What Makes a Sliding Book Stop Both Rotating and Translating Simultaneously?
  • Thread starter Thread starter tehrv
    Freshman Physics
The discussion centers around a physics question regarding why a sliding book stops both translating and rotating simultaneously when friction is involved. It references a longstanding query from a textbook that has puzzled many, including graduate students and even a renowned physicist. Participants explore the dynamics of friction, noting that the force of friction acts against the total velocity of the book, which combines both translational and rotational components. They conclude that under typical conditions, both motion types cease at the same time, unless specific initial conditions are manipulated. The conversation highlights the complexities of friction and motion, emphasizing that static friction is not relevant until the object stops moving completely.
  • #51
MikeGomez said:
The answer is no, and the reason is that friction acts upon each atom in a manner which is proportional to its instantaneous momentum vector. In other words, it slows each atom down in the direction that the atom traces, and in proportion to its velocity along its trochoid path. If there is no change to the shapes of the trochoid paths of the atoms, then there can be no change in the ratio of rotational motion with respect to the amount of translational motion.
I like the approach "...no change in the ratio of rotational motion with respect to the amount of translational motion."
A constant ratio of trans component vector length wrt the floor to rotation component vector length wrt the center of rotation would get the end result of coincident stopping.
From what you also mentioned, it sounds like an observable indication of this would be the preservation of the cyclic aspects... as the spinning and sliding book slows down the cyclic paths are just "drawn" increasingly more slowly, but the actual goemetric form and features of the cycloids' paths ("wavelength") as viewed wrt the floor would be constant as well.
I am beginning to wonder if the role friction plays in this is to actually oppose a curving path... the right and left halves' opposed directions of spin both encounter the same direction of friction, yet there is no curving of the path. But from the cycloid perspective, there may be a balanced compensation between the two sides (cycloid path points' net speed against the floor vs frictional velocity)...
A.T. asked, "Is dynamic friction proportional to velocity?"
I think it is, inversely in this case, and I wonder if that is what answers my curving path question, since it is the part of the cycloid path that has the lessor trans component that appears on the side of the disc that is experiencing the slower relative trans speed wrt the floor... so taking the cycloid path points' speed wrt the floor on each side of the disc, maybe the net friction on each side is balanced as well...?
For CCW; left half is the cycloid's "slow cusp side" with less net motion, with less motion against the friction direction but greater friction (from reduced speed against floor); the right half is the cycloid's "fast non-cusp side" with more net motion, and opposing the friction direction, but with greater speed so less friction.
Left side - slower trans component - motion with friction direction - net friction= F(left)
Right side - higher trans component - motion opposed to friction - net friction= F(right)
It looks like the preservation of the trans/spin ratio would preserve the form of the cycloid wrt the floor, and F(left) = F(right) throughout the duration would prevent the spinning sliding book from taking a curved path...?
  • #52
I read in Hyper-physics that "Frictional resistance to the relative motion of two solid objects is usually proportional to the force which presses the surfaces together as well as the roughness of the surfaces." I'll have to edit the last paragraph of post 49 to make that correction.
What do you think about the correctness of the statement that I am making about the trochoid paths of the component parts? I am saying that for the ratio of translational with respect to rotational motion (momentum) to change, the shape of the path traced by the component parts must change.
  • #53
@ bahamagreen I sent post #52 before your post #51 was there.
I think that is correct about what you are saying regarding the balance between the change in curvature of cw vs ccw, but the last sentence confused me when you said "prevent the sliding book from taking a curved path", because we're talking about curved paths. Did you mean to say "prevent the spinning sliding book from changing the curve of its path"?
  • #54
Just an idea.
From wiki:
Static friction is friction between two or more solid objects that are not moving relative to each other. For example, static friction can prevent an object from sliding down a sloped surface. The coefficient of static friction, typically denoted as μs, is usually higher than the coefficient of kinetic friction.
If you want to take out a nail from a piece of wood you can use brute force and, using a lever, exert a big force on it.
Or you can turn the nail, cw and ccw, using a pliers, and pull out the nail smoothly.
I realize now that the OP question does not talk about how to start a movement but how to stop it. Something is missing in the wiki explanation, something like the minimum velocity to switch from kinetic to static friction.
  • #55
This is incorrect.
At the freshman physics level, kinetic friction is independent of speed, so long as the speed is not zero. The freshman physics model of friction is that it is a force proportional to weight that is directed against the velocity vector.
And that is the key problem with this problem. Given the velocity ##\vec v_p## at some point p of the book, the velocity at some other point displaced by some quantity ##\vec r## from the point p is ##\vec v_p + \vec{\omega} \times \vec r##. Finding the net force due to friction is not a simple task. It is one ugly integral. Finding the net torque is even uglier. Showing that this means angular velocity reaches zero exactly when translational velocity equals zero is hideously ugly.
  • #56
MikeGomez said:
@ bahamagreen ...Did you mean to say "prevent the spinning sliding book from changing the curve of its path"?
My original impression of the problem was that there were two problems to answer - one, why do the slide and spin of the book stop at the same time; and two, why doesn't the path of the center of mass of the book curve (curve to the left for CW and right for CCW)? I was thinking that one side half of the book would be spinning "against" the surface friction "harder" than the other side, and this would form a couple that would displace the center of rotation away from the center of mass... and cause the book's translational path to curve off to the side.
I still think this imbalance of friction direction between the left and right side is still happening, but the imbalance is the speed of the surface between the book and the floor, but the way friction varies inversely with surface speed in this case (I think?), the two principles seem to be conspiring to net out to even... so the ratio of spin to trans is staying undisturbed and constant... so the cycloid forms are "drawn" on the floor as identical repeating patterns of the same size and shape... just slowing down, everything in proportion, until the book stops.
Now I'm thinking of how to take a disc and mount some felt tip markers through it and see what kind of patterns it would draw on a surface if I gave it a sliding spin... or better, a time lapse photo of LEDS mounted on top, or something... there must be an elegant way to verify if the cycloids maintain there self same repeating pattern, size, shape, and "wavelength" etc. as the thing slows down.
  • #57
D H said:
This is incorrect.
Thank you. I went to edit and correct that last paragraph of post #49, and the edit button seems to have disappeared. Weird.
That’s too bad. It would have been nice to mathematically either verify or falsify the premise that translational and angular motion stop at the same time. My feeling is still that they do, for the exact reason that fundamentally they are the same thing, and that it is total momentum that is being affected by friction, regardless of what combination of linear momentum or angular momentum.
My current thinking is that concentrating on the time factor will help a lot. How long does it take to slow down to zero velocity given x total initial linear momentum, and how long to slow down to zero velocity given x amount of total angular momentum. If the calculated times are the same, that would be very promising, and the next step would be to show that a combination of both will take the same amount of time to slow down to zero velocity.
  • #58
I’m afraid there is little hope for this. A.T. and DH (not to mention dozens of online sites) point out that friction does not depend on velocity. Friction is complex thing, and technically velocity can be a factor, but I think you will find that the magnitude of this effect is sure to be insignificant.
If you are seriously thinking about doing that, that would be fantastic!
  • #59
Im afraid that we have been talking past each other because of sloppy language, regarding two meanings of the word stop. Let me coin some definitions to distinguish the two.
Full Stop: Consider a single point. If the coordinate X is fixed and all orders time derivatives of X are zero (velocity=0, acceleration=0, ...), than that point is in Full Stop. If the book is rigid, then it is easy to see that if any point is in Full Stop, then all points must be in Full Stop.
Momentary Stop: A pendulum stops twice in each cycle, although swinging continues. A Momentary Stop at a point happens when the first time derivative of the total velocity is zero, although acceleration and higher derivatives are non-zero. Momentary Stops of some points on the book must necessarily occur during the time evolution before the moment of Full Stop. Specifically, there should be a cycloid locus of points in Momentary Stop when the translational velocity is sufficiently slow.
In post #32 in this thread I argued for the significance of Momentary Stop. I assume that static friction is significantly different than dynamic friction. Static friction applies anyplace on the cycloid locus of Momentary Stop. Therefore, we can not dismiss static friction.
Let us also say that there is a small velocity ε below which friction transitions from dynamic to static. For any non-zero ε, the cycloid locus of Momentary Stop, become a region of finite area. In the final moment before Full Stop, that area must necessarily increase to 100% of the book's area. This I feel, is a spoiler to the problem. The final moment before Full Stop, is dominated by nonlinearities related to the dynamic-static friction transition. That spoils any linear analysis of moments prior to the final moment.
  • #60
Execellent. Just to give a further visual picture, if we imagine that example about the point on that wheel in contact with the ground having momentary zero velocity, that would be the momentary stop at apex of the cycloid, As we watch a racing car whizzing by us at 200 mph, we see that the point tracing its cycloid path isn't on the verge of coming to a full stop.
It’s true about the effects of static friction vs dynamic friction directly before the book stops, but I don’t think that is a spoiler for the problem. That time period ε that you mention directly before the object stops is extremely small and can be neglected for the most part. When we toss the book on the table it slides for a couple of seconds and then when it stops, it stops abruptly with a jerk. That is only a fraction of a second.
  • #61
The time is indeed very short, but the velocities are correspondingly small at the beginning of this period. Say that we were on track for translational and rotational velocities to reach full stop simultaneously, and also that that the final moment is only one millisecond long. It would take only a tiny perturbation to spoil the simultaneous arrival of both velocities at zero. My argument is that the nature of the nonlinearities, not the laws of motion will break the tie in the last moment. Which way will it break? It depends on the nonlinearities.
I feel bad raising a spoiler because I think that this was an exceptionally fun physics problem. Thanks to the OP.
  • #62
If somebody wants to try this, I suggest you first try it for a thin circular ring, and then for a circular disk. That will make the integrals easier.
If the assertion about simultaneous stopping isn't true in those cases, it probably isn't true for an book whose shape is an arbitrary rectangle either.
  • #63
D H said:
This is incorrect.
How about looking at upper and lower bounds of some kind?
If you draw pictures of the velocity vectors, it is pretty easy to see that if it is spinning quickly most frictional work goes into slowing the spin, while if it is translating quickly most frictional work goes into slowing the translation.
  • #64
AlephZero said:
If somebody wants to try this, I suggest you first try it for a thin circular ring... That will make the integrals easier.
Yeah , right :)
Assuming dry friction, the force at a point is ## d\vec{F} = -\rho \vec{D}P dS##, where ## \vec{D} = \frac{\vec{V}}{\left|V\right|}## is the instantaneous direction of motion at a point.
Linear and angular accelerations are:
## M \dot{v} = \int d\vec{F} = \int \vec{D} \rho P dS ##,
## I \dot{\omega}= \int (\vec{r} \times d\vec{F}) = \int (\vec{r} \times \vec{D}) \rho P dS##
The instantaneous velocity field is
## \vec{V}(r) = \vec{v} + (\vec{\omega} \times \vec{r})## where ## v, \omega## are translation and rotation velocities.
In coordinates, assuming ## \vec{v} = \begin{bmatrix}v \\ 0\end{bmatrix}## and ## \vec{r} = \begin{bmatrix}r \cos \alpha \\ r \sin \alpha\end{bmatrix}##:
## \vec{D} = \frac{1}{\sqrt{v^2 + (\omega r)^2 - 2 v \omega r \sin \alpha}}\begin{bmatrix} v - \omega r \sin \alpha \\ \omega r \cos \alpha \end{bmatrix} = \frac{1}{\sqrt{k^2 + r^2 - 2 k r \sin \alpha}}\begin{bmatrix} k - r \sin \alpha \\ r \cos \alpha \end{bmatrix} ##
where ## k = \frac{v}{\omega} ##
We are interested in the behaviour of ##k## when ##v, \omega→0##. Let's look at the sign of ## \dot{k}##.
##\dot{k} = \left(\frac{v}{\omega}\right)'_t = (\frac{\dot{v}}{\dot{\omega}} - k) \frac{\dot{\omega}}{\omega}##
For a ring of radius ## r=1##:
##\frac{\dot{v}}{\dot{\omega}} = f(k) = \frac{\int\limits_0^{2 \pi}{\frac{ k - \sin \alpha} { \sqrt {k^2 + 1 - 2 k \sin \alpha}}}d\alpha }{\int\limits_0^{2 \pi}{\frac{ 1 - k \sin \alpha} { \sqrt {k^2 + 1 - 2 k \sin \alpha}}}d\alpha}##
The plot of ## f(k)-k ## looks like an S-curve with roots at ## k= 0##, ## k=1## and ##k=∞##, with ##f(k)>k## when ##k<1## and ##f(k)<k## when ##K>1##. Which would indicate ##k=1## is a point of stable equilibrium. This corresponds to a case where the ring 'rolls' with the point (0,r) being the instantaneous center of rotation. Which makes sense as even a small change of v/w ratio reverses the direction of friction force at that point.
For non-rotationally symmetric shapes things quickly become ugly. For a start, the whole thing is not even guaranteed to go in a straight line. And the forces depend on orientation so there is no steady state to speak of.
  • #65
I've run into the same wall of ugliness you have run into, Delta Kilo, with pretty much the same ugly elliptical integrals.
One difference between your analysis and mine: I looked at your ##\dot k## from the perspective of ##\dot k = k\left( \frac {\dot v} v - \frac {\dot \omega}\omega \right)##.
  • #66
I think the idea of starting with a ring was pretty good, but what about making it even simpler like just two points on opposite sides of the ring?
Can anyone give the physics of two point masses separated by massless rod?
I've looked around a bit and haven't found the right thing, just blocks on inclines, pulley problems, gravitation problems, billiard balls colliding, etc. It seems like it would be a trivial physics problem to able to set a system of two identical point masses (separated by a massless rod) in motion, and then apply the external force of friction in opposition to their direction of motion.
  • #67
I'm not sure if this idea helps. The net force/torque will depend on the orientation of the two points w.r.t the linear velocity. It seems more complicated than the ring where force/torque depend only on v & omega.
  • #68
With only two point masses, you lose the rotational symmetry of the system, so the behaviour would be different.
That is clear if you consider the friction forces when the rod is perpendicular to the direction of motion: if ##\omega r /2 < v##, there is no torque component of the friction because both masses are moving in the same direction as the ##v## vector.
On the other hand, n > 2 point masses should be a rotationally symmetrical system. This is the same as evaluating the integrals using the trapezium rule with n integration points.
But I don't expect it would give any more insight than Delta Kilo's result, which seems to confirm my hand-waving conjecture in an earlier post.
You might like to try it for n = 4, which is probably easier math than n = 3.
  • #69
Okay. Let me try this one out. If you don't mind, I will deal with this situation:
* The book I will use will be in the shape of a circular disk of radius "r" meters .
* It's translational speed will be "t" meters per second.
* It's rotational speed will be "s" cycles per second in the clockwise (CW) direction. CCW would be specified as s<0.
* The actual value for the frictional force is not important - except that it must be a positive value. We will call this "f" and we don't need to further define it.
* I'm going to set up a Cartesian coordinate system centered on the center of the book. Positive x will be in the direction of the the translational motion and positive y will be at a right angle to the left of that motion.
If the translational speed (t) is ignored, the speed along the perimeter of the book would be 2πrs.
But with both translational and rotational speeds, there will be a point (perhaps within the boundary of the book and perhaps not) where the t and s balance out to zero.
This "quiet" point will lie at a distance "q" from the center of the book such that 2πqs=t, thus q=t/(2πs).
This q-point will be directly to the receding side of the center of the book. For example, if the book is traveling from North to South and turning clockwise, then the q-point will be just to the West of the book's center. In our coordinate system, the q-point will be at (0,-q).
One way of describing the instantaneous motion of the book relative to the table top is that it is not translating at all, simply spinning at rate "s" around point "q".
I described my x,y axis above. Except at the q-point, the magnitude of the frictional force at any point on the book will be "f". Although the coordinates relative to the center of the book are (x,y), the coordinate relative to the q-point would be (x,y+q). So the direction of the force at any point (x,y) will be counter to the spin and therefor (-y-q,x). If someone wants an exact formula for the frictional force at any point on the book, it is f·(-y-q,x)/√(x²+y²+q²-2qy). But that not required to demonstrate the point.
The key is the relationship between the absolute value of "q" and "r". In fact, the ratio |q|/r is all that is needed to determine what portion of the total friction is being used to retard the translational speed and what portion is being used to retard the rotational speed.
If |q|>r, then the quiet point falls outside the boundary of the book and every point on the book is contributing to retarding the translation speed and the affect on the rotational speed will be slight. As this quiet point falls within the boundary of the book from |q|=r to q=0, there are more and more points that are actually attempting to accelerate "t" while at the same time there becomes a disk or radius r-|q| that applies a full retarding force to the spin. Once q=0, there is no longer any affect on the translational velocity and a maximum effect of the rotational speed.
So there are two specific functions: one for the translational retarding force Ft(q/r) with an absolute value that monotonically increases from 0 to 1 as q/r increases from 0 to infinity; and one for the rotational retarding force St(q/r) with an absolute value that monotonically decreases from 1 to 0 as q/r increases from 0 to infinity.
So there must be a point "b" where these functions cross. If the q-point falls outside the b-point, the translational velocity will be reduced in greater proportion that the rotational - moving the q point towards that b-point. If the q-point falls inside the b-point, the rotational velocity will be reduced in greater proportion that the translational - again moving the q point towards that b-point. No matter what the starting conditions are, as long as there is some spin and some translation, the ratio of spin to translation will continuously move closer to some certain value until that ratio becomes 0/0 and both stop.
  • #70
.Scott said:
Okay. Let me try this one out...
I think we already got to that point, about 50 posts ago.
Arm-waving math + Arm-waving physics still equals Arm-waving solution, IMO.
The thing you haven't proved (and to be fair, neither did I, nor Delta Kilo) is
  • #71
The key is that there is a specific spin to speed ratio that is approached asymptotically from either direction. To demonstrate that, all you need to demonstrate is that both the spin and speed friction is a function of the same spin to speed ratio, that each goes from near zero to a much larger value, and that they are both monotonic but one is increasing while the other is decreasing.
Given those constrains, they have to cross at a certain spin to speed ratio - and that that ratio, whatever it is, will be approached asymptotically as the book slows.
When I start that post, I was thinking I would attack the actual integration problem. But I don't have the time. But if you simply draw out the graphics as if you were about to attack that integration, all of the points I listed in the first paragraph become very evidently true.
Anyone who calculates "b" or rather b/r completes the proof.
  • #72
I seem to recall that kinetic friction decreases slightly as speed increases at higher speeds, and also the transition from kinetic to static friction at very slow velocity when an object stops sliding is not instantaneous, but a reasonably smooth transition where friction increases during the transition resulting in some jerk (change in rate of acceleration) just before an object stops sliding. I'm wondering how this affects any small portion of the book that has near zero velocity as the book translates and spins. However perhaps the original question is assuming an idealized case where velocity doesn't affect kinetic friction and that the transition from kinetic to static friction when an object stops sliding is instantaneous.
As a real world example, since it's part of the winter olympics, in curling, the stones can be made to curve with a very small amount of induced rotation compared to the induced linear velocity. A clockwise rotation results in a left to right curve.
  • #73
I did the integrations the dumb way (by having the computer march through an array of 201x201 points superimposed on the disk, so about 40000*pi/4 were evaluated.
The amount of energy in a disk that is spinning with an edge speed "s" has half the energy of a disk that is moving at speed "s", but since they both have the same frictional area they will both have the same total force applied to them.
So I was looking for a situation where the total force retarding the translation was double that retarding spin.
The results were interesting. Drum roll...
When those speeds are equal, the translation friction is at about 84.9% and the spin friction is at about 42.5%.
So that is the condition that the "book" will tend towards. In the case of the circular book, it's when the point on the book that is not actually moving is at the very edge.
I'll post the code in a moment.
  • #74
Code:
  int     nX, nY, nDiv, nYRange;
  __int64 nYRange2, nDiv2, nArea;
  double  fR, fX, fY, fX2, fQ, fB, fBR;
  double  fForceX, fForceY, fForceD, fRDiv;
  double  fForceXSum, fForceYSum, fTurnForce, fTurnForceSum;
  double  fSpinFrictionMax, fArea;
  fR    = 1.0;   // Radius
  for(fQ=0;fQ<=2.5;fQ+=0.05) {
    fB    = fQ;    // Estimated balance point.
    fBR   = fB*fR;
    nDiv  = 100;
    fRDiv = fR/nDiv;
    nDiv2 = (__int64)nDiv*nDiv;
    nArea = 0;
    fSpinFrictionMax = 0.0;
    fForceXSum  = 0.0;
    fForceYSum  = 0.0;
    fTurnForceSum = 0.0;
    for(nX=-nDiv;nX<=nDiv;nX++) {
      // Compute the range of Y values that are within the disk given nX.
      nYRange2 = nDiv2-((__int64)nX*nX);
      nYRange = (int)sqrt((long double)nYRange2);
      fX  = nX*fRDiv;
      fX2 = fX*fX;
      for(nY=-nYRange;nY<=nYRange;nY++) {
        fY = nY*fRDiv;
        nArea++;
        fSpinFrictionMax += sqrt(fX2+fY*fY);
        fForceX = -fY-fBR;
        fForceY = fX;
        fForceD = sqrt(fForceX*fForceX+fForceY*fForceY);
        // Check for zero-friction point.
        if(fForceD<0.001) continue;
        fForceX /= fForceD;
        fForceY /= fForceD;
        fTurnForce = fY*fForceX-fX*fForceY;
        // Accumulate frictional forces.
        fForceXSum += fForceX;
        fForceYSum += fForceY;
        fTurnForceSum += fTurnForce;
    // Compute all the proportional forces.
    fArea    = (double)nArea;
    fForceX  = fForceXSum/fArea;
    fForceY  = fForceYSum/fArea;
    fTurnForce = fTurnForceSum/fSpinFrictionMax;
    // Output fQ, fForceX, and fTurnForce here ...
  • #75
With this method I won't be concerned with finding net torque. I will simply run the physics for a couple of points (or 3 or 4 points) and check the motion at small increments of time.
Checking translational motion is trivial, because at each slice of time we just compare the current position of the center point with its previous position.
Checking the rotational motion is just as trivial because we just take the arctangent of the angle from the center point to any point, and compare with the previous angle. Technically we don't even need to find the angle, because if there is no rotation there will be no relative change in position between the center point and any of the other points.
  • #76
Great forum and question! Since this is my first post here, I'd like to confess that I failed the only physics courses I took in college, so feel free to discount my opinions if you'd like.
I don't think the problem is correct. If what the question stipulates is true, then I think it implies the following must be true as well. For these cases I think it's easier to imagine an ice rink than a table, but still assume "perfect" friction surfaces.
CASE A - Take the book and push it forward slightly with no rotation (let's say X velocity) so that it translates forward and stops after one second.
CASE B - Spin the book extremely rapidly (let's say Y RPM) in place so that it takes 100 seconds to stop.
CASE C - Set the book so it goes both forward with X linear velocity and rotates at Y RPM.
The problem as written implies that the book will travel further in CASE C than it would in CASE A. It will necessarily take longer than 1 second to stop translating, if it must stop translating at the same time it stops rotating. It does this even though no additional linear momentum was added.
I don't think that's correct.
  • #77
It is correct.
To make the RPM and the velocity more comparable, let's say that in case B, points near the outside edges of the book are traveling at velocity E = 100X. In this case, the effective translational friction at the outset of case C will be approximate 1% of what it is at the outset of case A. Even after 25 seconds, it will still be only about 2%. At 50 seconds it will still be spinning, but it will be approaching the V = 2E ratio and will almost ready to stop.
Actually, I can compute the initial conditions based on the information you provided.
The value "E", velocity of points near the edge of the book for case B, must be 50·V, because if they matched (if E==V), then it would only take twice as long for the rotation to stop (ie, 2 seconds).
So for case C:
At the start, E=50V and the translational friction is about 2% of what it was at the start of case A and the rotational friction will be about 100% of what it was.
  • #78
If anyone finds it useful, this table shows the frictional force at various spin(edge) velocity/book velocity ratios.
The frictional forces are expressed at the percentage of the best possible friction. So for travel friction, it is compared to what it would have been without any spin. And for spin friction, it is compared to what it would have been without any travel.
Of course, it's based on the C++ code supplied a few posts ago.
Code:
travel/     friction
  spin   --(% of best)--
 ratio   travel    spin
  0.00     0.00   100.00
  0.05     5.00    99.81
  0.10     9.99    99.25
  0.15    14.96    98.32
  0.20    19.90    97.02
  0.25    24.80    95.37
  0.30    29.66    93.37
  0.35    34.46    91.03
  0.40    39.18    88.37
  0.45    43.83    85.41
  0.50    48.39    82.16
  0.55    52.84    78.66
  0.60    57.17    74.92
  0.65    61.36    70.99
  0.70    65.40    66.90
  0.75    69.27    62.69
  0.80    72.95    58.42
  0.85    76.40    54.15
  0.90    79.59    49.97
  0.95    82.46    45.99
  1.00    84.88    42.45
  1.05    86.69    39.67
  1.10    88.13    37.36
  1.15    89.31    35.36
  1.20    90.31    33.59
  1.25    91.17    32.02
  1.30    91.91    30.60
  1.35    92.56    29.32
  1.40    93.13    28.15
  1.45    93.63    27.07
  1.50    94.08    26.08
  1.55    94.48    25.16
  1.60    94.84    24.31
  1.65    95.17    23.52
  1.70    95.46    22.77
  1.75    95.73    22.08
  1.80    95.97    21.43
  1.85    96.20    20.82
  1.90    96.40    20.24
  1.95    96.59    19.69
  2.00    96.77    19.18
  2.05    96.93    18.69
  2.10    97.08    18.22
  2.15    97.22    17.78
  2.20    97.35    17.36
  2.25    97.47    16.96
  2.30    97.58    16.58
  2.35    97.68    16.21
  2.40    97.78    15.87
  2.45    97.87    15.53
  2.50    97.96    15.21
  • #79
The initial amount of linear momentum in CASE A & CASE C is the same, but the rate of it's transfer to the table is different. Let's assume sliding friction doesn't depend on speed, so that only it's direction changes according to the relative velocity vector.
- In CASE A the friction forces of all book parts are opposed to the linear momentum vector, so the net linear force opposing linear motion is maximal.
- In CASE C the friction forces are almost tangential at each point, so the net linear force opposing linear motion is almost zero.
I'm not saying that in reality this works out exactly as claimed even in such extreme cases, but your argument against it is flawed, because it assumes the same net linear forces in CASE A & CASE C.
  • #80
... stop translating at the same time it stops rotating ...
I recorded some of the winter olympic curling. In the cases of collision betwen stones, a stone sometimes ends up with a moderate amount of spin after the collision, and the stones forward motion stops before the spin stops. After the forward motion stops but while the stone is still spinning, there's a slight sideways drift, but the forward motion is stopped and if anything, the drift has a slightly curved backwards component.
  • #81
Thanks Scott and A.T. Those explanations make sense.
  • #82
Friction on Ice is quite complex, and cannot be modeled with a constant coefficient. The pressure and friction melt the ice, so it becomes more slippery because of the water film. When something spins almost in place on ice, it might create a small pond where it wants to stay spinning.
I think for the purpose of the original question we should stick to dry sliding friction.
  • #83
Changes in spin/translation due to collisions don’t apply here because the external force is acting at a localized location on the stone, not the entire contact surface.
In general I don't think comparison with the dynamics of a curling stone is a good comparison with the book. The ice has an extremely low coefficient of friction, the stone is much heavier, the stone is thrown with much greater forward momentum, the surface contact area is a very thin ring, and the curlers make the friction in the path unbalanced from one side to the other.
If the stone had a flat contact surface and the ice was perfectly flat and smooth with nobody messing with it, then that might be an interesting experiment, but still overkill. Sorry to be grumpy, but to me it’s almost like having a discussion about the velocity of a bullet and going off on a tangent about the relativistic effects or something else that is not pertinent.
You toss the book on the table and the rotation and translation stop at the same time.
If there is any minute difference it is well below our ability to perceive it as humans.
Try this. Toss the book so that it translates for one second. Then toss it so that is spins for 5 seconds. Now do both at the same time: toss it so it will stop translating in one second, while at the same time giving it enough spin so that it will stop spinning in 5 seconds. You can’t do it, and the question is why.
  • #84
tehrv said:
It is supposed to be a 'qualitative' problem, so I don't think they wanted you to write much. Something like gralla's argument may be on the right track.
Yes. There has to be an acceptable qualitative explanation that, even if you cannot write out all the math, proves the behavior from first principles.
D H said:
It might help to look at this problem from the perspective of the instantaneous center of rotation. I've just started playing with this mess, so I don't yet know if it's a viable approach; hence the "it might help".
If there exists finite positive bounds dmin and dmax on the distance d between the center of mass and the instantaneous center of rotation is bounded (dmin<d<dmax) while the object is moving, then the object will stop rotating and translating simultaneously. It's a bit trickier if d→0 as v→0 or if d→∞ as ω→0.
This is close to the correct approach. It can be refined by noting the following two principles:
  • for the frictional force to STOP rotation, it must be 100% symmetrical around the center of mass
  • for the frictional force to STOP translation, it must be 100% against the direction of motion of the center of mass (the net force of friction must "point at" the center of mass)
I shouldn't have to prove the above points, but I can if someone would care to question them.
The proof of why both translation and rotation have to stop at the same time is that neither of these conditions can be met while the book is both rotating and translating. If the book is translating, any torque will be around a node that is some distance from the center of mass (the distance as described by D H, above). Similarly, if the book is rotating, the net force on the book due to friction cannot be pointed straight at the center of mass.
So here are the three cases:
  1. If rotating only, the node sits at the center of mass and stays there.
  2. If translating only, there is no node, because there is no rotation by which to determine where the node is.
  3. If both rotating and translating, the node gradually moves from some point away from the center of mass (even beyond the extent of the book, if it's a fast translation/slow rotation), inexorably toward the center of mass. The book MUST stop when the node reaches the center of mass, due to both rotation and translation needing to approach that point continuously.
The most difficult part of my argument to justify for others is the requirement that both rotation and translation must stop at the same time, since simply asserting it merely begs the question.
The reason is the two principles I started with: the conditions for stopping rotation and translation are mutually exclusive. They are only met at that infinitesimal point of time when both rotation and translation are stopped, or in the case that there is only rotation or the case that there is only translation.
  • #85
I still think the most relevant factor in all of this is that only one point on the book is ever stationary at anyone time. This refers to the spinning and translating condition. There is exponential (instantaneous) rate of decay (with distance) so no single point (except the Zero velocity point - which is constantly shifting about, of course) will lose its energy before any other. So you cannot choose more than the 'zero velocity' point that will also have zero velocity.
I don't think this argument is circular (not a pun) but I don't see how more than one point could actually be stationary. Considering the trajectories of all the points on the surface, they will take some of them to the zero velocity condition (only the ones for which ωr = |v|). None of the other points can be stationary.
Does anyone see what I am getting at?
  • #86
Well, I think I actually did prove it, at least for a uniform ring.
If we introduce ## p = \log(\frac{v}{\omega})##, ## q= v \omega##, then it can be shown that
## p' = -\sqrt{\frac{2}{q}} \sinh p \int\limits_0^{2\pi} \frac{\sin \alpha}{\sqrt{\cosh p - \sin \alpha}} d\alpha##
It is easy to show that the integral is always > 0, and so the sign of ##p'## is always the opposite of ##p##. This means, starting from a finite value of p, ## |p|## always decreases with time. Which in turn means, when ## q → 0## (that is when either ##v## or ##\omega## or both → 0), ## p ## and therefore the ratio ## \frac{v}{\omega}## remains finite, so both stop at the same time.
  • #87
tehrv said:
How about this?
So, we can rewrite the deceleration of each point as a sum of a translational and a rotational part.
Moreover, and this is the key part, we see that the ratio of the magnitudes of the deceleration of the translational part and the deceleration of the rotational part is PROPORTIONAL to the ratio of the magnitudes of their respective velocities. Call this the PROPORTIONALITY CONSTRAINT:
Deceleration of the translational component/Deceleration of the rotational component
=Speed of the translational component/Speed of the rotational component.
This is not true.
In the simple case that I examined, where the book is in the shape of a circular disk, the translational and rotational parts did not remain constant.
Instead they approached a specific ratio. In terms of energy, the translate to rotate ratio was 2 to 1. In terms of speed, where the rotational speed is defined as the relative speed of a point on the circumference to the point in the middle, that ratio was 1 to 1.
If the ratio starts higher than this, the translational friction is more than twice the rotational friction, so the translational energy is reduced disproportionately faster.
If the ratio starts lower than this, the rotational friction is more than half the translational friction, so the rotational energy is reduced disproportionately faster.
---- edit to add ---
I just realized the post I am responding to is not recent.
Still, it shows that the first attempt by the OP was almost valid. The only problem being that the situation is better than he supposed.
  • #88
It would be interesting to see the proofs. Both the assertions see to be wrong. The first one seems obviously wrong, if you spin a wheel and stop it with a friction force applied at one point on the rim.
  • #89
A clarification of my initial points:
  • for the frictional force to STOP rotation without also stopping translation, it must be 100% symmetrical around the center of mass
  • for the frictional force to STOP translation without also stopping rotation, it must be 100% against the direction of motion of the center of mass (the net force of friction must "point at" the center of mass)
My apologies for not being more clear in my initial post. I'm not trying to "always be right" by modifying my explanation, but communicating qualitative ideas is an imprecise art. I appreciate your feedback in that it helps clarify things all around. :smile: If it were an easy problem, this thread would be very short.
In your counter-example, there is also a fixed axle exerting a force that exactly counters any translational force on the wheel. I'm regarding the book as uncoupled to anything other than the frictional force on the surface. If the book were nailed down with some sort of axle on the surface, the OP problem could not be posed. In the problem as posed, to stop rotation without stopping translation requires a rotationally symmetric application of forces.
Given a rotating/translating book, the rotation is not around the center of mass (it is, in the book's frame of motion, but not ours), but around a moving point some distance from the path followed by the center of mass, direction and distance depending on the the ratio between the angular spin and the translational velocity.
If there were no translation, that center of rotation would be at the same point as the center of mass. If there were no rotation, that point would be infinitely far from the center of mass.
It is the fact that the point is a finite distance from the center of mass that forces both rotation and translation to stop simultaneously. The simplest intuitive case to consider is when that point is underneath the book, but not coincidental with the center of mass. In this case, there is an asymmetric set of forces on the book, exerting a torque around that point of rotation (not the center of mass), and also decelerating the translation (because the forces aren't symmetrical around the center of mass).
Only that single point of rotation, underneath the book, feels no net force. In order for the book to stop rotating, but keep translating, that center of rotation must instantaneously move from underneath the book to infinitely far from the book. In order for the book to stop translating, but keep rotating, the net force must instantaneously move from where it is (exerting a force offset from the center of mass, slowing both rotation and translation) to the center of mass.
If (contrary to my intuitive interpretation in my earlier post) the point of rotation never reaches the center of mass, then both rotation and translation must cease simultaneously. If it continuously approaches the center of mass (or a point infinitely far), then the condition that rotation and translation must stop simultaneously applies for the duration until reaching either limit, which, by arguments of continuity, implies that rotation and translation must stop simultaneously AT either limit. I'm beginning to suspect that the center of rotation doesn't move unless the frictional force from the surface is uneven (due to normal irregularities in the surface). I'd have to sit down and do the math to figure out if it does, but I'm refraining from doing so because I prefer to hone the qualitative explanation, for now. (And because I'm lazy. :-p)
tl; dr version:
If the book is both rotating and translating, there is no way for it to stop just one or the other without some kind of discontinuity in the motion, as indicated by the location of the center of rotation.
  • #90
Isn't is simply due to loss of kinetic energy i.e. the book is moving (rotating and translating) due to kinetic energy that friction opposes. Since friction is not a conservative force, the kinetic energy is lost and since the book is on the flat table there is not potential energy so when the kinetic energy ends then the movement (rotation and translation) stops at the same time.
  • #91
There appears running torque for the rotation.Fulcrum and force are two essential ingredients for running torque. That is to say, ununiform configuration of force is responsible to the rotation.In addition, rotation disappears if surface is ideally flat.
  • #92
Could someone tell me (I may have missed this in the past 90 posts; if so, I apologise) why the 'rotational' motion of a point is being considered? Does that have any meaning? At anyone instant, all points can be considered to have a linear velocity. What is the 'frictional torque' on a point?
The energy loss at any point is just proportional to its speed, as I have pointed out before. The faster moving points will be dissipating the book's KE faster than the slower moving points (it will be zero for the one point that happens to be stationary). If just one point is moving then all the others but the pivot point, must be moving too (rigid book).
Also, the relative distribution of speeds over the surface will be the same for the same ratio of rotation /translation speeds (everything scales). The rate of energy loss over the surface will be proportional to the absolute speed of , the CM and ratios of velocities will also be the same during every rev of the book.
Full marks to people for trying a simulation but the initial equations for a simulation must be justified before the results actually prove anything.
  • #93
Although it is true that rotation stop at the same time, I think the only thing you have demonstrate is that rotation can only stop when translation is slowed, and vice versa.
Based on the program I wrote, that pivot point always moves towards the edges of the book. If the book is circular, it will approach the a point on the circumference.
If we slowed it down by some other method (not friction), we could stop one without the other and there would be no discontinuity of motion.
  • #94
The KE at any point will be proportional to the square of the speed, so reducing the KE in proportion to the speed will not keep everything proportional. It will disproportionately affect the speed of the slower moving points.
... I'm still considering one of your other points ...
  • #95
But the rate of loss of energy is proportional to speed (friction force times speed is dissipated power); that's my point about "everything" being proportional. Perhaps the word "everything" was a bit unspecific.
What I am getting at is that the same exponential energy dissipation (not KE) decay factor applies to every point at every time; whatever its instantaneous speed, its loss of power is proportional to that speed. This, in my reasoning, means that no energy can be lost from anywhere 'first'. This all hangs upon the idea that the 'rotational' forces and energy do not have to be relevant - even if the way they have been used by some contributors is actually valid - I have my doubts about that.
I thought that this idea could be applied even better if you bear in mind that the instantaneous stationary point (reference the table) will follow a path over the bottom surface which will repeat itself once per cycle of rotation*. So you could break one cycle into a loop of N delta steps and apply my exponential idea to every point sampled at a given angle of rotation. Sm(tn) would represent the speed Sm of point m at time tn, where n goes from 1 to N every rotation. The speed samples Sm(tn) would all follow a path of energy loss against speed Sm(tn). No individual point could attain zero speed (unless there was no initial translation speed); at times when its speed is low, the energy loss is low and when its speed is high the energy loss would be high - but the rest of the book is coupled to it so you could say it is sharing the total KE of the other points and, between them, all points are dissipating the KE at different rates and at different times.
*Hmm - that may be a circular argument but, even without it, my reasoning seems coherent - to me.
  • #96
This is basically the same code as before but with better annotation.
I also eliminated an unnecessary variable and renamed two other variables.
Let me know if you want more detail or explanation.
Code:
  //  This code computes the frictional forces acting on a spinning and
  // translating disk at one moment in time.  The ratio of the speeds of
  // rotation and translation are varied over a wide range.
  double  fR, fX, fY, fX2, fPivot, fPR;
  double  fForceX, fForceY, fSpeed, fRDiv;
  //  I am presuming a circular book.  "fR" is the radius of that book and I
  // am setting it to 1.  This doesn't really matter because everything will
  // scale to the radius anyway.
  fR    = 1.0;   // Radius
  //  The ratio of the rotational speed and the translational speed can be
  // described by specifying the "pivot" as a ratio of the radius, which I
  // calling "pPivot".  When pPivot is zero, there is only spin motion.
  //  The pivot point is the location where there is no relative motion
  // between the book and the surface.  It will always be along a line
  // that crosses through the center of the book and is perpendicular to
  // the translational motion of the book.
  //  When pPivot is 1, the pivot point will be at the circumference of
  // the book.  When pPivot is zero, the pivot point is at the center of
  // the book.
  //  I am varying the pPivot from 0 (book center) to 2.5 (well outside
  // the book so there is much more translation that rotation.
  for(fPivot=0; fPivot<=2.5; fPivot+=0.05) {
    //  Multiplying "fPivot" by the radius gives us the actual distance
    // between the pivot point and the center of the book.
    fPR   = fPivot*fR;
    //  I will be performing discrete integrations across the surface of
    // the book.  "nDiv" is the number of discrete interval I will be
    // using along the radius.  Computation time will be proportional to
    // nDiv*nDiv but precision improves as nDiv is increased.
    nDiv  = 100;
    //  Two values that will be needed in the inside loops (below) are
    // precomputed here.  They are the actual distance of one interval
    // (fRDiv) and the square of nDiv (nDiv2).
    fRDiv = fR/nDiv;
    //  We will be integrating five value:
    //   nArea:    The area of the circular book surface.
    //   fSpinFrictionMax:  The force that would have been applied
    //           against friction if there was no translational force.
    //   fForceXSum:  The translational force along the direction of
    //           travel.
    //   fForceYSum:  The translational force perpendicular to the
    //           direction of travel.  This should be zero and is used
    //           as a check.
    //   fTurnForceSum:  The force applied against the book's spin.
    nArea = 0;
    fForceXSum  = 0.0;
    fForceYSum  = 0.0;
    //  Discrete integral along the direction of motion from the
    // trailing edge to the leading edge.
      //  The book is circular and we only want to integrate across
      // points that are on the books surface.  So we compute the
      // range of Y value that will keep us on the book (nYRange).
      //  We are using __int64 foor the intermediate results.  This
      // will allow us to use values of nDiv above 45000 - not that
      // we would want to run the program that long.
      //  Compute the X coordinate and its square.
      fX  = nX*fRDiv;
      fX2 = fX*fX;
      //  Discrete integral across the direction of motion from the
      // left edge to the right edge.
        // The Y coordinate.
        fY = nY*fRDiv;
        //  These next two integrals (nArea and fSpinFrictionMax)
        // are not dependent on fPivot.  So if I wanted to optimize
        // for speed, I could create separate (nX, nY) loops for
        // them so that they are only computed once.
        //  Integrate the book's area by integration so that it will
        // match the other integrals.
        nArea++;
        //  Integrate the spin friction assuming no translation.
        //  Compute the direction of the frictional force.  It will be
        // against the direction of motion and can be computed
        // from the relative position of this point to the pivot point.
        fForceX = -fY-fPR;
        fForceY = fX;
        //  Compute the speed.
        fSpeed = sqrt(fForceX*fForceX+fForceY*fForceY);
        //  Check for the zero-friction point.  This is important to
        // avoid zero/zero division.
        if(fSpeed<0.001) continue;
        //  I'm using a coeeficient of friction of "1", so the absolute
        // value of (fForceX,fForceY) must be 1.
        fForceX /= fSpeed;
        fForceY /= fSpeed;
        //  The turn force is the cross product of the force and the
        // arm to the center of gravity (fX,fY).
  • #97
Code:
OK, so that works out the forces. Then will you calculate the effects of those forces on the book as a whole? It could help perhaps is you were to describe the process analytically, rather than in code. Code is easily digestible by a compiler but a series comment lines tends get a bit disjointed for the human reader.
I guess your approach so far is fine. What does the next step involve and what does it show?
  • #98
I'm not sure where you're getting this.
If you take the maximum frictional forces for translation and rotation as occurring when there is, respectively only translation or only rotation, then the table shows what percentage of that maximum force you have when the pivot point it not at those extremes. Although, I am wondering if I should have computed energy loss instead of force. What is critical is that in either case (force or energy) the spin and translation curves will be monotonic. So they will cross at a particular point and the book will tend towards the spin/translation ratio corresponding to that point. The only time there will be a regular oscillation of this ratio is when the book is not circular and it is already at the ideal spin/translation ratio.
  • #99
There will be only one point at any time that is not moving wrt the table. For a disc the points will lie on a circle where tangential velocity equals minus translation velocity of centre. For a general shape the locus may not be a circle (?) this point is losing no energy from the book.
  • #100
I tend to think in a mixture of graphics and computation - and sometime the graphics don't translate fluently to equations.
The basic question can be restated as:
Given any particular initial spin/translate ratio, will that ratio tend towards the extremes (no spin or no translate)?
Or, restated again:
Given any particular spin/translate ratio, in what direction will the spin/ratio change?
If the answer to that last question is either "the ratio stays constant" or "is tends to some middle point", then we know that the spin and translation end at the same time.
A book that is only translating has speed-squared (Ts=speed; Ts2/2) energy and is loosing energy at rate proportional to speed (Ts). So it will stop in a period proportional to speed (Ts/2).
A book that is only spinning has speed-squared (Ss=speed at edge; Ss2/4) energy and is loosing energy at a rate proportional to average speed (2Ss/3). So it will stop in a period proportional to speed (3Ss/8) - but 25% quicker than with the corresponding translational speed.
(So when I went to the 2:1 ratio in the table, I was probably wrong. But anyway...)
If we had two books, one spinning (Ss) and one translating (Ts) and we wanted them to stop moving at the same time, then Ts/2 must equal 3Ss/8, so Ss/Ts must equal 4/3.
When there is a combination of spin and rotation, I will not get my maximum energy loss from either. So the situation will be:
Translational Speed: Ts
Translational Energy: Te=Ts2/2
Maximum relative rate of translational energy loss: Tfmax = Ts
Effectiveness of translational energy loss: Tfe(Ts/Ss)
Actual relative rate of translational energy loss: Tf = Tfmax*Tfe(Ts/Ss) = Ts*Tfe(Ts/Ss)
Spin Speed: Ss
Spin Energy: Se=Ss2/4
Maximum relative rate of spin energy loss: Sfmax = 3Ss/8
Effectiveness of spin energy loss: Sfe(Ts/Ss)
Actual relative rate of spin energy loss: Sf = Sfmax*Sfe(Ts/Ss) = 3Ss*Sfe(Ts/Ss)/8
The Tfe and Sfe functions were the ones I was trying to compute with my program - and show in the table.
We can further describe the situation in terms of how fast we are approaching a stationary book at the given moment. Of course, since the spin/translate ratio is changing, this rate will change. But at any given moment:
Extended time to no translation: Tet = Te/Tf = (Ts2/2)/(Ts*Tfe(Ts/Ss)) = Ts/(2Tfe(Ts/Ss)).
Extended time to no spin: Set = Se/Sf = (Ss2/4)/(3Ss*Sfe(Ts/Ss)/8) = 2Ss/(3Sfe(Ts/Ss)).
Ratio of extended times to no translation and no spin: Ret = Tet/Set = (Ts/(2Tfe(Ts/Ss)))/(2Ss/(3Sfe(Ts/Ss))) = (3/4) (Ts/Ss) (Sfe(Ts/Ss)/Tfe(Ts/Ss)).
If Ret equals 1, then we are bleeding energy in the same proportion form both spin and translation. Since our Ts/Ss ratio is not changing, Ret will remain 1 until both stop.
If Ret is greater than 1, spin is slowing faster than translation and our Ts/Ss ratio is increasing.
If Ret is less than 1, translation is slowing faster than spin and out Ts/Ss ratio is decreasing.
When Ret is not 1, we need to look at whether it will be heading towards 1 or away from 1.
If it is moving towards 1, one motion will end before the other. If it is moving towards 1, they are syncing up.
Ret is useful because we know the target is 1. But we can do the same sort of thing with the Ts/Ss ratio:
Letting the ratio be: Rs = (Ts/Ss)
Ret = (3/4) (Ts/Ss) (Sfe(Ts/Ss)/Tfe(Ts/Ss)) = (3/4) (Rs) (Sfe(Rs)/Tfe(Rs))
We are aiming for Ret equaling 1, so let
Target ratio: Rst such that (3/4) (Rst) (Sfe(Rst)/Tfe(Rst)) = 1
Rst = (4/3) Tfe(Rst) / 3Sfe(Rst)
At this value, the ratio will not change.
Now consider what happens when we are not exactly at Rst, say we are at Ratio=Rst+δ
d( (4/3) Tfe(Ratio) / Sfe(Ratio) ) / d(Ratio)
= (4/3) Sfe(Ratio)Tfe'(Ratio)) - Tfe(Ratio)Sfe'(Ratio) / Sfe(Ratio)²
We only need to know the sign of this value so...
Is Sfe(Rst)Tfe'(Rst)) - Tfe(Rst)Sfe'(Rst) < 0?
Sfe(Rst) is never negative (range is 0 to 1)
Tfe(Rst) is also never negative (range is 0 to 1)
Sfe'(Rst) is negative because the effectiveness of the spin energy loss always decreases with increasing spin.
Tfe'(Rst) is positive because the effectiveness of the translational energy loss always increases with increasing spin.
So both terms will be zero or negative. And they both can't be zero.
So the area around Rst has a negative slope. So if we have start with Rst+δ we will tend to move opposite from the change (δ), back towards Rst.
