Where Will Earth's Magnetic Field Cancel a Wire's B-Field?
The discussion revolves around understanding the interaction between Earth's magnetic field and the magnetic field produced by a vertical current-carrying wire. Participants are exploring how to determine the net magnetic field and the conditions under which these fields may cancel each other out.
  • Participants discuss the orientation of the magnetic fields involved, questioning the initial assumptions about their directions. There is an exploration of how to calculate the net magnetic field strength and the implications of equating different magnetic field components.
The conversation is ongoing, with participants providing insights into the relationships between the magnetic fields. Some guidance has been offered regarding the approach to equate the magnetic fields, and there is acknowledgment of the need to clarify the direction of the fields involved.
There is mention of uncertainty regarding the distance variable in the problem, as well as the implications of different methods for calculating the net magnetic field. Participants are navigating through these constraints without reaching a definitive conclusion.
Bolter
Calculate the distance the neutral point is from the wire
Magnetic field strength due to current currying wire = u0 * I/(2*pi*d)
Hey everyone
So this is question shown below
I'm not so sure where to begin with this, but I thought I'd work out the net magnetic field first
How would I work out the magnetic field strength that is acting on the vertical current-carrying wire. Since I do not know what d is in this case?
Any help would be really appreciated! Thanks
Since the wire is vertical, the magnetic field produced by the wire should not be vertical, but horizontal. The vector you draw for Bv is vertical, I think that's why you're stuck.
Ok so that means to find the net magnetic field strength. I know that both the magnetic field produced by the current carry wire and horizontal magnetic field are both horizontal and facing the same direction
This gives me the net magnetic field as this
I'm still not entire sure what to do with this net magnetic field expression to find the distance from neutral point?
EDIT: nevermind I think I have answered it now. I had equate B–wire = B–horizontal not sum them up together
Summing them is fine if you then equate the sum to zero. You get the same equation.
BTW did you work out the direction before Chester told you?
Sorry for the late reply. Yeah I figured but then I had seen the post after correcting me.
I get 0.027m as my answer
Looks right to me.
