What is the separation between the two surfaces
To find the separation between two equipotential surfaces in a uniform electric field, the equation Eave = - deltaV/delta x is used. Given the electric field of 13.3 x 10^3 N/C and the potentials of 1543 V and 951 V, the calculation involves determining delta x. The attempt at a solution shows the correct approach by rearranging the equation to delta x = (1543V - 951V) / (13.3 x 10^3 N/C). The user expresses uncertainty about the correctness of their method. The discussion highlights the application of physics equations to solve for distance in electric fields.
zoomba91210
You measure a uniform electric field of 13.3 x 10^3 N/C between two equipotential surfaces. One surface is at a potential of 1543 V and the other is at 951 V. What is the separation between the two surfaces?
After rewriting the equation I did delta x = (1543V-951V)/(13.3 x 10^3) N/C
I am not sure I am doing this right
Thanks for any help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
