What physical quantity has dimension [ML⁻³T⁻²] in electromagnetism?
Kim Gi Hyuk
TL;DR
Seeking a named physical quantity with dimension [ML⁻³T⁻²].
Two independent paths from Maxwell's equations (ρ²/ε₀ and μ₀J²)
both yield this dimension, suggesting it may be the apex of an
electromagnetic dimensional hierarchy. Is this quantity known in
established physics?
Background.
I have been building a systematic dimensional map of electromagnetic quantities, organized by their MLTIQNJ exponents. The map places mechanical quantities along a central vertical axis, with electric quantities to the left and magnetic quantities to the right — connected by structured dimensional steps (×d, ×E, ×H, etc.). The left-right symmetry reflects the duality between electric and magnetic sources.
The quantity χ.
When filling in all cells of the map using dimensional consistency with neighboring quantities, the top-center cell — the apex of the mechanical core axis — must have dimension:[χ] = M¹L⁻³T⁻²I⁰.
Two independent paths from Maxwell's equations both lead to this dimension:
- From Gauss's law (electric source): ρ²/ε₀ ~ [ML⁻³T⁻²]
- From Ampère's law (magnetic source): μ₀J² ~ [ML⁻³T⁻²]
where ρ is charge density [IL⁻³T] and J is current density [IL⁻²].
Note that (ρ, J) form the natural pair of electromagnetic source quantities — the four-current in relativistic notation.
My Questions
1. Does a named physical quantity with dimension [ML⁻³T⁻²] exist in established physics?
2. Is the structural relation ρ²/ε₀ ~ μ₀J² physically significant? For instance, does it appear in plasma physics, radiation reaction theory, or higher-dimensional theories such as Kaluza–Klein or Brane World models?
3. Both ρ and J — quantities with current index I≠0 — give rise, through ε₀ and μ₀, to a purely mechanical quantity χ with I⁰. Is there a known principle explaining why the apex of an electromagnetic dimensional hierarchy should be charge-free?
There isn’t any particularly deep significance for the dimensions of a particular quantity outside of the formulas where it appears and the system of units you use. Since you don’t specify either it isn’t much that can be said.
No.
That is the acceleration of the mass density.
  • Haha
There is some arbitrariness about dimensions. The Gaussian system has only three, but it is a mix of the electrostatic (esu) and electromagnetic (emu) systems, which have conflicting dimensions for the quantity of electric charge. By convention, charge was chosen to be measured in ## \rm dyn^{1/2} cm ## (esu) in the Gaussian system, whereas ## \rm dyn^{1/2} s ## (emu) was used in the practical system that evolved into the SI. It is rather unsettling to have different dimensions for a single physical quantity, depending on how it is measured! (As a force between two charges at rest, or between two electric currents.) Different units for charges at rest and charges in motion!
The dimensions differ by a velocity, and for the units we have the correspondence $$ \rm
1\ Biot \cdot second = 1\ dyn^{1/2} s \leftrightarrow 3 \times 10^{10} \ dyn^{1/2} cm = 3 \times 10^{10} \ Franklin
$$ which really means that 1 second is the same as 30 billion centimetres, if "charge" is to have only one reasonable dimension. Of course the speed of light is a fundamental constant, and the metre is now defined in terms of the second. Relativity has taught us that space and time are unified, and the distinction between dimensions of length and time is arbitrary. As for the "correct" dimension of charge, the existence of the fine-structure constant indicates that it should be dimensionless.
I found this an interesting read: Babel of Units. The Evolution of Units Systems in Classical Electromagnetism
Baluncore said:
No.
You're right — I should have specified SI units from the start. Apologies for the ambiguity.
Exactly — and that kind of identification is the core of this work. My project is to systematically map all physical quantities by dimensional structure using MLTIQNJ base dimensions (extending MLT to include I, Q, N, J). The goal is a reference framework — analogous to a periodic table — where quantities sharing the same dimension are grouped together, making such relationships explicit and visible across domains.
Happy to elaborate if there's interest.
I wrote some code some time ago that while computing numbers, also tracked dimensions. It was able to identify the units and flag errors. This was the table I used to identify units and terms.
Code:
 Length,  m, metre
 | Mass,    kg
 | | Time,    s, second
 | | | Current, A, ampere
 | | | | Temperature, K, kelvin, celcius
 | | | | | Light,  cd, candela
 | | | | | | Substance, mole
 | | | | | | | Angle,     rad, radian, degree
 | | | | | | | | Information, bit
 | | | | | | | | | Money,    $, currency
 | | | | | | | | | | Divisor, common to all dimensions
 1 0 0 0 0 0 0 0 0 0 1    m  metre  Length
-1 0 0 0 0 0 0 0 0 0 1        Wave number
 0 1 0 0 0 0 0 0 0 0 1    kg  kilogram  Mass
 0 0 1 0 0 0 0 0 0 0 1    s  second  Time
 0 0 0 1 0 0 0 0 0 0 1    A  ampere  Electric current
 0 0 0 0 1 0 0 0 0 0 1    K  kelvin  Temperature
 0 0 0 0 0 1 0 0 0 0 1    Cd  candela  Luminous intensity
 0 0 0 0 0 0 1 0 0 0 1    mol  mole  Substance
 0 0 0 0 0 0 0 1 0 0 1    rad  radian  Angle
 0 0 0 0 0 0 0 0 1 0 1    b  bit  Information
 0 0 0 0 0 0 0 0 0 1 1    $  USDollar  Money
 0 0-1 0 0 0 0 1 0 0 1    Hz  hertz  Frequency
 1 1-2 0 0 0 0 0 0 0 1    N  newton  Force
-1 1-2 0 0 0 0 0 0 0 1    pa  pascal  Pressure, Stress
 2 1-2 0 0 0 0 0 0 0 1    J  joule  Energy, Work, Torque, Moment, Couple
 2 1-3 0 0 0 0 0 0 0 1    W  watt  Power, Energy flux
 0 0 1 1 0 0 0 0 0 0 1    C  coulomb  Charge
 2 1-3-1 0 0 0 0 0 0 1    V  volt  Voltage
-2-1 4 2 0 0 0 0 0 0 1    F  farad  Capacitance
 2 1-3-2 0 0 0 0 0 0 1    ohm  ohm  Resistance
-2-1 3 2 0 0 0 0 0 0 1    S  siemens  Conductance
 2 1-2-1 0 0 0 0 0 0 1    wb  weber  Magnetic flux
 0 1-2-1 0 0 0 0 0 0 1    T  tesla  Magnetic flux density
 2 1-2-2 0 0 0 0 0 0 1    H  henry  Inductance
 0 0 0 0 0 1 0 2 0 0 1      lumen
-2 0 0 0 0 1 0 2 0 0 1      lux  Luminance
 2 0 0 0 0 0 0 0 0 0 1        Area
 3 0 0 0 0 0 0 0 0 0 1        Volume
 1 0-1 0 0 0 0 0 0 0 1        Velocity, Speed
 0 0-1 0 0 0 0 1 0 0 1        Angular velocity
 0 0-2 0 0 0 0 1 0 0 1        Angular acceleration
 2 1-2 0-1 0 0 0 0 0 1        Entropy
 2 0-2 0-1 0 0 0 0 0 1        Specific heat
 1 1-3 0-1 0 0 0 0 0 1        Thermal conductivity
-1 1-1 0 0 0 0 0 0 0 1    pl  poiseuille  Dynamic viscosity
 2 0-1 0 0 0 0 0 0 0 1    sk  stokes  Kinematic viscosity
 1 0-2 0 0 0 0 0 0 0 1        Acceleration
-3 1 0 0 0 0 0 0 0 0 1        Density
 1 1-1 0 0 0 0 0 0 0 1        Momentum, Impulse
 2 1 0 0 0 0 0 0 0 0 1        Moment of inertia
 2 1-1 0 0 0 0 1 0 0 1        Angular moment
 1 0 0 0 0 0-1 0 0 0 1        Molecular weight
 3 0-1 0 0 0 0 0 0 0 1        Volume flow
 0 1-1 0 0 0 0 0 0 0 1        Mass flow
 0 0-1 0 0 0 0 0 1 0 1        Information flow
-2 0 0 1 0 0 0 0 0 0 1        Current density
-2 0 1 1 0 0 0 0 0 0 1        Electric polarization, Surface charge density
-3 0 1 1 0 0 0 0 0 0 1        Volume charge density
 1 1-3-1 0 0 0 0 0 0 1        Electric field strength
 1 0 1 1 0 0 0 0 0 0 1        Electric dipole moment
 3 1-3-2 0 0 0 0 0 0 1        Resistivity
-1 0 1 0 0 0 0 0 0 0 1        Electrical conductivity
-3-1 4 2 0 0 0 0 0 0 1        Permittivity
 1 1-2-2 0 0 0 0 0 0 1        Permeability
-1 0 0 1 0 0 0 0 0 0 1        Magnetic field strength
 2 0 0 1 0 0 0 0 0 0 1        Magnetic dipole moment, pole density
 1 0 0 1 0 0 0 0 0 0 1        Magnetic pole strength
 0 0 0 0 0 0 0 0 0 0 1        Dimensionless
Thank you, WernerQH — this is exactly the kind of discussion I was hoping for.
The point about E and B having the same dimension in the Gaussian system is particularly striking. In SI-based frameworks, they appear dimensionally distinct, yet the underlying physics treats them as components of a unified electromagnetic field. This asymmetry has always felt like an unresolved tension to me.
I'll read the 'Babel of Units' paper over the weekend. The question of how dimensional structure changes across unit systems — and what that implies for the definition of physical quantities themselves — is something I'd like to explore more deeply. It may have direct relevance to the dimensional mapping framework I'm developing.
Looking forward to continuing this conversation.
That is good, but you still have not said which equations you are using. The dimensionality of a quantity only has meaning once both the system of units and the equation has been specified. You have finally specified the units, but despite pointing out the need for both in post 2 it is now post 8 and the equations you are using are still missing!
This makes a difference. Consider the SI dimensions ##M^{ 1} L^{2 } T^{ -2}##. In the equation ##E=mc^2## it is the energy of a body at rest. In ##KE=\frac{1}{2}mv^2## it is the kinetic energy of a moving body. And in ##\vec \tau=\vec r \times \vec F## it is the torque. You can talk about equivalence of the first two, but even though they have the same dimensions, they are physically distinct from the third.
Dimensions do not have any inherent physical significance. They only have meaning within a specific unit system and physical equation.
You may want to study EM in CGS systems. In those systems EM units are all purely mechanical.
You may also be interested in particle physics units where everything is tied to ##\mathrm{eV}##.
There are also many people that use personal unit systems that are numerically equal to SI, but with some personal alteration. Like choosing that radians are a base unit with dimensions of angle, or where moles are dimensionless.
In relativity we often use units where ##c=1##, not just numerically but also dimensionally. So you might measure a person’s height in nanoseconds or the duration of the Kessel run in parsecs.
Probably the most extreme example is geometrized units, where the only fundamental dimension is length. So mass, time, and charge, each have dimensions of length.
The asymmetry disappears if you set ## c=1 ##. There is no "unresolved tension" -- it's just the result of historical contingencies, of how we've perceived and measured the phenomena in the real world. Time and space were perceived as completely distinct, one being measured with clocks and the other with rulers. And things differing vastly in scale -- compare 1 second with 300000 kilometers! There is no problem with introducing additional dimensions. For instance, you could choose to treat distance and height as different dimensions, one being measured in miles, the other in feet. (In aviation that's a pretty normal thing to do.) Because the scales are not so different, it's easy in this case to perceive them as the same dimension, "length".
It was a very practical decision to introduce "current" as an extra dimension in the SI, but there was some arbitrariness in the choice of defining it in terms of the force between currents, rather than charges. As I tried to emphasize in my previous post, "charge" should have one dimension, but in the emu and esu systems they have different dimensions. Of course there is enormous flexibility in defining such systems, and each one is right, if used consistently. But the relation between the esu and emu units of charge is a strong signal that the speed of light plays a special role, and that time and length should be considered as having the same dimension. So in your scheme either L or T are redundant.
Resistance can be measured in cm/sec in the emu system, and in sec/cm in esu. In the theoretician's world where ## c=1 ##, resistance would just be a number, dimensionless. Mass would have the same dimension as energy: 1 TWh is just the same as 0.04 kg. Since Planck's constant is another fundamental constant, you could also express this same quantity as a frequency of ## \rm 5.4 \times 10^{45} \ Hz ##. With the arbitrariness of the original definitions of metre, gram, and second removed, you could simplify your dimensional scheme to one of powers of a single base dimension. (Which could be measured in centimetres, seconds, ## \rm GeV^{-1}, kg^{-1}, \dots ## or whatever.)
Using Planck units, you could take this to an extreme and claim that every physical quantity is dimensionless. But the strong ties of physics with geometry suggest that it is not only practical but also justified on theoretical grounds to use at least one physical dimension.
Thank you for the feedback, Dale. You are right — I should have shown the derivation explicitly from the outset. Let me clarify how the expressions relate to Gauss's law and Ampère's law in SI units.
Starting from Gauss's law:
∇·E = ρ/ε -> (∇·E)² = ρ²/ε²
Multiplying both sides by ε: ε(∇·E)² = ρ²/ε ≡ χ
Starting from Ampère's law (magnetostatic case):
∇×B = μJ -> Squaring both sides: (∇×B)² = μ²J²
Dividing both sides by μ: (∇×B)²/μ = μJ² ≡ χ
Since both expressions equal χ, we obtain: ρ²/ε = χ = μJ²
This is the correspondence I intended to express. Both sides share the same SI dimensions, and the equality holds as a direct consequence of squaring the two fundamental field equations.
I acknowledge that sharing the same dimensions does not imply physical equivalence. The quantity χ is intended as a dimensional structural quantity — a way of organizing electromagnetic quantities within a dimensional framework (MLTIQNJ), not a claim that these expressions are physically identical.
I apologize for not making this derivation explicit earlier, and I appreciate your patience in pressing for clarity.
Kim Gi Hyuk said:
Squaring both … Multiplying both sides by ε … Dividing both sides by μ
If I take literally any quantity and square it, then multiply by some integer power of ##\epsilon_0## or ##\mu_0## then I get a “mechanical” quantity.
Electric potential ##\phi^2 \epsilon_0##
Resistance ##R^2 \epsilon_0^2##
Magnetic moment ##m^2 \mu_0##
etc.
It can literally be done with any quantity. So how does a process that can be done with any quantity imply some sort of apex of a dimensional hierarchy?
etc.
Thank you for the pointed critique, Dale. I think there may be a misunderstanding worth clarifying.
You are absolutely right that one can always multiply an arbitrary quantity by some power of ε₀ or μ₀ and obtain something with mechanical dimensions. Algebraically, nothing stops that. But that is precisely not what I did.
The derivation leading to the quantity χ (chi) was added at your earlier request — you noted that the derivation steps were missing from my original post. What I presented was not a dimensional "trick" where I chose a target dimension and then worked backwards by multiplying convenient constants. Rather, it followed the physical relationships between quantities step by step: each factor in the expression enters because of a specific physical law or definition connecting the quantities involved, not because it happened to fix the dimensions.
So the real question is not "can ε₀ or μ₀ be used to manufacture mechanical dimensions?" — of course they can, as your examples show. The question is whether the specific expression for χ arises naturally from the relational structure of electromagnetism, or was artificially constructed. I would argue it is the former: the path from electromagnetic quantities to χ follows the internal logic of Maxwell's framework, not an arbitrary algebraic choice.
If you see a specific step in that derivation where a factor was introduced without physical justification, I would genuinely welcome pointing that out — that would be a substantive objection I could respond to directly.
That is precisely what you did. You literally took a quantity, squared it and multiplied or divided by a factor of ##\mu_0## or ##\epsilon_0##.
Really? Why did you square the quantities? Why not cube or square root?
Why did you multiply by a factor at all? Why ##\epsilon_0## or ##\mu_0##? Why not a different power?
The mathematical fact is that the algebra you did, whether physically justified or not, always arrives at mechanical quantities. So that fact alone cannot be used to imply anything special about this particular mechanical quantity.
  • · Replies 18 ·
