What would crack easier? An iPhone 6 or an iPad air?
The discussion centers on the comparative durability of the iPhone 6 and iPad Air when subjected to impact, specifically whether one would crack easier when struck with a hammer. Participants suggest that the iPad Air may crack more easily due to its larger surface area and thinner design, while the iPhone 6 is perceived as sturdier because of its thicker frame and construction aimed at withstanding drops. The impact of screen protectors on crack resistance is debated, with some questioning their effectiveness beyond scratch protection. Additionally, there are mentions of bending issues with the iPhone 6, although reports of such incidents are minimal. Overall, the conversation emphasizes the importance of understanding the physical properties of these devices before making assumptions about their durability.
Jbeats245
If I took a hammer to each of the screens, which would crack first with a minimum amount of force? If I put a screen protector on it, would it change the answer of which one would crack first? I tried to pick two models which had similar frames. If the using different models actually makes it a simpler problem go ahead and try it.
Physics is an experimental science.
Likes TheDemx27 and Orodruin
Patience, Borek. Before unleashing your inner beast, you must create the hypothesizes!
Anyway, assuming both gadgets use the same Gorilla glass and you put the hammer on the center of their screens: I believe the iPad air will crack easier due to the fact that the iPhone 6 is smaller and a bit thicker & denser. This means it has more support from the frames, and the shockwave can dissipate more easily. than in iPad Air.
Besides, I'd imagine they've built the iPhone 6 much sturdier due to its predisposition to be dropped as well.
You must have missed the hype:
Well, isn't curved displays the new trend anyway?
Likes Borek
If I applied that much torque around the centre of my iPhone 5, it might just crack.
Honestly the iPhone 6's a large area, very thin aluminum phone. What do you guys expect would've happened?
Nikitin said:
Though honestly the iPhone 6's a large area, very thin aluminum phone.
In the follow up video he bends a similar (slightly thicker?) plastic phone, and it bends back. While trying to bend the aluminum phone back, cracks it. Nice demonstration of plastic vs. elastic material behavior, ironically plastic being the elastic one here.
Mhm, but I wouldn't do that too many times; it can't be good for the components inside. At any rate, how would you get into a situation where this bending business becomes an issue? As long as you don't try to sit on a large but thin phone while wearing super-skinny jeans this shouldn't be a problem.
They started doing those bending tests, after some noticed a slight bend from normal usage, within a few days.
What if you have no choice?
But if there's a screen protector on it, would the shockwave dissipate easier in the iPad air since there's more surface area? They're meant to absorb most of the impact.
I don't know. I thought those were only for scratch protection.
Allegedly somebody put it in his back-pocket and sat on it, and it bent, but I don't know the details. At any rate you should be careful with your new, fancy 1000 euro phone.
I guess people just assumed they can treat it just like their previous versions. It's not a completely unreasonable assumption.
Nice snip, Borek. But a large butt would probably cause less bending of the phone.
Not sure how much more solid the iPhone 5 is compared to the smaller version of iPhone 6.
How many people have actually bent their phones this way? I read that apple had received only 6 reports/complaints about this, so it really can't be that big of a deal.
According to Apple.
