When an object becomes very cold do the electrons stop revolving ?
  • Thread starter Thread starter Abidal Sala
    Cold Electrons
Electrons do not revolve around the nucleus in the classical sense; instead, they occupy quantum levels. As temperature decreases, electrons tend to occupy lower energy states, which means they have less kinetic energy. The idea that electrons gain energy to revolve faster when heated is a misconception. At lower temperatures, electrons are more stable and less active. Understanding electron behavior requires a grasp of quantum mechanics rather than classical physics.
Abidal Sala
I thought that electrons revolve around the proton faster when the material is hot, and slower if it's cold, if that's not true then from where do the electrons gain the energy to constantly revolve?
Electrons don't revolve around the nucleus. They exist in quantum levels. When the material is cold they tend to be at the lowest possible levels.
http://en.wikipedia.org/wiki/Electron_configuration
http://www.colorado.edu/physics/2000/quantumzone/bohr2.html
The first reference is a complete description. The second is an excerpt which might help you understand the physics a little better.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
