What Is the Speed of the Elevator in a Rectilinear Pulley System?
The speed of the elevator in a rectilinear pulley system, with both motors drawing in the cord at a constant rate of 8 m/s, is determined to be 4 m/s. The equation of constraint used is 4Xe - Xb - Xc = constant, where Xe represents the distance from the roof of the shaft to the elevator, Xb is the distance to the left-most cord, and Xc is the distance to the right-most cord. After differentiating and substituting the values for Vb and Vc, the correct speed of the elevator is confirmed to be 4 m/s. The initial misunderstanding stemmed from incorrect interpretation of the pulley system.
  • Understanding of basic physics concepts related to pulley systems
  • Familiarity with equations of constraint in mechanics
  • Knowledge of differentiation in calculus
  • Ability to interpret physical systems and their components
  • Study the principles of pulley systems in classical mechanics
  • Learn about equations of constraint and their applications
  • Explore differentiation techniques in physics problems
  • Investigate common mistakes in interpreting mechanical systems
Students studying physics, particularly those focusing on mechanics and pulley systems, as well as educators looking for examples of problem-solving in this area.
crazyman27
Both motors are drawing in the cord at a constant rate of 8 m/s. Determine the speed of the elevator.
Using an equation of constraint I got 4Xe - Xb - Xc = constant (Xe being the distance from the roof of the shaft to the elevator, Xb being the distance from the roof of the shaft to an arbitrary point on the left-most cord, and Xc being the distance from the roof of the shaft to an arbitrary point on the right-most cord).
Differentiating this with respect to time gives 4Ve - Vb - Vc = 0 and subbing in 8m/s for Vb and Vc gives the speed of the elevator to be 4m/s. This isn't the solution however, not sure where I went wrong.
Any help appreciated.
How do you get this one: 4Xe - Xb - Xc = constant?
If I were you, I would express the lengths of the strings connected to B and C (there are discrete 2 strings if you look carefully) in terms of Xe and d, where d is the distance between the middle fixed pulley and the pulley which is connected to neither the shaft nor the elevator.
Thanks hikaru1211. I figured it out, I wasn't interpreting the pulley system correctly.
  • · Replies 33 ·
  • · Replies 22 ·
