What mass of the ethanol is she freezing?
To determine the mass of ethanol being frozen after removing 9.53x10^4 J of heat energy, the technician must use the equation Q = mL, where Q is the heat energy removed, m is the mass, and L is the latent heat of fusion for ethanol. The specific heat capacity of ethanol and its melting point are essential for accurate calculations. Participants in the discussion emphasize the need to reference these values to solve the problem effectively. Understanding the relationship between heat energy and temperature changes is crucial for this calculation. The discussion highlights the importance of gathering the necessary data before applying the equations.
MacoRules94
A technician freezes some ethanol by removing 9.53x10^4 J of heat energy from it at its melting point. What mass of the ethanol is she freezing?
What equation do you think you need to use here? What information do you think you need to have to work out this problem?
No idea
MacoRules94 said:
No idea
Wouldn't the technician have to lower the temperature to the freezing point? Do you know an equation that related heat energy to temperature?
No ida
MacoRules94 said:
No ida
Do you know the equations Q=mcΔT and Q=ml ?
Yes
Q = Mas x (umm, 4200 for water :) ) x (Tf - To)
You will need to get the specific heat capacity of ethanol, the melting and freezing temperatures. Look those up.
