When to square a sum and when not to
  • Thread starter Thread starter mess1n
    Square Sum
In Compton scattering calculations, when squaring an equation, it's essential to square the sum correctly. The left-hand side (LHS) should be squared as a whole, following the formula (a + b)² = a² + b² + 2ab, rather than squaring individual components separately. This is crucial because a² + b² does not account for the cross-term, which can affect the outcome. The distinction is particularly important in vector components, where perpendicular components can sometimes lead to the same result. Understanding when to apply each method is key to accurate calculations in physics.
mess1n
Hey, I've got a question which might be really simple, I'm not too sure yet!
Basically, I'm going over the compton scattering calculations, and there's a part where:
v - v' + (mec2)/h = \sqrt{something else}
Basically, the next step is to square both sides of the equation.
To do this, my lecturer squares the LHS as a sum (i.e. in the form (a+b)2 instead of doing a2 + b2... where a = (v - v') and b = (mec2)/h).
My question is... why do you in some instances take the square of the sum, and in other instances take the square of the individual components. I'm assuming there is a non-arbitary reason for this.. but I don't know about it!
Any help or pointers in the right direction would be much appreciated.
Cheers,
Andrew
Mathematics news on Phys.org
Welcome to PF!
Hey Andrew! Welcome to PF! :smile:
(have a square-root: √ :wink:)
You always take the square of the sum. :smile:
(Though there are a few cases where that is the same as taking the sum of the squares, for example if they are perpendicular components of vectors :wink:)
Cheers for the welcome, and for the answer!
If you got
x = \sqrt{y}
and you square it to
x^2 = y
If x happens to be a sum
x = a + b
then you get
(a + b)^2 = y
and not
a^2 + b^2 = y
The reason is simple. In general,
a^2 + b^2 \neq (a + b)^2
because there's also the crossterm:
(a + b)^2 = a^2 + b^2 + 2ab
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
