B What reference frame is used for the velocity v in the Lorentz transformation?
  • B
  • Thread starter Thread starter Huangdongcheng
Huangdongcheng
TL;DR Summary
There is no such thing as an absolutely stationary reference frame, and thus the Lorentz transformation makes no sense.
When a spacecraft leaves the earth, its velocity is in the opposite direction of the earth's revolution around the sun. When the speed of the spacecraft relative to the earth is exactly equal to the linear speed of the earth's revolution, the spacecraft is stationary relative to the sun, and the earth revolves around the sun. Of course, spacecraft need to control power to avoid flying to the sun. People on the ground think that the spaceship is moving, and the clock on the spaceship is slower than the clock on the earth. But when the sun is the reference, the spaceship is stationary, and the earth is moving, and the clock on the earth is slower than the clock on the spaceship. So, when a spaceship returns to the earth after the earth has made a circle around the sun, which clock is slower, the clock on the spaceship or the clock on the ground? Why do we have to use the earth as a reference?
You are considering a problem where gravity is a significant factor, which means you need to consider GR not SR. In this particular case you can get away with just SR, but be aware that it's not always possible.
In fact, this scenario is just a messier version of the Twin Paradox, and as with that scenario the problem you have is naively applying formulae that apply in global inertial frames to the case of the Earth, which is not at rest in any inertial frame. You can use the naive calculations when you work in the Sun's rest frame; in that case the Earth is moving and its clocks tick more slowly than those on the spaceship. Thus we predict that its clocks will have ticked less when they meet up again, which is the correct solution. The Earth is the "travelling twin" in this scenario.
The Earth is, in fact, a Langevin observer so you can't just say "principle of relativity, so the spaceship's clocks tick slowly according to the Earth". If you do so you are forgetting the relativity of simultaneity, and failing to account for the way the Earth's notion of simultaneity differs from an inertial observer's notion. If you want to consider the Earth as at rest, you must first formally define a coordinate system where the Earth is at rest and which covers all of its orbit in order to be able to define "now" in the phrase "what rate is the spacecraft clock ticking at now". Once you've done that you can answer that question, and then perform an integral over one orbit to get the elapsed time on the spacecraft clock - which you will find is the same as the simple calculation in the Sun rest frame.
If you want to perform the calculations I'd suggest using radar coordinates. They have a clean physical motivation and work well even in this accelerating case. The maths will be fairly messy but should be in reach if you want to try.
Likes russ_watters, sbrothy and PeterDonis
The Lorentz transformations are used to transform between the coordinates used with one inertial frame and the coordinates used with another inertial frame. However, none of the three frames you are considering here ( the frame in which the hovering spacecraft is at rest, the frame in which the orbiting earth is at rest, the frame in which the sun is at rest while the earth orbits around it) are inertial so we need a lot more math than just the Lorentz transformations to properly analyze the situation.
But before you take on that problem, you should take on the much more basic question in your thread title: What reference frame is the velocity v in the Lorentz transformation measured?
If I am at rest and you are moving relative to me at speed ##v##, I can use the Lorentz transformation to transform between the coordinates of the frame in which I am at rest and the coordinates of the frame in which you are at rest. So ##v## is always relative to a point that we consider to be at rest in some frame, and the Lorentz transformations will convert from coordinates in that frame to coordinates in a frame in which that object is not at rest.
Likes sbrothy and Ibix
If there is a clock on the spaceship and a clock on the ground, you only need to give a definite answer as to whether the clock on the ground is slower or the clock on the spaceship is slower. Is it necessary to say so much?
Yes, because you have posed a complicated problem, likely much more complicated than you realize. It might be helpful if you could tell us what the question behind the question is, that is, what would you conclude from the answer if we told you which clock "runs faster"?
Also note that "runs faster" assumes that there is a meaningful way of comparing the tick rates of the two clocks. That is NOT the same thing as saying that one clock measures less time than the other between the two comparisons.
Likes Ibix and PeterDonis
There is a short answer to which one will show more elapsed time between meetings - I gave it in my previous post. But "which clock ticks slower" is a much more complicated question that requires a more complete understanding of relativity. Unless you just mean "slower on average between meetings", in which case the answer is as above.
Likes PeterDonis
A definitive answer was given in the first reply. Adding an explanation is what makes it a discussion. Is it necessary for you to complain about it?
Likes russ_watters and dextercioby
According to the theory of relativity or the Lorentz transformation formula, time passes more slowly for a moving object than for a stationary one, and the faster the object moves, the slower time passes. So, is it wrong for me to ask whether the clock on the spaceship runs slower or the clock on Earth does? If it is impossible to determine which object's time passes more slowly, it proves that there is a problem with the theory of relativity.
  • Skeptical
  • Sad
  • Haha
Likes russ_watters, PeterDonis, weirdoguy and 1 other person
No, it proves you didn't understand both theory of relativity AND answers you've been given. Read them again.
Likes phinds, russ_watters, PeroK and 3 others
That is a simplification of a special case. Your scenario is not that special case.
You can ask the question, but as we've already said the answer to "which clock shows more elapsed time when the spacecraft returns to Earth" is straightforward. But "which clock is running slow" is a more complicated question.
It isn't impossible. The answer to the simpler question is as I already stated in post #2, and the answer to the more complex version depends on details of your coordinate system (or at least your synchronisation convention) that you haven't specified.
Likes russ_watters and PeterDonis
Do also note, @Huangdongcheng, that you are simply proposing a messier version of the twin paradox scenario. Your use of circular motion instead of a linear out-and-back trip changes nothing except to make the maths harder.
The twin paradox was first proposed and resolved by Einstein in his 1905 paper where he first set out what became known as the special theory of relativity. It isn't a problem for relativity. The resolution has been known literally as long as the theory itself.
That is a very common misunderstanding, one that unfortunately has been repeated over and over by well-meaning people trying to explain relativity when they don’t completely understand it themselves.
If we consider A to be at rest and B to be moving, we will correctly conclude that B’s clock is running slower than A’s clock; but if we consider B to be at rest and A to be moving we will just as correctly conclude that A’s clock is one that is running slowly.
The apparent paradox here is the result of two common errors: being imprecise about exactly what it means to compare the rate of two clocks that are at not colocated; and failing to consider the relativity of simultaneity (if you are not completely comfortable with that concept, go google for it right now and do not proceed until you understand it thoroughly - it is essential to making sense of relativity).
We have a number of older threads showing how this apparent paradox is resolved. You will find some of them if you search this forum for “time dilation simultaneity” and if I have time I’ll link a few of them in a moment.
Edit: https://www.physicsforums.com/threa...on-question-w-spaceships.883303/#post-5552719
https://www.physicsforums.com/threads/time-the-special-theory-of-relativity.846242/#post-5307390
Likes PeterDonis
Nugatory said:
That is a very common misunderstanding, one that unfortunately has been repeated over and over by well-meaning people trying to explain relativity when they don’t completely understand it themselves.If we consider A to be at rest and B to be moving, we will correctly conclude that B’s clock is running slower than A’s clock; but if we consider B to be at rest and A to be moving we will just as correctly conclude that A’s clock is one that is running slowly.
Edit:https://www.physicsforums.com/threa...on-question-w-spaceships.883303/#post-5552719
Before a spacecraft leaves Earth, can we compare the speeds of two clocks? After the Earth completes one orbit around the Sun and the spacecraft returns to Earth, can we compare the speeds of the two clocks? Which clock would be slower, according to your calculations? Furthermore, if there are two objects moving far from the solar system, how can we determine which is moving faster and which is moving slower? Isn't the magnitude of the speed independent of the chosen reference frame? Would the results be the same if we chose a different reference frame?
  • Skeptical
Likes weirdoguy
Does the original version of the twin paradox only allow for linear motion? Doesn't the formula break down when an object moves on a curved path? No matter how complex a formula is, if it doesn't fit real life, it's useless.
  • Skeptical
Likes weirdoguy
That's an explanation often seen, but it can be misleading. To begin to understand this you must realize that to reach that conclusion the two clocks must share the same location, and that can happen at most only one time in scenarios where the Lorentz transforms apply.
Why is that? Because the Lorentz transformations apply to two reference frames that are moving relative to each other at a steady speed in a straight line.
If you are moving west and I am moving east we can cross paths at most only once. That's our only chance to directly compare our clocks. Since we'll never meet again what can we do to determine if my clock is ticking faster or slower compared to yours?
I can set up another clock at some distance behind me and synchronize my two clocks. Then, when you pass by my other clock it can be compared to yours. When I do that, I conclude that your clock is running slow compared to my clocks. But if you do the same you will conclude that my clock is running slow compared to your clocks.
This is a very confusing thing! Einstein said that it bothered him so much that one night as he was lying in bed thinking about it, and the solution came to him, it caused him to sit upright in his bed.
It's not wrong, it's just that you've simply been clever enough, as many others have before you, to arrange a scenario where there are two meetings. But all such scenarios involve motion that's not in a straight line at a steady speed, so the Lorentz transforms don't apply. This situation is so famous it has a name, the Twin Paradox.
Nope. It just means you're missing the realization that Einstein had when he sat upright in his bed.
You see, in the scenario I described above you will conclude that I made an error synchronizing my two clocks, and that is what led me to conclude that your clock is running slow. Likewise, I will conclude that you made an error synchronizing your clocks and that is what led you to conclude that my clock is running slow.
But in fact no errors were made by either of us. The Lorentz transforms will show this. It's the notion that simultaneity is relative. Things (like the readings on your two clocks) that are simultaneous in your rest frame are not in mine. And vice-versa.
In my opinion you have to work through the math to understand all this. Words alone won't do it. But the good news is you're not on your own. Lots of textbook authors have written worked examples. You just have to read and understand them.
Likes sbrothy and robphy
Indeed… Draw a spacetime diagram.
Likes Ibix and Herman Trivilino
Yes, it is wrong to ask that. The rate a clock ticks depends on the reference frame. So asking “which clock runs slower?” is wrong to ask because it is incomplete.
A complete question would be “which clock runs slower in the sun’s frame?”. Without specifying the frame, the question is wrong.
Once you ask a complete question then a valid answer is possible. The impossibility of an answer to an incomplete question is hardly a problem with any theory.
Likes phinds
No. the original form, published in the same 1905 paper in which Einstein introduced special relativity, involved circular motion (and in fact looks like a more clearly stated version of your original post). Since then most introductory presentations have used linear motion, because that special case illustrates the physics just as well but needs only high school algebra instead of multivariable and tensor calculus.
No, the formula works just fine no matter how complicated and twisty the path of the object is.
Because to OP is talking about "reference frames", they are most likely doing Newtonian physics and not actually doing GR. If they were doing GR, they would be talking about what metric they were using rather than about "reference frames". But I'll try to answer the question both from a Newtonian and a GR perspective. I expect that the full GR treatment will be too brief to be useful, but I hope to at least convey something about the "flavor" of the treatment.
From a Newtonian perspective, the reference frame one uses is essentially heliocentric. The heliocentric idea occured historically before Newton - with Copernicus, Kepler, and Gallileo being important authors. Rather than get the details wrong, I'll mention that Newton came later.
A better degree of approxmation would anchor the reference frame used for Newtonian calculations to the barycenter of the solar system rather than the sun, but I won't go into this refinement.
The basic equations of motion used in the Newtonian approach would be F=ma, with the gravitational force F being equal to GmM/r^2.
The basic equations used for the GR approach would be the geodesic equations. See https://en.wikipedia.org/wiki/Solving_the_geodesic_equations. Geodesics are still an approximation in GR, but they are a good one - actual planets would depart from the geodesic for various reasons, including the emission of gravitational waves, and numerically larger effects such as the transfer of momentum to the Earth from solar radiation.
The basic geodesic equations would be
$$\frac{d^2 x^a}{d \tau^2} + \Gamma^a{}_{bc} \frac{dx^b}{d\tau} \frac{dx^c}{d\tau} = 0 \quad \Gamma^a{}_{bc} = \frac{1}{2} \partial g^{ad} \left( \frac{\partial g_{cd} }{\partial x^b} + \frac{\partial g_{bd} }{\partial x^c} - \frac{\partial g_{bc} }{\partial x^d} \right)$$
F=ma is not used, thats the Newtonian approach - the GR approach is fundamentally different and based on different concepts.
These equations are probably not familiar to the OP and would require some study to disentangle enough to actually use. Among other issues one would need famiiartiy with the convention of summation over repeated indicies. The point of the equations though is that they are differential equations (just like the ones from the Newtonian equations) derived from the metric, ##g_{ab}##. So, specifying the metric gives the solutions for the orbits of test masses.
While there are several metrics one could use, the Schwarzschild metric is the usual choice. There are some alternatives one might use, but getting into the details is beyond the scope of what I want to write here.
There are a number of refinements that can be made to the GR analysis that I've outlined here - it has made some approximations, but this post is already long enough. The point is that it should not be at all surprising that we use a sun-centered coordinate system to work the problem in GR just as we did with Newton. The Sun, being the most massive object in the solar system, tends to dominate the physics. Again, refinements of this heliocentric model are possible in GR, but it would take an extended discussion to clarify this, I'll just drop the words "PPN approximations" and leave it at that.
I'll add one more thing. Rather than attempt to learn enough about GR to compute the orbits, it would be simplest to just assume that it gives a circular orbit. Then one can concentrate on the original question, by computing and integrating the proper time ##\tau## for the orbital motion, the "hovering" motion, and even answering the question of what trajectory maximizes the age of the stay-at-home twin. Perhaps I should have started here, but I didn't - and it would be another thread to do this justice. Of course, some famliarity with the concept of what proper time is is needed - perhaps another thread might be needed, to explain what proper time is and why it answers the question, before we would go about computing it :(.
Likes PeterDonis
Actually, no, it doesn't. The computation is very simple. If we have a "hovering" observer at radius ##r## in Schwarzschild spacetime and a second observer making a circular orbit at the same radius ##r## (so that the two meet once per orbit), then their respective time dilation factors are ##\sqrt{1 - 2M / r}## for the hovering observer and ##\sqrt{1 - 3M / r}## for the observer in the circular orbit. Since the latter is smaller than the former, the circular orbit observer measures less elapsed time than the hovering observer does between two successive meetings.
It can be even simpler (and may have been what @Ibix was doing way back in #2 of this thread): Remove the earth and its gravitational field from the problem. Likewise remove the sun and its gravitational field.
Now we have a flat spacetime, no general relativistic complications, can use Minkowski coordinates and the Lorentz transformations that OP was asking about in their first post. We have two clocks, one undergoing continuous circular motion under the influence of some force, and the other at rest at some point on that circle. They will meet once every rotation of the moving clock and the question is which clock counts more seconds between consecutive meetings.
I’m thinking that OP would be well-served by understanding this case and how it is just the twin paradox restated before moving out of flat spacetime.
Why choose the Sun as the reference frame? The solar system is also in motion within the Milky Way. Is it reasonable to choose the Sun as the reference frame? What if the spacecraft is moving far away from the solar system? Then what should be chosen as the reference object to measure the speed of the spacecraft? My point is that there is no absolutely stationary reference frame. We can choose any reference frame to measure the speed of an object. The Lorentz transformation then becomes meaningless.
That's correct.
That's wrong.
The ##v## in the Lorentz transformation is the relative velocity between the two frames.
Likes Dale
True. The advantage of the Sun rest frame is that it is the only one in which the speed of both ship and Earth is constant, so it is the only one in which you can apply the time dilation formula without having to do integrals. If you are happy with integration you can use any inertial frame, with the ##v## being the instantaneous velocity of the Earth or ship in that frame.
First, a meta observation. Special Relativity is over a century old and the mathematics underlies literally all of modern physics. We cannot explain how your phone (or anything else that uses electromagnetism) works without it, nor could we have expected nuclear reactors or weapons to work - yet they do. There's an FAQ linked in a sticky thread in this forum on the experimental testing that has been done. So which do you think is more likely - the core mathematics of an extremely well tested theory that you (possibly unknowingly) rely on every day is meaningless, or you are misunderstanding it?
Second, the point you are misunderstanding is that the Lorentz transforms relate the coordinates of events as measured in one inertial frame to the coordinates in another. The ##v## is the velocity of the second frame with respect to the first. That is, it is explicitly a relative velocity. The problem you have is that one of your objects is not at rest in any inertial frame, so you can only do naive calculations based on the maths of inertial frames if you pick a frame where its speed is constant. You can do non-naive calculations in any frame, but as we've said you're going to need integrals and quite possibly have to take careful account of the relativity of simultaneity. The usual constant speed linear out-and-back version of the twin paradox is a gentler introduction to this, because it requires developing understanding of the relativity of simultaneity but does not require any integrals.
Likes Dale
I did start re-writing the problem as a clock on a string whirled about your head, but actually if you idealise the Earth as a test particle in a circular orbit the maths of SR works exactly anyway. At least, it does as long as we don't get into stuff like detailed observations between the spacecraft and the Earth during the flight, where GR effects like Shapiro delay and gravitational lensing would kick in, not to mention the gravitational effect of the Earth itself, which is why I was careful to add an introductory paragraph noting that this is really a GR problem.
I agree it may be necessary to simplify to a clock on a string if we ever get past the OP's "Lorentz transforms are meaningless" error. The maths of rotating reference frames is quite messy enough without having to deal with numerical analysis of light paths in gravitational fields.
Perhaps I really don't understand relativity, but that doesn't mean we can't question and doubt authoritative theories. Aristotle's ideas persisted for over two thousand years, and eventually they were rejected.
There are different levels of "doubt". Suppose you started learning pure mathematics and immediately didn't understand mathematical logic. You have a choice.
1) Presume all mathematics is wrong or meaningless and that mathematicians are fools or conspirators. This is easy!
2) Presume that you, as a new student, will have to work hard to understand these ideas.
Ancient science, for all its merits, was build on shaky foundations. It progressed very slowly, with centuries passing between significant developments.
Modern science (mathematics, physics, chemistry, biology, geology, astronomy, medicine, engineering) is based on an enormous volume of empirical evidence. There is still a lot to discover, but the idea that it's all fundamentally wrong, is not likely to be a productive approach.
Likes robphy and PeterDonis
Of course. But you aren't doing anything except repeating "this doesn't make sense to me personally". You need to do some maths to actually get anywhere with understanding the theory or showing a problem with it, and you aren't doing that. Try calculating the elapsed time for Earth and the spaceship, for example, and we can help show you where you've gone wrong. I repeat my advice that this scenario doesn't add much except mathematical complexity to the linear version of the twin paradox, and I'd recommend working that one first.
Special Relativity is ridiculously simple when you get right down to it, and it is internally consistent. You might show by an actual experiment that the universe does not follow it (and indeed it doesn't - General Relativity is needed when gravity is a factor) but thought experiments will only show you that you do or don't understand the theory.
I notice I forgot to paste in the URL to the Experimental Basis of SR FAQ in my last post so the link won't work - I'll correct that now.
Likes robphy and Dale
There are no authoritative theories in physics. We do not "belive" in any theory because someone said we should. We "belive" in them because they are backed up by thousands/milions of experiments. Physics is empirical science.
Aristotle's ideas
Which are not scientific theories by modern standards. Any other examples? No.
Likes Dale
You solve this problem using mathematics: If a pair of twins were 20 years old at 8:00 on January 1, 2015. Then the elder brother went on a space journey and returned to Earth, and his clock showed 8:00 on January 1, 2020. So did he witness the events that happened on January 1, 2020 on Earth or the events that occurred on Earth in 2025? Could he see his younger brother on January 1, 2025?
  • #31
Yes. That is correct. In fact it is one of the underlying assumptions of the Lorentz transform
This is wrong. The fact that there is no absolutely stationary reference frame is one of the foundational assumptions of relativity. The correctness of its assumptions is precisely what makes the Lorentz transform meaningful. So this is completely backwards. It would be finding an absolutely stationary reference frame that would make the transform meaningless.
Likes PeterDonis
  • #32
Not here. The place for questioning and doubting authoritative theories is the professional scientific literature. PhyscisForums is an educational site that teaches about currently accepted science.
However, you should be made aware that your objections here are wrong. Relativity may eventually be found to be incorrect, but it will be through new experimental evidence.
Only new experimental evidence will disprove relativity. Do you have that? If so then please publish it in the scientific literature and then we can discuss it here once it is published. If not, then the purpose of this thread is to help you correct your misunderstandings.
The kinds of objections you are raising are just typical misunderstandings of introductory students. Your misunderstandings are a teaching and a learning challenge, not a challenge to the science.
Likes PeterDonis and PeroK
  • #33
I can do this easily (except for the bits you haven't specified l, discussed below). The point is for you to familiarise yourself with relativity.
You haven't specified the problem well. What speed is the elder brother travelling at relative to the Earth and are we assuming that he travels at constant speed (i.e., with instant acceleration)? Once you've specified that can you calculate the Lorentz gamma factor the Earth measures for the elder brother? Once you've done that, using the Earth frame, what does the maths tell you the clocks on Earth will show at the elder brother's return if his clocks showed 2015 when he left and 2020 when he returned?
Likes Dale
  • #34
Yes. ##2020-2015## is ##5## years and ##2025-2015## is ##10## years. So the mathematical question is, do there exist two timelike worldlines, ##x_1(t)## and ##x_2(t)## that intersect at two events such that one timelike worldline is ##\tau_1=10## years long and the other is ##\tau_2=5## years long?
In any inertial coordinates using units where ##c=1##, the length of a worldline can be calculated by $$\tau=\int_{t_i}^{t_f}\sqrt{1-v(t)^2}\ dt$$ where ##v(t)=|\dot {\vec x}(t)|##.
So, if ##v_1(t)=0## and ##v_2(t)=\sqrt{3}/2=0.866## then $$\tau_1= \int_{0}^{10}\sqrt{1-0^2}\ dt=10$$ and $$\tau_2=\int_{0}^{10}\sqrt{1-\left(\frac{\sqrt{3}}{2}\right)^2}\ dt=5$$
Thus the problem is solved. The elder brother can leave in 2015 and return in 2025 with his own clock showing 2020 provided he spent the entire trip at a constant speed of ##0.866 \ c## in the inertial frame where his younger brother is at rest.
Now, that we have established the math, the next step is to establish your understanding of the math. Please look over what I have posted and ask any questions about any part of the math that you do not understand. But do so with the clear understanding that the purpose of this exercise is your education and learning, not to give you space to make claims that relativity is wrong. Such claims would require new experimental evidence published in the professional scientific literature.
Likes nasu and weirdoguy
  • #35
You might want to start by working through the Twin Paradox FAQ: https://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
Likes Dale
  • #36
It seems that you haven't realized the complexity of this issue. Some problems can be solved using mathematics, but some cannot be simply addressed by mathematics alone. For instance, whether the calculated results are consistent with reality.
  • Sad
Likes weirdoguy
  • #37
For that, you'd have to do the experiment.
Likes Dale
  • #38
It seems that you're not here to learn, but to argue. Telling physiscists that they haven't realized the complexity of issue when you haven't even grasped the very basics of the topic is rude.
Special relativity is consistent with reality as hundreds of thousands of experiments and observations show. So, again, what do you want to achieve here?
Likes Dale, berkeman and PeroK
  • #39
Suppose the elder brother left the Earth at 8:00 on January 1, 2015, when they were both 20 years old. When he returned to Earth, his clock showed 8:00 on January 1, 2020, and he looked like a 25-year-old. While the younger brother's clock showed 8:00 on January 1, 2025, and he looked like a 30-year-old.
1. At two different times, 8:00 on January 1, 2020 and 8:00 on January 1, 2025, were the Earth in the universe at the same position? Should a moving Earth be at different positions at different times? Did the Earth that the elder brother stepped on in 2020 return to be in the same position as the Earth that the younger brother stepped on in 2025 in the universe?
2. If the elder brother's time passed slowly only because the reading on his clock was small and his body grew slowly, was it unrelated to what happened around him? If the elder brother's time was 8:00 on January 1, 2020, why could he stand together with the younger brother who was 8:00 on January 1, 2025 and see what happened around him in 2025?
If we follow this logical reasoning, if the younger brother was 30 years old in 2025, imagine he went back to 2020, his clock showed 2020, and he looked like a 25-year-old. But he didn't see what happened in 2020, and what he saw was still what happened in 2025. That is to say, he and his clock returned to the state of 2020, but the clocks of all the people around him showed 2025 instead of 2020. Do you think it's okay?
3. If one person's time passed slowly and showed 2020, and another person's time passed quickly and showed 2030, but they saw each other and saw all the other clocks showing 2025, do you think there's no problem?
  • #40
Indeed. That requires experiments.
The calculated results are consistent with a large amount of experimental data. In particular
Bailey et al., Nature 268 (July 28, 1977) pg 301.
Bailey et al., Nuclear Physics B 150 pg 1–79 (1979).
Hafele and Keating. Science Vol. 177 pg 166–170 (1972).
All three of those tested some version of your scenario, but the Bailey ones are conceptually simpler as the effect of gravity is negligible.
So now we have both the relevant math and a small sample of some of the most relevant experiments. Are you ready to start learning?
  • #41
Why do you think the universe cares that their clocks don't show the same time? They are at the same event.
The maths you are refusing to do would eventually show you that the time you experience is a measure of a "distance" through spacetime that you have travelled, and just like with distance through space the elapsed time depends on the route taken. The elder brother found a shortcut, so his clock advanced less, but both brothers started at the same event and ended at the same event.
  • #42
In reality, do you think that what happens in time has no connection with what occurs in the universe? Do you think that exactly the same events could take place in different times within the universe?
  • #43
It doesn't matter what you or he thinks about reality. What matters is what actually happens in reality. This is confirmed by experiments as linked above
  • #44
Have you really thought about these questions seriously? Suppose the elder brother left the Earth at 8:00 on January 1, 2015, when they were both 20 years old. When he returned to Earth, his clock showed 8:00 on January 1, 2020, and he looked like a 25-year-old. While the younger brother's clock showed 8:00 on January 1, 2025, and he looked like a 30-year-old.
1. At two different times, 8:00 on January 1, 2020 and 8:00 on January 1, 2025, were the Earth in the universe at the same position? Should a moving Earth be at different positions at different times? Did the Earth that the elder brother stepped on in 2020 and the Earth that the younger brother stepped on in 2025 have the same position in the universe space?
2. If the elder brother's time passed slowly was only because the reading on the clock was small and his body grew slowly, was it unrelated to what happened around him? Was the elder brother's time at 8:00 on January 1, 2020, able to stand together with the younger brother at 8:00 on January 1, 2025 and see what happened around in 2025? If reasoning like this is followed, why couldn't the younger brother, who was 30 years old in 2025, return to 2020 and have his clock show 2020, look like a 25-year-old, but not see what happened in 2020, but still see what happened in 2025? That is to say, he and his clock returned to the state of 2020, but the clocks of all the people around him showed 2025 instead of 2020. Do you think it's okay?
3. If one person's time passed slowly and showed 2020, and another person's time passed quickly and showed 2030, but they saw each other and saw all the clocks showing 2025, do you think there's no problem?
  • #45
Yes, because that's how reality/universe works. It's you that have problem with reality, because it does not work the way you want it to.
Likes Dale
  • #46
I've been teaching physics since 2008, and I've spent 5 hard years becoming a physicist. We all here thought about these questions seriously multiple times. You have not and you're wasting our time. You are not here to learn. This thread is going nowhere.
Likes berkeman, Dale and PeroK
  • #47
This is your problem. You think that there is a global time, so you think that the only way (non-broken) clocks can measure different times is if they are at different global times. This is wrong.
Relativity shows us that the time you experience is analogous to distance travelled through space. So two clocks showing different times is no more confusing or impossible than two odometers showing different distances.
  • #48
Your comments seem to indicate that you have a newtonian view of time. That there is the equivalent of a giant clock in the sky keeping track of a universal time that is the same everywhere. It's been shown repeatedly throughout the last 120 years that such a view is not right.
If the engineers who operate the GPS satellite clocks held that belief, the GPS system would not be precise enough to tell you what street intersection you are at, but instead perhaps only the city you were in. Each of the GPS clocks measure their own proper time, and engineers have to account for the fact that each clock reports a different amount of elapsed time between events.
  • #49
Every single one of us answering your questions has thought about it. We were all where you are once, but we studied and learned how the universe actually works. Your intuition is wrong, although in a way that will make milliseconds of difference over your life. Once you start studying high speed phenomena, though, you have to accept that you are wrong because that's what the experiments say.
Likes Dale
  • #50
Yes, I have, and they do not matter in the end. They are the standard questions that most students ask as distractions from the actual important learning. We have all asked these. I was stuck on my version for about 7 years before I understood.
Have you understood the math and the experiments?
Likes PeterDonis
