What's the simple formula for winch/ramp/angle?
  • Thread starter Thread starter prefetch
    Formula
To determine the winch size needed for a 40,000 lb vehicle on a 30-degree ramp, the formula involves calculating the force required using the sine and cosine of the ramp angle, resulting in a need for approximately 37,000 lbs of pulling power. It's important to consider the drag coefficient, which can significantly affect the required winch capacity. Best practices suggest that winch ratings should be at least double the weight of the vehicle for recovery scenarios, especially if the vehicle is stuck in challenging conditions. For a 40,000 lb vehicle, a winch rated for at least 80,000 lbs is recommended. Utilizing snatch blocks can also enhance the pulling capability of the winch.
prefetch
i'm not a physics guy, or a mechanical engineer, but i think this should be a really simple formula - I'm assuming some of you folks will know this off the top of your head:
okay, so I'm trying to figure out how big of a winch to buy for a very large tow truck i am building. winches are rated based on how much they can pull. eg. a 20,000 lb winch can pull 20,000 lbs at a 0 degree incline (flat surface.)
so if i have a vehicle that weighs 40,000 lbs, and a ramp angle of 30 degrees, and a drag coefficient of .5 (if I'm towing a disabled tracked vehicle, I'm guessing a drag coefficient as high as .5 isn't unreasonable) then how big of a winch would i need to pull this up the ramp?
i'm looking for a formula, so i can change the values of my variables: weight of vehicle, drag coefficient of vehicle, winch size, angle of ramp.
is this a basic formula that you folks know?
You would need a winch that can pull more than:
(40,000 lbs.) * sine(30 degrees) + (0.5) * (40,000 lbs.) * cosine (30 degrees) = ~ 37,000 lbs.
You should be careful about assuming your drag coefficient. Perhaps you could measure the force require to pull a vehicle of some known weight up a hill of some known slope?
cool. yeah, that's a good idea on the drag coefficient, i guess that makes a big difference. i think i have some ideas on that.
anyway, thanks a bunch! good on you.
You also have to consider what the "disabled" vehicle might be stuck in or behind. For 4x4's it's best practice to spec a recovery winch at about double the weight of the veihicle, in case it's stuck in mud or large rocks. This helps to keep the duty cycle and strain on the winch down, in addition to giving you an extra safety factor for rare circumstances. So for a 4500lb SUV, you want your winch to be rated at about 9000lbs; for a 40,000lb tank you'll want the winch to be rated for at LEAST 40,000lbs, and I would aim closer to 80K.
Keep in mind though you can use snatch blocks (pulleys) to double or quadruple the pulling capability of whatever winch you decide on.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
