Where is Point B on a Sinusoidal Wave?
The discussion revolves around determining the coordinates of point B on a sinusoidal wave, specifically where it is 60.0° out of phase with point A at the origin. The wave is described by the equation y = (15.0 cm) cos(0.157x - 50.3t). The calculation shows that the x-coordinate for point B is approximately 1.05 m, and the corresponding y-coordinate is about 0.148 m. The final coordinates for point B are (1.05, 0.148) m. The user expresses initial confusion about the question but ultimately finds the correct answer.
magisbladius
For a sinusoidal wave:
At a certain instant, let point A be at the origin and point B be the first point along the x-axis where the wave is 60.0° out of phase with point A. What is the coordinate of point B?
x(at point B) = theta + 0 = 60.0° = pi/3 rad = ~1.05 m.
y(at point B) = (0.150 m) cos(0.157[1.047 m] - 50.3[0]) = 0.148 m
(x, y) = (1.05, 0.148) m
I don't understand what the question is asking for. I am handing this in, online, and it checks the answers (I have 3 tries left).
I found the answer.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
