What will the gravitational field inside the Earth be?
If a ball is released in a channel dug from the North Pole to the South Pole, it will oscillate back and forth between the poles, taking about 42 minutes for each complete cycle. The gravitational force acting on the ball changes linearly with its distance from the Earth's center due to the shell theorem, which states that only the mass beneath the ball contributes to the gravitational pull. As the ball descends, the gravitational force initially increases until it reaches the center, where the acceleration becomes zero. After passing the center, the ball decelerates until it reaches the surface on the opposite side, where its velocity again becomes zero. This motion can be modeled as simple harmonic motion under the assumption of uniform density, although actual density variations in the Earth complicate this model.
Negi Magi
There is a question: If we dig a channel from the North pole of the Earth to the South pole of the Earth, then we release a ball into this channel from the North pole, what will be the motion of this be like?
I think this question is related to the inner gravitational field of the Earth
Ignoring friction and air resistance, etc., it would oscillate from pole to pole.
With a pole to pole length of time of about 42 minutes!
The force will change linearly with the distance from the centre.
This is connected with the shell theorem, i.e. there is no net force acting on a body inside an uniformly dense sphere.
As the ball gets deeper under the surface, the layers above it stop exerting gravitational force, and all that matters is the mass underneath.
That mass gets smaller with the third power of distance(volume of a sphere) as the ball goes down, but at the same time it is getting closer to the centre of mass attracting it, which force is inversely proportional to the distance squared(Newton's law of gravity).
F=\frac{GMm}{r^2}
M=ρV
V=\frac{4}{3}πr^3
F=\frac{\frac{4}{3}πr^3 ρGm}{r^2}
F=\frac{4}{3}πr ρGm
a=r \frac{4}{3} πρG
G is constant and we can assume the density of Earth ρ to be constant as well, so we have a linear relationship between acceleration and distance.
So the ball starts falling by being accelerated by g=9,81 m/s2, then the acceleration falls to 0 in the centre of the Earth just as the velocity reaches maximum.
Then it gets slowed down more and more the farther away from the centre it gets. As it reaches the surface on the other side, the velocity is again 0 and the acceleration is again g.
That does assume uniform density, whereas the density is sure to be higher towards the centre. But on that assumption (and ignoring the spin of the Earth), the linear relationship would make it simple harmonic motion.
It most certainly is. Which results in gravitational pull of Earth actually increasing almost half the way to the center, and only then beginning to drop.
Wikipedia has this graph that illustrates the effect.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
