Whether charges can stay inside wires or on the surface of a conductor
In an ideal circuit with no resistance, excess charge from an isolated capacitor will redistribute on the surfaces of conductors to ensure that the electric field inside the conductors remains zero. The charges cannot stay within the wires themselves; they must reside on the surfaces. This redistribution occurs because the ideal wires are considered to have no internal electric field. Consequently, the electric field must be zero everywhere within the conductors. Therefore, excess charge will always move to the surfaces of conductors in such a scenario.
feynman1
There's an isolated capacitor initially carrying nonzero net charge. Then place the capacitor in a circuit connected with ideal wires (no resistance). Where will the excess charge go? Can they stay in wires or on any surfaces of conductors in the circuit? Electric field needs to be 0 everywhere in ideal wires.
Excess charge distribute on surfaces so that electric field inside conductor is zero.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
