Where Can I Find Resources to Get Started in Robotics?
  • Thread starter Thread starter some bloke
    Robotics
A novice in robotics is embarking on a project to create two identical robots, one manually operated and the other mimicking its movements. The project will utilize angle poise lamps as a base, incorporating sensors and motors to detect joint angles for replication. Recommendations for starting include using stepper motors, which do not require position feedback, and sensors like optical encoders for control via platforms such as Raspberry Pi or Arduino. It is suggested to begin with a single joint to master the basics before scaling up. Resources like Maker Faire and Maker-related websites are recommended for inspiration and project ideas. For beginners, advanced kits like Lego Mindstorms EV3 are advised due to their educational value and supportive community, providing a pathway to more complex robotics as skills develop.
some bloke
Hi everyone,
I'm looking to try my hand at robotics, and I am a complete novice at it - I have a reasonable head for coding and can negotiate logic circuits easily, but I have never done anything with robotics.
My first project is to produce 2 robots of identical proportions, where one is manipulated manually and the other replicates it's motions. I plan to use 2 angle poise lamps as a base, then add sensors and motors to identify the angle of each joint and replicate it on the second one. I thought it to be a good, basic entry-level project, with minimal fabrication & cost.
Can anyone recommend some good basics to start with? I understand that raspberry pi is quite a good platform, but I want to know the general feeling of people before I go investing in things.
any free courses anyone knows about will be gratefully received as well.
Cheers!
Well I don't know what type of motor, sensors and control you will decide upon.
Stepper motors are useful for robotics, since they do not "require" position feedback since they can count on their own the absolute or differential position from a starting setpoint.
So you could do a readup on their function and control.
One comprehensive site is,
http://homepage.divms.uiowa.edu/~jones/step/
Likes berkeman
I like @256bits advice. Start with a single joint. Choose an acuator such as a stepper motor. Choose a sensor such as an optical encoder. Learn how to connect them and control them via software with Rasberry Pi or Arduino.
Once you have that mastered, then a robot is just a collection of multiple joints.
One important choice up front is how "strong" must this robot be. Do you want it to just move itself, or to lift heavy objects?
Check out the Maker resources for robot project ideas. If there is a Maker Faire near you, they can be very fun and inspirational to attend. :smile:
https://makerfaire.com/
https://makezine.com/category/technology/robotics/
For a "complete novice" as described, I would recommend starting with an advanced Lego Mindstorms kit such as this one: Lego Mindstorms EV3 31313 Robot Kit. This kit specifically is a good start from an educational perspective due to the large community of builders who use it, and there are numerous step-by-step tutorials that can be followed to build progressively more advanced robots using sensors and motors to complete tasks. You can make some impressively advanced robots with the relatively basic kit, and can experiment with control systems and programming as well.
Once you're comfortable and start to outgrow the MindStorms (which would take quite a while based on my experience with them), you can consider going more advanced with a more enthusiast or engineer solution using microcontrollers and raw components like stepper motors or photodetectors.
Good luck!
Likes FactChecker, berkeman and jrmichler
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
