What would the new limits be for this integral?
  • Thread starter Thread starter Xyius
    Integral Limits
Xyius
I am working on an physics problem and it has boiled down to this integral.
\int_{0}^{∞} r e^{-\frac{1}{2 r_0}(r-i r_0^2 q)^2}dr
I found that if I make the substitution ##u=r-i r_0^2 q##, then I can do the integration, but I am a little confused about what the limits would be in terms of u. Normally I would just replace u with its expression in terms of r, but one of the integrals turns out being a gaussian integral and thus, doesn't have an indefinite form.
I have for the upper limit to be ∞, but the lower limit is ##-i r_0^2 q##. This lower limit obviously will not work for the gaussian integral. Plus it doesn't make sense to me, a negative, complex radial limit?
$$\int_a^b f(x)dx = \int_{u(a)}^{u(b)}g(u)du$$
I see... perhaps the way to make sense of it for you is to separate the integrand into real and imaginary parts before you do the substitution.
You can also consider that u is not a radius.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
