Where does a quantum experiment *begin*?
244 replies · 19K views
Well, that phrase has at least much less ambiguous connotations than "collapse" :-)).
Shayan.J said:
If wave-function is not physical and only represents our knowledge about the system, then Schrödinger equation describes the evolution of our knowledge. So, to describe the the evolution of our knowledge, we need the Hamiltonian of the system? Really? This...doesn't seem right!
The standard interpretation is agnostic about the reality of the wave function, collapse etc. It does not say that the wave function is not physical. It does not say that the wave function is physical.
vanhees71 said:
Ad (1): The abstract quantum theoretical elements are all "not physical" in the sense that they are a description of phenomena, but that's semantics, because it's true for any mathematical theory, including classical mechanics. A point paricle is not a 6-tupel of real numbers (phase-space coordinates) in Newtonian mechanics either!
How is a point particle not a 6-tuple of real numbers? Are you considering the point particle physical?
vanhees71 said:
Ad (2): Local relativistic QFT, as formulated in any good textbook on the subject is by construction compatible with quantum theory (of course not with Schrödinger-like wave mechanics, which doesn't make sense for relativistically interacting particles), and it defines precisely what's meant by "local interaction": Interactions are described by Lagrangians that are polynomials of the fields and their derivatives; local observables commute for arguments at space-like distances. This implies causality and unitarity of the S-matrix, and thus is a sufficient (not necessarily necessary) condition for a relativistic QT.
Collapse is consistent with all of that.
Demystifier said:
Well, when some concept is often used, I like to use a name for it. Names are also thinking tools (I like my new signature) which simplify thinking.
If, in some future discussion, I mention that "observation induces an update of quantum state", will you understand what I am talking about? Or will you object that this is wrong/misleading?
"Observation induces an update of quantum state" is pretty much what the text by Cohen-Tannoudji, Diu and Laloe says about state reduction, but vanhees71 also rejected that account of collapse.
What means "physical"?
In theory you describe a point particle in a 6-dimensional phase space, i.e., three position and three momentum variables. These variables are real numbers and part of the mathematical description, but that's trivial, isn't it?
How can collapse be consistent with local interactions in the usual sense of relativistic local QFT? The collapse claims that you affect an extended system (like the polarization-entangled biphotons in Aspect-like experiments) instantaneously all over space via a local (!) interaction of part of it. That's obviously self-contradictory!
If "collapse" is just a bad name for update, then it's obvious how can it be consistent with relativistic local QFT.
As Asher Peres briliantly said:
"Quantum phenomena do not occur in a Hilbert space, they occur in a laboratory."
The same idea is expressed by my signature.
I think he does not reject the update. He just refuses to call it collapse, because that expression has misleading connotations.
I couldn't agree more!
But also this has to be taken with a grain of salt. There are only a very few very special experimental situations where you do a von Neumann filter measurement, and only then you can use the postulate that you can update your knowledge on the system to be represented by an eigenvector of the measured quantity to the eigenvalue found in the measurement.
It's also clear that different observers may associate different states to the situation. E.g., if you have the usual polarization-entangled biphoton setup, then before the measurement both A and B associate with the polarization state for B's photon the state ##\hat{\rho}_B=\mathbb{1}/2## (unpolarized photons). Now, if A registers her photon being V-polarized she's associate after the measuremtn ##\hat{\rho}_B^{(A)}=|H \rangle \langle H|## but Bob will still associate ##\hat{\rho}_B##. There's no contradiction here since taking the entire ensemble of biphotons in the measurement for Bob to find his photon being H-polarized is still ##1/2##, no matter what A finds for her photon. I think it's pretty clear that in the minimal interpretation the state, represented by a statistical operator, describes an observers' knowledge about the system, and it cannot be associated in some "ontological" way with the system itself. I think that Bohr had this view, although he expressed himself in such a philosophical way that it is hard to grasp what his view really is. I'm also not sure, what was his take on the collapse hypothesis, i.e., which Copenhagen flavor he followed. At least there seems to be even a difference in Bohr's and Heisenberg's view, and that's what made Einstein&Co. rebel (in my opinion righteoulsy) against "the Copenhagen doctrine", because it's not a sharp scientific definition but a quite fuzzy set of philosophical thoughts.
Is Stern-Gerlach setup one of those?
Yes, it's pretty easy to make it a "von Neumann filter measurement". Supposed you have a setup such that the partial beams of definite ##\sigma_z## are well separated you can just block all partial beams except the one with the ##\sigma_z## you want. Then you have a beam of pure ##\sigma_z## states. For a full quantum treatment of the SG experiment, see
Potel et al, PHYSICAL REVIEW A 71, 052106 (2005)
http://arxiv.org/abs/quant-ph/0409206
So, when does the update happen in a SG setup?
Would you also put Ballentine in that company of Einstein&Co?
Good question. The problem is that Einstein&Co. didn't give a specific interpretation but simply considered QT incomplete based on their classical prejudices. I think Ballentine's book is great in discussing the various aspects of the different interpretations and why the minimal interpretation is the least problematic one (and, in my opinion, the only necessary one too).
vanhees71 said:
It happens as soon as the observer is finding a particle at the position referring to a certain ##\sigma_z##.
I know it seems clear, but its actually not!
You block one of the beams and the other creates a spot on the screen and so you will update the wave-function to the corresponding eigenstate. But what is the system? The whole beam? Only the unblocked beam? If its only the unblocked beam, when did it become a separate system from the other beam? How do you explain that separation?
Also, what if you don't block any of the beams? You get two spots. So what is the updated wave-function now?
In other words, the most general measurements are POVM measurements, while projective measurements are only a small subclass.
But even that should be taken with a grain of salt. By Neumark's theorem, POVM measurement in a Hilbert space ##{\cal H}## can always be represented by a projective measurement in a larger Hilbert space ##{\cal H}' \supset{\cal H}##.
For instance, consider a photon detection. Since it involves a photon destruction, it is not a projective measurement in the space of 1-photon states. Nevertheless it is a projective measurement in the space of all QED states.
In this sense, all measurements are projective at a fundamental level. But for practical laboratory purposes it is more convenient to work with a smaller Hilbert space which describes only those degrees which are of direct experimental interest. That's why, for laboratory purposes, it makes sense to say that most measurements are not projective.
I certainly agree that Ballentine's book is great and that minimal interpretation has many merits.
Nevertheless, would you agree with me that Ballentine's conclusions about quantum Zeno effect (watched pot paradox) are wrong? I mean page 343 where he says:
" ... we have been led to the conclusion that a continuously observed system never changes its state! This conclusion is, of course, false."
I think it's wrong, because for a "continuously observed" quantum system you have to take the entire Hamiltonian including the apparatus into account, and then it can well be that the decay of an unstable quantum state is prevented due to this interaction. It has been confirmed (in full consistency with QT) by various experiments, as one can read in the references of the Wikipedia article
https://en.wikipedia.org/wiki/Quantum_Zeno_effect
What the system is, should be decided by the experimenter. We could use only the unblocked beam or we could use both beams. For subsequent measurements on the unblocked beam, the spatial overlap between the measurement apparatuses and the blocked beam is zero. So if our state is |unblocked> + |blocked>, all probability amplitudes involving |blocked> will be zero. Thus if we redefine the system to include only the unblocked beam, we get the same probabilities as if we continue to use the whole system. In the spirit of this, the "updating of the state" is more a redefinition of the system.
(I am not sure if this reasoning can be extended to Bell tests. It's been a while since I've been thinking about this.)
No, the idea expressed in your signature is that someone who disagrees with you is a fool.
It is not brilliant like Peres' statement and could be offensive to some.
That's why I put a smile at the end. :)
If you like to discuss with physicist you shouldn't be to sensitive. Discussions can get pretty tough, but it's usually not meant personally ;-)).
This also underlines that quantum states refer to ensembles. Whether of not you block partial beams decides about the preparation of the ensemble. If you don't block anything, the ensemble in your example is represented by ##|\psi_1 \rangle=(|\text{blocked} \rangle + |\text{unblocked} \rangle)/\sqrt{2}##, otherwise in ##|\psi_2 \rangle=|\text{unblocked} \rangle##.
Exactly! :smile:
"Physical" is your term. You are the who introduced the term to discuss "collapse" and "point particle". You should explain it to me, not me to you.
Then it is just semantics - but I find it odd that vanhees71, who is supposedly promoting the minimal interpretation always brings up "physicality" and "interpretation" and "interaction" ... when I use the term collapse, in a perfectly standard way, without any meaning of physicality.
It's a bit like Ballentine - the nominal claim to support the minimal interpretation, but not the actual support of it. It is people like me who just want to shut up and calculate who are the true believers in the minimal interpretation, not vanhees71, and not Ballentine.
Also, if you look at his statement about "collapse contradicting foundations of relativistic QFT", you will find that the statement cannot be right whether collapse is physical or not. So it is just plain wrong for any interpretation of collapse.
Edit: Furthermore, see David Lewis's post below - what vanhees71 thinks about collapse is wrong. There is no accepted proof that collapse is the same as the classical Bayesian update (without "nontrivial" additional assumptions). Perhaps there is one, and many have pointed out the similarity, but the analogy to the die is not justified at this stage.
vanhees71 said:
E.g., take a dice (thought of as a classical system) and you just say that the indeterminism of the outcome of throwing it comes from the unknown initial conditions, there will always be a clear and not a somehow "smeared" outcome. Nobody would come to the idea of a "collapse... Where is the difference to QT?
While the die is spinning through the air, each face still has some definite, fixed number of spots (1 through 6) even when nobody is looking at it.
vanhees71 said:
The point of controversy in the "interpretation question" is also not so much the dynamics but rather the interpretation of the states themselves, which in the standard theory is just Born's Law (no collapse necessary), i.e., the usual probabilistic content of the state. There is, however, nothing which makes a collapse postulate necessary. You just state that QT predicts probabilities for measurement given the preparation of the measured system (and preparation can be very crude, e.g., you describe a gas by the usual thermodynamical quantities like temperature, volume of the container, and density of conserved charges), which allows the association of a statistical operator to the system.
From this point of view, if you introduce a collapse into QT, you have to introduce it for the probabilities in classical statistical physics too. E.g., take a dice (thought of as a classical system) and you just say that the indeterminism of the outcome of throughing it comes from the unknown initial conditions, there will always be a clear and not a somehow "smeared" outcome. Nobody would come to the idea of a "collapse", i.e., it just turns up with a specific result, and throughing many times leads to an experimental test of the prediction of any theoretical probability. You can also envoke some theory behind how to postulate such probabilities like information theory a la Shannon and say that as long as you don't know anything about the dice you say each outcome will have a probability of 1/6 (maximum-entropy probability). Then you can do the experiment and confirm or refute the estimate of the probabilities with some confidence level given the experimental outcomes of your measured ensemble.
Where is the difference to QT? The only difference is that, according to the minimal interpretation, the observables that are not determined by the preparation, are "really random", i.e., they have indeed no determined value and not only because we don't know them. Then a lot of philosophical mumbling is done about, how it can be that one has a clear outcome of any proper measurement of such observables. My point is that this is due to the construction of the measurement device, which works with very good precision as a classical system, and classicality can be explained satisfactorily by quantum statistics and coarse graining. It's just the usual quantum theoretical dynamics ("unitary evolution") of this interaction, and this interaction is (according to the best QT we have, which is relativistic local QFT) local and thus there cannot be an instantaneous influence of a measurement at a position A to another far-distant measurement at position B, but that's what's postulated when "envoking" a collapse.
To add to David Lewis's post above, the whole of this quote from vanhees71 is wrong.
In short, I object to attacks on Many-Worlds or Bohmian Mechanics (or other approaches to the measurement problem) based on incorrect Minimal Interpretations.
We should clarify this point, because I think it's wrong what you claim. The collapse in the usual meaning of textbooks claims that the interaction of the measured system with the measurement device (a local interaction according to local relativistic QFT) acts instantaneously over the entire space, which is contradicting itself, because that would mean the interaction is not local. In the mathematical foundations, however it is built in that the interaction is local. So collapse cannot be part of relativistic local QFT.
