What's the physical meaning of an eigenvalue?
The discussion revolves around the concept of eigenvalues and eigenstates, particularly in the context of quantum mechanics and linear algebra. Participants explore physical analogs and interpretations to enhance understanding of these mathematical concepts.
  • Exploratory, Conceptual clarification, Mixed
  • Participants attempt to clarify the meaning of eigenstates through physical analogs, such as resonance frequencies in violins and the behavior of vectors under transformations. Questions arise regarding the implications of continuous spectra and the nature of eigenvalues in different contexts.
Some participants have provided insights and examples that may help in conceptualizing eigenvalues and eigenstates, while others express gratitude for the contributions. There appears to be ongoing exploration of the topic without a clear consensus on all aspects discussed.
One participant notes a lack of time to fully engage with the provided information, indicating that the discussion may evolve as they revisit the topic. Additionally, references to specific researchers and their work suggest a broader context of study related to the physical interpretation of eigenvalues.
seek
This isn't a homework problem, just something I've been trying to conceptualize for a while. Can anyone exemplify with a physical analog the concept of eigenstates? For example, I know that eigenvalues of variables with continuous spectra do not exist in the physical hilbert space, but I really can't get a working grasp of that concept. This would really help to solidify QM for me if someone can explain this, thanks.
In some situations, you can have continuous spectra, such as the energy bands in crystals.
Eigenvalues are easiest to understand in terms of linear algebra. A square matrix represents a transformation on some vector space; the eigenvectors are the directions in which the matrix acts solely as a scaling transformation, and the eigenvalues are the corresponding scale factors.
I find it easiest to understand that first, and then look at Quantum Mechanics as a generalization of linear algebra to an infinite-dimensional Hilbert space. An operator in Hilbert space is in some sense an infinite-dimensional square matrix, and the eigenstates are infinite-dimensional column vectors.
Another way to think of it physically is in terms of resonance frequency and normal modes. Take a violin, for example. It has a fairly complicated shape. But for some frequencies of vibration, only one mode of oscillation is excited. This mode is an eigenstate; the frequency (or its square) is an eigenvalue.
The modes of vibration of some arbitrary shape can be mapped out by putting a thin layer of sand on the surface, and using a speaker-like device to drive vibrations at a particular frequency. At resonance frequencies, the sand forms a stationary pattern of gaps corresponding to the nodes of the standing wave pattern (or was it antinodes? I forget). The pattern you see is an eigenstate of that shape; the (square of the) frequency is its eigenvalue.
You can consider a 3-D example. Consider a rotation about the z-axis (of some angle that is not a multiple of pi). ez (or alternatively -ez) is an eigenvector of this rotation with eigenvalue = 1. The reason is that the rotation does not change this vector.
If you restrict the vector space to a real field, then a rotation only has one eigenvector, and the eigenvalue is always = 1. However, if you allow a complex field, then there are two more orthogonal eigenvectors. Do you know what they are, and what are their eigenvalues? These other two eigenvectors and eigenvalues are actually important to particle physics.
I just wanted to thank the both of you for your very helpful input. I've been a little busy, so I haven't had the time that I wanted to really go over your information. I'll be sure to do so though. Thank you :)
seek Martin Schleske has done a lot of work on this connected with violins.Much easier to visualise when you see his moving violin plates.Quite frankly it all baffles me.Pretty pictures though.
Martin Schleske
  • · Replies 176 ·
15K
