What is the total energy stored in this oscillation
The discussion revolves around calculating the total energy stored in a simple pendulum oscillation, given its length, mass, and release angle. For frequency, the formula f=1/2π√(g/L) is suggested, but the angle's impact on motion is noted. The pendulum's speed at the lowest point is confirmed to be maximum, and the conservation of energy principle is emphasized for parts b and c. Participants discuss determining the initial height of the pendulum bob using trigonometric relationships, specifically x = Lcos(angle), to find the change in height. Understanding the initial conditions and energy conservation is crucial for solving the problem accurately.
MIA6
1. The length of a simple pendulum is 0.760 m, the pendulum bob has a mass of 365 grams, and it is released at an angle of 12-degree to the verticle. (a) With what frequency does it vibrate? Assume SHM. b) What is the pendulum bob's speed when it passes through the lowest point of the swing? c) What is the total energy stored in this oscillation, assuming no losses?
For a), I used the formula f=1/2pai *(g/L)^(1/2) {I can't type the symbol 3.1415.. and radical} I wasn't sure because I didn't use the angle. For b), I used the formula v=radical F/(m/L). I don't think it is right, either, because of the angle. For c) E=1/2mv^2 + 1/2 kx^2, but how do I find x?
Thanks for help.
a) I agree
For parts b and c you really need to find the equation of motion. Since you probably are not familiar with differential equations then I will just tell you what it is.
x(t) = Acos(\omega t + \delta)
Where A and \delta are constants to be determined from your initial conditions, and omega (the w thing) is 2πf. It looks like you are supposed to assume that the pendulum is released from rest i.e. \frac{dx}{dt}(0) = 0, and that you are supposed to figure out the initial position x(0), where you would want to use that angle you are worried about.
I know that a lot people teach physics as, formula this, formula that, but try and start from the basics before resorting to formulas.
Mindscrape said:
a) I agree
I know that formula, but first I have to find the amplitude? and it kinda relates to the angle? but you said when x(0)=12 degree which will convert to radians?
For parts b and c, consider conservation of energy.
Is the speed at the bottom the greatest? But how do I know that at the bottom, it's the equilibrium point? And i don't know the amplitude, either.
You tell me. Where is PE the lowest?
Equilibrium has nothing to do with it.
What's the initial height of the bob, compared to the lowest point?
Okay. PE is definitely the lowest at bottom because h=0, so the speed is at its maximum. But I don' know the initial height of the bob.
Good.
Figure it out. You're given the string length and the angle for a reason! :wink:
Can I use the formula: x=Lcos(angle)?
That's almost what you need. That's not the height, but it will help you figure out the height. Draw yourself a diagram.
ehh,, to find the height in triangle?
Hint: The bottom position is a distance L below the pivot. How far below the pivot is the initial position? (The difference is the change in height.)
