WHAT IS THE WORK DONE THAT IS DISSIPATED AS HEAT?
The discussion revolves around a physics problem involving work done by a force on a body moving along an inclined plane. The body experiences a change in height and is subject to forces that may convert work into heat, potential energy, and kinetic energy.
  • Participants explore the relationship between work done, energy conversion, and heat dissipation. Questions arise regarding the distribution of work into potential energy and kinetic energy, particularly under the condition of constant speed.
The discussion is active, with participants questioning their understanding of energy conversion. Some guidance has been provided regarding the implications of constant speed on kinetic energy, and participants are encouraged to consider where the remaining energy goes after accounting for potential energy.
Participants are navigating the complexities of energy conservation and the specifics of the problem setup, including the forces involved and the definitions of work, heat, and energy types. There is an emphasis on understanding the implications of constant speed on kinetic energy.
jinx007
A constant force of 9 kN parallel to an inclined plane, moves a body of weight 20 kN through a distance of 40m along a plane at a constant speed. The body gains 12 m height..
HOW MUCH WORK IS DISSIPATED AS HEAT?
A/ 120 KJ
B/ 240 KJ
C/ 360 KJ
D/ 600 KJ
So workdone = f x d
but i am a bit confuse as the question say the heat dissipated
so i think that the work done = 20 kN X 12 = 240 KN (heat dissipated) answer
However the work done is 9 KN X 40 = 360 KJ
AM I ON THE RIGHT TRACK ? HELP BY THE WAY ACCORDING TO ME THE ANSWER IS B
You know the total work done by the force. Where does that energy go? Some goes to heat, but where does the rest go?
So some converts to kinetic energy and potential enegy..please just tell me whether i am on the right track and if the answer is correct... thanks in advance
Good. In this case, how much energy goes to KE? How much to PE?
No, your answer is not correct. But you'll get there.
So p.e is 20 kN x 12
What about the kinetic energy..?? no speed...what should i do...
Good!
You are told that the speed is constant. So how much of the total work goes into KE?
Doc Al said:
Good!
So i think that its the work done of moving the object to the top this is equal to the kinetic energy..! i am right..?
No. Since the speed of the object--and thus its kinetic energy--doesn't change, none of the work is transformed into kinetic energy. There is no change in kinetic energy.
Awww..but what is the answer..?..
See my hint in post #2. You know the total work done. And you know how much went to PE and KE. What's left?
