Atom Rubbing Sounds: Wood vs Glass
  • Thread starter Drbazz
  • Tags
    Noise
In summary: You can only scratch one if it is harder than the other. When atoms collide they produce different sounds because the particles have different shapes and sizes.
Drbazz
What makes the noise when atoms rub each other. E.g a different noise is made from scratching wood than a noise from scratching glass.
well noise is just an illusion created by your brain. All 'noise' is, is atoms in the air vibrating against each other. These atoms vibrations reach your eardrums which convert them into signals your brain can interpret.
If you were in a vacuum (no air) I could yell at the top of my lungs and you would not hear a thing.
Now, if you are having trouble understanding what makes sounds different, or how we are able to interpret one sound from another and why everything doesn't sound the same...
Then just think of speakers. All speakers are is basically a wall that vibrates. It has a magnet on the speaker and an electromagnet attached to some wires. When an electrical signal passes through the electromagnet it attracts the speaker and then it let's go causing the speaker to "push" the air.
How is it that a speaker then, if all it can do is push, create soooo many different sounds?
It's the patterns of vibrations that are created that give rise to all the different possible sounds.
The mediums the sound in also has an effect. In water every thing sounds different because sound moves at a different speed.
This brings up the question "If a tree falls in the forest and nobody is there to hear it, does it make a sound?"
no eardrums=nothing to interpret the compression wave created=no sound
I never thought of that. Logically it would, but if you define sound as how your brain interpretaties wave compressions then there is no sound... still compressions though.
Sound is just mechanical vibrations. So in a sense, "touch" is "very low frequency sound" - the lowest frequency vibrations in a rock concert or organ recital are felt with your body. Scratching wood and glass produces different sounds because you cannot scratch them in the same way.
What is the science behind atom rubbing sounds?
The atom rubbing sound is produced when two surfaces come in contact and rub against each other, causing vibrations that travel through the material and reach our ears as sound waves. This phenomenon is governed by the principles of physics, specifically the laws of motion and conservation of energy.
Why do wood and glass produce different sounds when rubbed?
The difference in sound produced by wood and glass is due to their different material properties. Wood is a porous material made up of fibers, which allows for more vibration and thus a deeper, lower-pitched sound. Glass, on the other hand, is a denser and more rigid material, resulting in less vibration and a higher-pitched sound.
Can the sound produced by atom rubbing be altered?
Yes, the sound produced by atom rubbing can be altered by changing the properties of the materials or the force applied when rubbing them together. For example, applying more pressure or using a different type of wood can result in a different sound.
Are atom rubbing sounds important in any scientific applications?
Yes, atom rubbing sounds have been studied and applied in various fields such as acoustics, material science, and archaeology. In acoustics, the study of atom rubbing sounds helps in understanding the properties of different materials and how they affect sound. In material science, it can be used to determine the quality and durability of materials. In archaeology, it can aid in identifying the materials used in ancient artifacts.
Is there any practical use for atom rubbing sounds?
Aside from scientific applications, atom rubbing sounds can also be used in musical instruments, such as rubbing a bow against the strings of a violin. It can also be used for entertainment purposes, such as creating sound effects for film and television. Additionally, some people find the sound of atom rubbing soothing and use it for relaxation or meditation purposes.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Other Physics Topics
  • Electromagnetism
  • General Math
