What system does this lagrangian represent?
  • Thread starter Thread starter Jamoo
    Lagrangian System
The discussion centers on identifying the physical system represented by a given Lagrangian, which appears to describe a coupled oscillator. The presence of the velocity term (bXY) raises questions about its significance. Participants suggest that transforming to different generalized coordinates could simplify the Lagrangian by eliminating the XY terms. The conversation also emphasizes deriving equations of motion and exploring special cases to better understand the system. Overall, the focus is on clarifying the implications of the Lagrangian and finding a more manageable form for analysis.
Jamoo
Hey guys,
I am struggling with this tutorial problem: If you have the following lagrangian:
L = m/2(aX^2 + bXY + cY^2) - K/2(ax^2 + bxy + cy^2)
(Where captial letters indicate first derivative with respect to time, a,b,c constants)
What physical system does it represent?
It looks like a simple coupled oscillator, but I don't know what the extra velocity term (bXY) could represent? Any help would be much appreciated.
Thanks
Does it matter what physical system it represents? What does the question ask?
It's really hard to work back to from the Lagrangian to a particular system, anyway, since the coordinates can be generalised coordinates rather than simple displacements, for example.
It would be possible to transform to different generalised coordinates (U,V) which would completely remove the XY terms in the expression, and give an equivalent Lagrangian with no terms of the form kUV.
For example, try:
U = X + Y
V = X - Y
The question is as follows:
1) Derive the Equations of motion for this sytem
Examine particularly cases a=c=0, and b=0,c=-a (I am not sure whther this applies to part 1 or 2/3)
2) What is the physical system described by the above Lagrangian
3) Write the natural form of the Lagrangian for this system
But thanks for the help so far.
You can probably write each term in terms of a symmetric matrix. Finding the eigenvectors and eigenvalues (i.e., "normal modes") should suggest a nicer choice of coordinates.
for the first term, do you mean X or X dot?
do you mean \frac {m}{2} (a\dot{x}^2 . . .. ?
JamesR and robphy, thanks. Using normal coordiantes seems to be the way to go.
sniffer: yes, by X I meant x dot, I just haven't worked out how to use the equation editor on forum.
sorry, i didn't read carefully.
