What is the spring constant for an elastic cord with varying weights?
To determine the spring constant of an elastic cord with varying weights, the relationship F = -Kx is used, where F is the force applied and x is the change in length from the cord's original length. Given a weight of 57 N stretches the cord to 67 cm and 79 N stretches it to 80 cm, the change in force is 19 N and the change in length is 0.13 m. By substituting these values into the formula, the spring constant is calculated to be approximately 146.15 N/m. This method effectively utilizes the differences in force and length to derive the spring constant without needing the original length of the cord. Understanding these calculations is essential for solving similar problems in elasticity.
mortho
An elastic cord is 67 cm long when a weight of 57 N hangs from it and is 80 cm long when a weight of 79 N hangs from it. What is the "spring" constant of this elastic cord?
F=-Kx
I substituted the numbers into the formula for each set, like for the 0.67 m, i got 85.1 N/m and for the other i got, 98.8 N/m and then i averaged the two because i didn't know what else to do, so i got 92.0 N/m for the average but it's wrong. Please help me!
Thanks
Remember in that equation that x is the distance from equilibrium
You don't know how long the cord was when there was nothing on it, so you're not going to have it but you're given two cases, so eventually it'll cancel out
i have a similar problem so i didnt want to start a new thread, i hope there arent any feelings of thread jacking, but my problem is that i have the force and the k constant and an original length but i need to find the final length. would it be the force added to the k * x or multiplied like this: (mg)*k(x_2-x_1)
i sense that i am completely off...i will rethink this and come back
Yo, to calculate the spring constant you just have to use the change in mass.
76N-57N=19N
the change in distance (delta x) is 80cm-67cm=13cm
change cm into meters dividing by 100
13cm/100=0.13m
now plug n chug
19N=-K*0.13m
divide 19N by 0.13m and you have your answer...
146.15 N/m is your spring constant
