Where can I find Creep Deformation data?
6 replies · 6K views
StewartC
Hello,
I am developing an analytical approach to determine the creep constants of a constitutive model for nickel-base superalloys.
I require creep strain versus time data to valid my approach.
I've searched through literature and have found very little usable data.
I need creep strain versus time data at 3 stress levels for 3 temperatures (9 tests).
Does anyone know where I could obtain this type of data?
Best Regards
Welcome to Physics Forums, StewartC
The manufacturers of the alloys?
You didn't mention specifically what alloys they are.
Any poly-crystalline nickel-base superalloy while do. I'm trying to develop a generalized approach which would work for most Ni-base superalloys (tertiary creep dominant materials).
In particular, I've been looking at Hastelloy X, Inconel 617, and Nimonic 80A? (I have some existing data for these materials but not enough for a full study)
Does this help?
Nice summary here of the alloys mentioned.
http://www.ewp.rpi.edu/hartford/~barthc2/EP/Other/Archive%20PDF%20Files/report11-28.pdf
Code:
              C      Fe     Ni    Cr    Co    Ti    Al    Mo    others
Hasteloy X   0.07   18.0   bal   22.0  12.5    -     -    9.0   0.6W
Inconel 617  0.07    -     bal   19.5   -     0.4   1.0   9.0   -
Nimonic 80A  0.08    -     bal   12.0   -     2.2   1.4    -    -
Hasteloy X is Ni-Cr-Fe-Co, while Inconel 617 is Ni-Cr-Mo and Nimonic 80 is Ni-Cr with 2nd phase particles if Ti and Al (moreso than 617).
There is an ASM reference book entitled, Atlas of Creep and Stress-Rupture Curves, which may have some plotted curves.
http://hts.asminternational.org/portal/site/www/AsmStore/ProductDetails/?vgnextoid=ad13e7c40209e110VgnVCM100000701e010aRCRD
and this might have some data
http://www.nrc.gov/reading-rm/doc-collections/nuregs/contract/cr6824/cr6824.pdf
and possibly in this
www.iaea.org/inisnkm/nkm/aws/htgr/fulltext/iwggcr4_16.pdf
and on can browse this book:
Superalloys: a technical guide
By Matthew J. Donachie, Stephen James Donachie
http://books.google.com/books?id=vjCJ5pI1QpkC
Otherwise, there are several journals on metals, such as Metallurgical Transactions
Meanwhile, I look to see what I have on these particular alloys
Astronuc,
Thank you for finding some relevant information.
The first paper has some background information on the materials.
The ASM atlas of creep I've already checked and didn't find much useful data.
The NRC Paper has a lot of good information.
I will look in the library for the "Superalloys" book.
I'm still search for more strain vs time curves.
Thanks
Superalloys are only partially standard. As compared with the inertia of mechanical activities, they're relatively young, so each supplier has its own names and properties. I suggest to get data from the suppliers.
A model: you want to have some equation and let it fit the experimental curve, with a set of parameters for each alloy, to interpolate the behaviour at intermediate temperature and stress, is that it? Because if someone wanted to predict the behaviour from the chemical composition, for instance, I doubt it can be done.
