the properly grounded neutral wire will be limited to the voltage drop caused by the current flow in the neutral. It will be a very low voltage compared to the 120volts at the load end of the hot wire.XPTPCREWX said:I am obviously talking to a bunch of amatures,
Neutral carries the HOT back to the DELTA/STAR configutation to complete the circuit.
NEUTRAL IS HOT.
I dare you to grab a neutral when a load is energized and touch the ground wire.
The neutral is grounded at the main panelboard. Any potential at the load in of the neutral wire will be due to voltage drop from one end of the neutral to the other, caused by the resistance of the neutral conductor. It will be in the range of 5 volts or less, depending on the length of the circuit. It will not be 120 volts...or anywhere near that high.XPTPCREWX said:With that said...
If Neutral carries the same current at the Load end of the Hot wire.
What is stopping Neutral from "equalizing" (shorting) its voltage with Ground and transferring its current into Ground?
Ground has a lower potential difference, and offers the path of least resistance.
I meant if it was just a small battery.salman213 said:why wouldn't it matter if it was a DC source. ??
Sorry I wasn't very clear - I assumed that it was referenced to ground back at the power station.and if it was an AC source you said "the case would be at 1000V above ground and your feet would be connected to 0V so you would provide a path for the current to flow through!"
isly ilwott said:You are not talking to "amatures". You simply misunderstand what the supposed amateurs are saying.
I'll get out my paint prushes and send you a picture that you may be able to understand.
isly ilwott said:The neutral is grounded at the main panelboard. Any potential at the load in of the neutral wire will be due to voltage drop from one end of the neutral to the other, caused by the resistance of the neutral conductor. It will be in the range of 5 volts or less, depending on the length of the circuit. It will not be 120 volts...or anywhere near that high.
XPTPCREWX said:Regardless of the voltage drop, however miniscule the voltage in neutral may be in reference to ground...the current in neutral is the same as the HOT leg supplied to the load.
Thus: neutral is HOT.
If no one understands this they are Amatures.
XPTPCREWX said:first off you drawings are wrong. and you are basing all your questions on a false basis.
ground will reduce shock/electrocution/arc blast/ and further damage to the equipment and operator, by creating a lower path of resistance and lower potential difference than anything or anyone around it.
what i think everyone need to focus on answering is HOW this is wired. Every drawing i have seen is a short circuit between HOT and NEUTRAL and GROUND.
Socrates via Wikiquote said:As for me, all I know is that I know nothing.
salman213 said:Is it possible for someone to explain why this individual gets electrocuted...(check image)..
I know MGB explained but I am still confused for some reason. I do not understand how this is a complete circuit. Can someone trace the current for me? :S
(Image: Yes that is a short no ground connection).
salman213 said:if the negative terminal is at a higher potential i still do not really understand how current would flow through the individual...
Is it NOT necessary that in AC Circuits the "End" which is the "EARTH" be connected to the negative terminal for the circuit to work..?
XPTPCREWX said:what part of the story do I not have straight?
salman213 said:ok..umm, thank you... I know you are trying to explain so thoroughly, but unfortunately I am still not really understanding what the answer to my question is. :(
I made a diagram, can someone complete circuit B and does current flow through the guy?First Diagram: https://www.physicsforums.com/attachment.php?attachmentid=15144&d=1219436573
mgb_phys said:That is said to be a 'floating' circuit and for a battery powered circuit it wouldn't matter.
But if it is floating then the + and - can be any voltage above 0 there is nothing to make the - terminal the same voltage as the Earth.
So suppose the + was at 1100V and the - was at 1000V, the circuit would work fine. But if you touched the case, even without any fault, the case would be at 1000V above ground and your feet would be connected to 0V so you would provide a path for the current to flow through!
The reason the Earth is used as a reference is that it is also the thing you are msot likely to be touching ! And you can be sure that the Earth in your house is at the same voltage as the Earth at the power station.
XPTPCREWX said:One thing I don't get...
If Ground is connected to the Neutral Bar at the Breaker Box, which it is.
(in residential)...what is stopping the current of that branch circuit on the neutral side from ground out instead of returning to the source?
The Ground is being "spurred" off of the neutral bar...and providing the path of least resistance...right?
