What power do you raise 3 to to get 9
  • Thread starter Thread starter m0286
    Power
m0286
Hello again..
Alright I am now on the part of 12th grade calculus, dealing with logs and exponents and stuff. I understand if say log39 That its basically what power do you raise 3 to to get 9. Well a question i need to answer is log162. So what power to I raise 16 to to get 2? I used my calculator just trying to find a number that would work, and i got 0.25. How would I show work for that? all of the solutions they gave for different equations worked different like for the log39They showed 2 ways:
3^x=9
3^x=3^2
x=2
OR
log39=log3(3^2)
=2
None of these solutions work for 16 since 2 is 2^1 and 16^1 is 16 not 2... I am confused.. Is 0.25 even the right answer.
Any Help is appreciated greatly!
Thanks ya!
hint: 16=2^4
Yes.Use this property of the logarithms wrt a change of basis.
\log_{16}2=\frac{\ln 2}{\ln 16}=\frac{\ln 2}{4\ln 2}=\frac{1}{4}=0.25
Daniel.
Have you heard of a change of base? You calculator can only do log base 10. Here is the formula
\log_b a = \frac {\log_c a}{\log_c b} where c can be anything. But why not set that to 10 so your calculator can crunch it.
0.25 is the correct answer, because 16^(0.25) = 2.
The easiest way to compute logs like \log_b x on a calculator is to compute
\log_b x = \frac{\log x}{\log b}
where the logs on the right can be any base at all (10, e, whatever). In other words, to find \log_{16} 2 on your calculator, punch up (log 2 / log 16).
- Warren
Thanks, but what does the In stand for...
I don't think so.Any (scientifical) calculator should have natural logarithm.It's eseential.
Daniel.
That's probably "ln", the "natural logarithm", and it means the logarithm to the base e=2.1718..., if you haven't met it in your class yet, it's probably not far off.
Dexter's post using natural logs can just as well be done with logs of any base, including 10.
- Warren
