Where does a quantum experiment *begin*?
244 replies · 18K views
zonde said:
Can you give reference to example of QED model for polarization entangled photon measurements at different measurement angles?
I asked about this earlier. I'd like to know as well.
rubi said:
You keep repeating your personal theories that aren't in accordance with accepted science. If PF were serious about its rules, you should have been banned by now.
There is "Report" link under every post. Simply push it and write what rule this post violates as you see it. All moderators will see your message and will take action if necessary.
rubi said:
QM is fully compatible with locality. One can embedd the QM probabilities in a local classical probabilistic model (https://arxiv.org/abs/1412.6987), so the compatibility with locality is established at full rigor.
I like this counter example to locality of QM. It does not use any probabilities.
atyy said:
Are the local interactions "physical" or "real"?
They are clearly defined in the mathematical formalism, using the equal-time (anti-)commutation relations, local realizations of the unitary irreps. of the covering group of the Poincare group with ##m^2 \geq 0## and polynomial Lagrangians of the fields and their first derivatives, which leads to a Poincare covariant S-matrix and microcausality.
Take any textbook on quantum optics, e.g., Scully&Zubairy for the foundations. The classical paper on the parametric-downconversion process is
C. K. Hong and L. Mandel, Phys. Rev. A 31, 2409 (1985)
http://dx.doi.org/10.1103/PhysRevA.31.2409
There is of course no counterexample to a proven theorem. Using frequencies instead of probabilities doesn't change that. The existence of a local probabilistic model that predicts the QM probabilities proves beyond doubt that these probabilities are compatible with locality. What's wrong with your counterexample? Frequency proofs of Bell's theorem make the same assumptions, they are just less obvious, because nobody is used to the frequency formulation. The choice of subsequences in the frequency formulation of probability is dual to the choice of a conditional probabilities in the measure formulation.
That seems to be an important paper. Can we call it an interpretation of QM?
Stephen Tashi said:
...is it true that we can have a situation of two "equal probability paths" without having a situation that is modeled by a superposition of states?
Yes. If we send particles through one at a time, and place detectors that tell us which path was taken then there can be no superposition. The presence of the detectors force the particle to either take one path or the other.
rubi said:
You are the one who claims that collapse is compatible with relativity, so you are obliged to prove it. What are your answers to the questions I askes in my previous post? How can collapse be compatible with relativity despite non-commutativity of projections?
Your paper addresses some paradoxes, but it doesn't prove the compatibility. Compatibility with relativity means that full Poincare symmetry is somehow implemented. If this can be done, then you should be able to answer the two questions that I askes in my previous post. Moreover, I'd like to see the mathematical implementation of the Poincare group.
My claim is at the physics level of rigour - in the same way that QED is said to be compatible with relativity. In fact, my claim is found in the standard textbooks.
rubi said:
You keep repeating your personal theories that aren't in accordance with accepted science. If PF were serious about its rules, you should have been banned by now. QM is fully compatible with locality. One can embedd the QM probabilities in a local classical probabilistic model (https://arxiv.org/abs/1412.6987), so the compatibility with locality is established at full rigor.
It's you that it is not accepting standard science.
Sure, but if you use that language, then conjugate position and momentum can also exist simultaneously. In the Heisenberg picture, after a preparation, the time evolution of position and momentum observables are governed by the Hamiltonian, and they remain canonically conjugate.
There's no state where position and momentum are determined simultaneously. If a position operator exists (i.e., for all kinds of massive particles or for massless particles with spin ##\leq 1/2##), then is obeys the Heisenberg algebra with momentum, which implies that for any state the uncertainty relation ##\Delta x \Delta p \geq \hbar/2## holds. Of course, the Heisenberg algebra of the operators in the Heisenberg picture is invariant under time evolution since time evolution is unitary.
The position and momentum observables exist simultaneously.
What do you mean by that. Of course, they exist if they exist (a photon, e.g., has no position observable, but that's another story). What has this to do with the discussion about locality of interactions, etc.?
What I mean is that the locality you are talking about is locality of the Hamiltonian - these concern operators just like position and momentum. So if those "exist" for you, then in the same language position and momentum also simultaneously exist.
So the language you use is not at all the usual language. In the usual language, canonically conjugate position and momentum do not simultaneously exist.
Also in the usual language, quantum mechanics does require nonlocal interactions, assuming reality.
The "locality" that you are talking about should be called "no faster than light signalling".
Relativistic quantum mechanics in the minimal interpretation is about no faster than light signalling. It is not at all about the locality of interactions of mathematical terms representing physical objects, In fact, Bell's theorem guarantees that no such local theory can exist.
Basically, there are two notions of locality - classical relativistic causality (which is where we usually say that interactions are local) and no faster than light signalling, and you are mixing them up.
I think this is totally confusing. What do you mean by "exist" here? Of course, the observables exist, because you can measure them. In standard relativistic QFT the "no faster than light signalling" is realized by using local interactions. Bell's inequality is violated by QT and also by standard relativistic QFT although it's built with local interactions. So something is mathematically wrong in your argument. I only talk about the mathematical construction of the theory. We should this get clear first, before we enter the unsharp terrain of philosophy again!
But what is the interaction between? The fields? If you mean observables exist, then the field do not necessarily exist, since the fields may not be Hermitian - eg. fermion fields.
Fermion fields are usually not representing observables. Observables are defined via Noether's theorem, which provides you with energy, momentum, and angular momentum (densities) and with various conserved current densities of global symmetries. Everything is expressed in terms of the field operators, of course. For the details, see a good textbook on QFT (e.g., Schwartz or for the finer details and more generality Weinberg).
So in your language fermion fields do or do not exist?
@atyy and @vanhees71 you will never come to an agreement because you are talking at two very different levels. While atyy discusses the ontology, vanhees71 talks at the epistemic level. Since it is impossible to make vanhees71 talk about ontology, perhaps you could both agree to talk only about the epistemic aspects? But then you would come to an agreement very soon, and there would be nothing to talk about.
No actually, I prefer to talk at the epistemic level (ie. minimal interpretation). But at the epistemic level, collapse is compatible with relativity.
So I suspect that vanhees71 is objecting to collapse because he is working at the ontological level.
In fact, my standard position is epistemic or operational - it is vanhees71 who brings in ontology by objecting to collapse.
(You can see that this in my post #2, where I use collapse in the standard shut up and calculate way. It is vanhees71 who is somehow objecting to shut up and calculate.)
I think this discussion has drifted off from the question asked in the thread title (the answer to that question is: a physics experiment begins with a grant application :wink:)
I like to think of the collapse hypothesis as having two parts:
  1. When you measure an observable, you get an eigenvalue (with probabilities given by the Born rule).
  2. Afterward, the system is in the state obtained by projecting the state onto the subspace corresponding to that eigenvalue.
(There is a sense in which rule #2 is only relevant for entangled systems. Typical measurements are destructive; when you measure a photon, the photon is gone afterward. So rule #2 comes into play when you have entangled subsystems: measuring a property of one subsystem can cause the other subsystem to "collapse" into a particular state.)
Rule #2 is definitely true, empirically, in the sense that it correctly predicts subsequent measurement results. But it's possible that it isn't necessary as an additional assumption, because you can always recast a sequence of measurements as a single, compound measurement, and so rule #1 would be sufficient. Rule #2 is more of a practical rule of thumb, because without collapse, you can't calculate probabilities for a sequence of measurements without describing the measuring devices quantum mechanically, which is infeasible. Collapse allows us to treat macroscopic measurement devices as if they were classical, having definite states at all times, and reserve QM for the description of microscopic systems (or extremely simple macroscopic systems).
To me, the weirdness of QM comes not from the collapse hypothesis, but from Rule #1. Why are observed values definite, when unobserved values are not? That seems to me to make "measurement" into a different class of interaction, but surely measurement should be explainable as quantum mechanical interactions between the system being measured and the measuring device?
This made my day! It's very true!
As I understood it, vanhees71 says that you can avoid using collapse altogether although it makes things more difficult in certain cases. So having collapse even as a calculational tool is not really "minimal", if you see the minimal interpretation not as the way to shut up and calculate but as the minimal core of quantum theory. And for him this also makes things more elegant with respect to relativity, since changing the inertial frame doesn't force you to change where collapse is supposed to happen.
I don't care whether it's ontic or epistemic, I'm talking about physics, and theory has a mathematical level, which should be clarified first. The words "local interaction" and "long-range correlations" have a very clear and unambiguous meaning, and are well compatible as is proven by relativistic local QFT. A collapse implies non-local interactions and is thus not compatible with the relativistic space-time structure and not with the usual formulation of relativistic QFT which is compatible with this very space-time structure by construction.
If it comes to "ontology" it's very simple for a physicist: Things exist that can be observed reproducibly and objectively in nature.
Yes, you can avoid collapse the same way you can avoid having the Bell inequalities violated at spacelike separation. But if we are talking at the level at which the Bell inequalities are violated at spacelike separation, then that is the same level at which standard quantum mechanics does contain collapse. Mind you, vanhees71 has explicitly said a standard text like Cohen-Tannoudji is not acceptable to him on the issue of collapse. So I am just using standard Cohen-Tannoudji, or Sakurai, or Weinberg, or Nielsen and Chuang which all have collapse. The big issue about interpretation is always brought up by vanhees71 because somehow the standard physics textbooks are not acceptable.
Your mistake is in the phrase "a collapse implies non-local interactions". A collapse does not have any "interactions" in the way you use "local interactions".
Now it becomes totally bizzare. If the collapse is not caused by the interaction between the measured system and the measurement device, by what is it caused then?
The minimal interpretation is agnostic about "cause". "Local interactions" are properties of Hamiltonians. The collapse does not even affect the Hamiltonian, so how can the collapse be related to interactions?
On my part, I don't know what to think. On one hand, the long-range correlations are there because of measurement, and avoiding collapse doesn't practically account for compound measurements (you have to believe it would work if you could do the practically impossible calculation of treating the whole measurement device quantum mechanically). On the other hand, collapse is frame-dependent, although the consequences are the same whatever frame you choose in the end, so it seems to beg for a deeper explanation.
I wouldn't say it's important, since it just makes precise what was already consensus (QM is compatible with locality). However, I like it a lot, since it forces locality deniers to point out an error in the proof, which of course doesn't exist. I also wouldn't call it an interpretation. All interpretations of QM must predict the same probabilities and that papers just shows that they can arise from a classical probabilistic model that happens to be local.
I'm not asking for a mathematically rigorous presentation. Also a physicist understands compatibility with relativity to mean the implementation of the Poincare group, possibly at a non-rigorous level (as in QCD). I would already be satisfied if you could show me a non-rigorous implementation of the Poincare group that includes collapse. Show me one textbook that explicitly claims that collapse is compatible with relativity.
You are just telling me that I'm wrong, but you don't counter my arguments. Why don't you respond to the questions I posed earlier?
(By the way, I'm not even denying compatibility. I'm just saying that there is no evidence for it, but rather arguments against it.)
The overwhelming majority of physicists interprets Bell's result in favour of locality and in disfavour of hidden variables. Only a die-hard minority of Bohmians advocates non-locality. Both groups agree that Bell can be interpreted in both ways. Moreover, the paper that I quoted proves unambiguously that QM is at least compatible with locality. So my view is in accordance with standard science.
Rubi, why do you say "classical probabilistic model that happens to be local", when the abstract of the paper says "violation of Bell's inequality implies the impossibility to apply the classical probability model of Kolmogorov (1933) to quantum phenomena"?
