What is the speed of the ball 10.0 sec later?
  • Thread starter Thread starter Peterson
    Ball Speed
The discussion revolves around calculating the speed and distance of a ball rolling down an inclined plane with a uniform acceleration of 1.00 m/s², starting from an initial speed of 0.5 m/s. After 10 seconds, the speed of the ball is calculated to be 10.5 m/s, and the distance traveled during that time is found to be 55 meters using the appropriate kinematic equations. There is confusion regarding the interpretation of "the eighth second," leading to differing calculations for the distance traveled during that specific time interval. Participants emphasize the importance of correctly applying kinematic equations and clarifying the problem's wording. The conversation highlights the need for precise understanding in physics problems to achieve accurate results.
Peterson
INTRODUCTION:
This is a problem from my Introduction to Physical Science class using "Conceptual Physics" 10th Ed.by Paul G. Hewitt
EXACT PROBLEM:
"A ball rolls down an inclined plane with a uniform acceleration of 1.00 m/sec^2. At a certain instant, its speed is 0.5 m/sec^2."
PROBLEMS FACED:
a) What is the speed of the ball 10.0 sec later?
b) How far has the ball traveled in that 10.0 sec time interval?
c) How far did the ball travel during the eighth second after it was released?
MY THOUGHTS:
I don't know what to do here really. I've had phyisics before, but that was for years ago (so much for saving that easy intro science class for senior year:rolleyes:). I am pretty much at a loss here. Any help for a lazy, "I just want to graduate" senior would be of great help.
Start by looking up the basic kinematic equations of linear motion in your book. Write out the things you know and the things you need to find. Find the equation that fits them together. Drawing a picture and labelling the points with the things you know can help.
hage567 said:
Start by looking up the basic kinematic equations of linear motion in your book. Write out the things you know and the things you need to find. Find the equation that fits them together. Drawing a picture and labeling the points with the things you know can help.
That doesn't help me at all. I take it I'm looking for something dealing with the equations for speed, average speed, acceleration. I honestly don't know.
Does your book not talk about them? I'm not trying to be difficult, but I find it hard to believe there aren't any examples of how to use these equations in your textbook.
To give you a hint for a):
A ball is traveling down an incline, with an acceleration (a) of 1 m/s^2. At some time, it has a velocity ( call it Vo) of 0.5 m/s. At t = 10s after it had the velocity of 0.5 m/s, you want to know what the new velocity (V) is. So you know Vo, a, t, and want to find V. Which one of those equations listed in the formulay do you think you could use?
ok, you answered my biggest problem. 0.5 is the starting point.
OK, so here's my crack at part a:
v = Vo + at
v = .5 + (1.0)(10)
v = .5 + 10
v = 10.5 m/s
part b:
d = vt
d = (10.5)(10)
d = 105 m
part c:
v = Vo + at
v = .5 + (1.0)(8)
v = .5 + 8
v = 8.5 m/s
d = vt
d = (8.5)(8)
d = 68 m
now was I correct in having to redo the velocity for part c?
Since the ball is rolling wouldn't we have to use kinematic equations for uniformly accelerated rotational motion rather than linear motion (since the ball isn't sliding down the plane). So in terms of x, v, and a it's just a small gripe but use theta, omega and alpha.
Another stab at part b:
x = x0 + v0t + (1/2)at^2
x = 0 + (.5 x 10) + .5(1)(10^2)
x = 5 + 50
x = 55m
Here's some pointers on your answers:
v = Vo + at
v = .5 + (1.0)(10)
v = .5 + 10
v = 10.5 m/s
Your answer looks good, but note that velocity is in m/s. Acceleration is m/s^2.
part b:
d = vt
d = (10.5)(10)
d = 105 m
You can't use d=vt, since this assumes a constant velocity (acceleration = 0). Since the ball is continuously accelerating at 1 m/s^2, you must find an equation that contains a as well.
part c:
OK, I think the question is asking how far the ball rolls during just the eighth second after being released from rest, not after 8 seconds from being released from rest. So your answer is not correct. For these calculations, now take Vo to be zero, which is the velocity at t=0 when the ball is released. I would start by finding the velocity at the beginning of the eighth second, and at the end of the eighth second.
v = Vo + at
v = .5 + (1.0)(8)
v = .5 + 8
v = 8.5 m/s
You can't take Vo=0.5 anymore. This is not the initial velocity at t=0. The initial velocity = 0, since the ball is being released from rest. Your answer is saying the velocity of the ball eight seconds after it reached the velocity of 0.5.
d = vt **see above for why you can't use this equation
d = vt
d = (8.5)(8)
d = 68 m
I fixed the units, and I solved part b again.
a friend and I were wondering the same thing about whether it was AT 8 seconds or How Far it went from 8 to 9 seconds.
Since it says during the eighth second, I would take it to be from t=7s to t=8s. If you count the interval between t=0s and t=1s as the first second. That's my opinion anyway.
Everything redone. Final Answer, Regis:wink:
part a:
v = Vo + at
v = .5 + (1.0)(10)
v = .5 + 10
v = 10.5 m/s
part b:
x = 5 + 50
x = 55m
part c:
v = Vo + at
v = 0 + (1.0)(8)
v = 0 + 8
v = 8 m/s
x = 0 + (8x1) + (1/2)(1.00m/s^2)(1s)^2
x = 8 + .5
x = 8.5m
a) and b) look good. For c): If you are going to take the eighth second to be from t=8s to t=9s, then I agree with your answer is correct based on that.
yeah, the problem is poorly worded if you ask me. I figure with the italics, it's stressing that point, so that's what I'm going with. I'll have to talk to my professor about it on Monday. Thanks for the help so far, as I have two more problems I have no idea about.
