Which student is correct when bulb C is removed?
  • Thread starter Thread starter EV33
    Bulb
When bulb C is removed from a circuit containing three identical bulbs with resistance R, bulb B becomes brighter. Student one correctly identifies that bulb B receives all the current previously shared with bulb C, resulting in increased brightness. Student two's assertion that the overall resistance increases and thus reduces current is incorrect. The analysis shows that the equivalent resistance changes from 3/R to 2R, leading to an increase in current through bulb B, making it 1.5 times brighter than before.
  • Understanding of electrical circuits and components
  • Knowledge of Ohm's Law (V=IR)
  • Familiarity with series and parallel resistor configurations
  • Ability to calculate equivalent resistance in circuits
  • Study the principles of series and parallel circuits in detail
  • Learn how to calculate equivalent resistance for complex circuits
  • Explore the impact of removing components on circuit behavior
  • Investigate the relationship between current, voltage, and resistance in various configurations
Electrical engineering students, educators teaching circuit theory, and hobbyists interested in understanding circuit behavior and component interactions.
EV33
Which bulb is brighter :)
b]1. Homework Statement [/b]
There is a circuit with a voltage V, and 3 identical bulbs of resistance R. B and C are parallel to each other, and A is in series to them.
what happens when bulb c is removed?
student one: I think that bulb B will get brighter. Bulb B used to share the current with bulb C, but now it gets all the current. So bulb B will get brighter.
student 2: I don't think so. Now there aren't as many paths for the current, so the resistance in the circuit has increased. Since the resistance in the circuit has gone up, the current in the circuit decreases. Bulb B will get dimmer.
Which student is correct?
1. Sum of all current into a node is the sum of the current out of the node.
2. The sum of voltage on a closed loop is equal to zero.
3. V=IR
Well I agree with student one in the part where bulb B doesn't have to share the current with bulb C anymore so the amount of current going to B is increased, but student 2 makes a great point too. He says that because bulb C is gone that the amount of resistance in the circuit is increased.
So from here I made the resistors into equivalent resistors in order to find the current that would be going through B in both cases.
The first case I get the equivalent resistor to have an Resistance=(2/R)^(-1)+R=3/R
So using V=IR, I get the equivalent I to be equal to 2V/(3R).
so that would mean that to current going to B individually would be half... V/(3R).
The second case without C I Get an equivalent resistance to be R+R=2R, and so the I=V/(2R).
Therefore when C is removed, the current also goes up for B making B brighter, and makeing student 2 wrong.
Is this correct reasoning? I am a still a little uncomfortable with circuits.
Your analysis is OK.
Bulb B should be 1.5 times brighter and bulb B's brightness will be reduced to 75% of previous value.
Thank you very much
