What is the speed of a synchronous satellite in orbit around the Earth?
The speed of a synchronous satellite in orbit around the Earth can be calculated using the formula v = √(G*M/radius), where G is the gravitational constant and M is the mass of the Earth. To determine the radius, the altitude of the satellite above the Earth's surface must be added to the Earth's radius, which is approximately 6.38 x 10^6 m. The discussion highlights the importance of using the distance from the Earth's center for accurate calculations. Additionally, the symbol "ω" (omega) represents angular frequency, which can be expressed as ω = 2π/T, where T is the orbital period. Understanding these concepts is crucial for calculating the speed of synchronous satellites.
dxlogan187
A rocket is used to place a synchronous satellite in orbit about the earth. What is the speed of the satellite in orbit?
I know that G= 6.67x10^-11 and the Mass of Earth is 5.98x10^24 kg.
So I'm to assume that I use the equation
v= Square root of([G*M]/radius)
But I don't know how high off the ground the satellite is. I know the radius of the Earth is 6.38X10^6 m, so I'd add that to how high above the Earth it is to get the radius.
Thanks for your time!
The distance from the center of the Earth is the relevant one. However, you just need to recognize that \omega r = v which you could use to eliminate r from your equation.
What does the w symbol mean? Never seen that before :confused:
It's the Greek letter "omega" and it stands for the angular frequency. You may be more familiar with it in this form:
\omega = \frac {2\pi}{T}
