- What is the tension in each wire?
  • Thread starter Thread starter IB
    Tension Wire
The discussion focuses on calculating the tension in wires supporting a street lamp and the forces acting on a scaffold with a window washer. For the street lamp, the tension in each wire is initially calculated as 75.0 N, but it is clarified that this is incorrect due to the angle of the wires, which requires a higher tension to support the weight. A free body diagram is recommended to analyze the vertical and horizontal components of the forces. For the scaffold problem, the calculations indicate that the tension in the supporting ropes is approximately 566.67 N. The participants emphasize the importance of understanding the geometry and equilibrium conditions in these statics problems.
IB
Statics and Equilibrium
Hi. I read and re-read these problems but I don't get them. Could you please show me how to do them?
STATICS
A 700.0N window washer is standing on a uniform scaffold supported by a vertical rope at each end. The scaffold weighs 200.0N and is 3.00m long. What is the force in each rope when t he window washer stands 1.00 m from one end?
[This is a torque/rotational equilibrium problem]
A Street lamp weighs 150N. It is supported by two wires that form an angle of 120 degrees with each other. The tensions in the wires are equal.
- What is the minimum tension that each wire has to exert to support the lamp? Assume the wires exert equal forces.
I tried to do the second one. Here is my solution, but I don't know if it's right or not:
a) 120 divided by 2 we have 60 degrees. Calculate the complementary angle we have 90 - 60 = 30 degrees.
sin(30)*150 = 75.0 N
Answer: Tension in each wire is equal to 75.0 N.
b) Hmm, this one I'm not so sure, but perhaps it's also 75.0 N. It makes sense if each wire supports half of the weight of the lamp.
Thanks in advance for the help!
I'd need to see some of your work on the first one before I could help.
For the second: One thing should be clear. If the wires were hanging straight down, each would be supporting one half of the weight of the lamp. In that case, the tension in each wire would be 75N.
The wires, however, are not hanging straight down. As the angle of the wires changes, the tension will have to increase - do you see that? If so, then it's clear your answer is not correct.
Do this: start by making a free body diagram of the situation. You can treat the lamp as a point, as the symmetry of the geometry of the situation will pretty much guarantee that there are no torques to worry about here. The tensions in the wires will be in the direction of the wires, and hence will have both horizontal and vertical components. Weight acts only vertically, so how will the vertical components of the tensions have to compare to the weight? How will the horizontal components of the weight have to compare with each other? And what does that tell you about the tensions in the wires?
A little simple geometry will give you the answer.
For the second part of the question, I assume what it means is that we should assume that we can change the angle between the wires. What angle would give you the minimum tension in the wires, and what would that tension be? You should already know the answer to that one.
2(Tcos60)=150
Tcos60=75
T=150
Is that right? :)
And for part b) I think 75.0 N is the most logical, yeah? It can't be less, cos otherwise it won't be able to hold 150.0 N.
First one:
Force x distance:
Forces going in one directon = 700x1 and 200 x 1.5
Forces going in other direction = F x 33F = 700*1 + 200*1.5
3F = 1000
F = 333.3333333 etc.333.33333 + T = 700 + 200
T = 900 - 333.33333
T= 566.66666
Am I doing this right?
Problem 2, check. Good job.
Problem 1, mostly check. Keep track of your units and your significant digits. That's a quibble, though. Good job there, too. :)
Thanks so much, Diane_ :)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
