Wheel Turning's Math: Angle & Displacement
  • Thread starter Thread starter PrudensOptimus
    Wheel
The discussion focuses on calculating the displacement of the back wheels of a three-wheel vehicle when turning at a specific angle, such as 20 degrees. The relationship between the angle and displacement is expressed using the formula s = rΘ, where s is the arc length, r is the radius to the pivot point, and Θ is the angle in radians. To determine the displacement, one must first identify the pivot point during the turn and calculate the radius from that point to the back wheels. The conversation also touches on the complexity introduced by having two motors, which operate as a differential mechanism, affecting the wheel velocities. Understanding these principles is essential for accurately setting the motors to achieve the desired turn.
PrudensOptimus
Hello,
Due to my meager mechanical physics knowledge and my meager math talent, I am stuck on this matter: How are the angle of a vehicle turning related to its wheel's displacement. Let me elaborate:
I have a 3 wheel vehicle. It relies on the 2 motors in the back to motivate it. Each of those turning in opposite direction produce a turning effect. However, is there a possible way to find the displacement of the back 2 wheels when given the angle? Say I want to turn the vehicle 20 degrees NE from the spot, how "far" should I set the motors to go?
Any advice would be greatly appreciated. Of course your time is the greatest contribution.
In a perfect world and in a nutshell:
s = r \Theta
where:
s = arc \ length
r = radius
\Theta = angle\ in\ radians
You should first estimate where your pivot point would be during a turn and then the radius would be from that point to either of the back wheels. If you want to go 20° then there is your angle (don't forget to convert it to radians). That will tell you how long of an arc the back wheel must travel to turn 20°. That is making the assumption that both motors are turning you exactly about a single pivot point and that point is stationary. If the point is moving, that will complicate the situation. I'd say start with the easy stuff first.
if there is two motors it is a differrential mechanism. and w=w1*wm1+w2*wm2
w=wheels velocity of angel
w1=velocity when the other motor stops
w2=velocity when the other motor stops
wm1=1st motor's velocity
wm2=2nd motor's velocity
s=w*l*t
Q=S/r
Q=angle (rad)
l=length
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
