Which compound is more acidic? (without using pkA value) HCl or H2SO4
  • Thread starter Thread starter Kaede_N9
    Hcl Value
H2SO4 is generally considered more acidic than HCl due to its lower pKa value, indicating stronger acid strength. The discussion explores the role of electronegativity and inductive effects in determining acidity, noting that sulfur's electronegativity may influence H2SO4's acidity. The presence of three oxygen atoms in H2SO4 contributes to resonance stabilization of its conjugate base, enhancing its acidity compared to HCl. There is some confusion regarding the definition of acidity, with interpretations varying between acid strength and neutralization ability. Ultimately, while the discussion attempts to avoid pKa values, it acknowledges their relevance in comparing the two acids.
Kaede_N9
HCl or H2SO4
Electronegativity.
Inductive effect.
Since sulfur is more electronegative compared to cholrine, H2SO4 is more acidic than HCl...
So then I think of how I could use inductive effect instead of electronegativity to verify this claim.
Since sulfur is more electronegative compared to oxygen it shall pull away electrons slightly, more than chlorine on hydrogen?
I don't think it'll work since there are a 3 oxygens around sulfur and so the combined electronegativity outweighs that of sulfur?
What do you think?
I think I have no idea what it means to be "more acidic". And I am deadly serious, I am not aware of any definition of acidity. The way I see it it can mean one of two things - acid strength (in which case HCl is "more acidic"), or ability to neutralize base (similarly to alkalinity) - in which case H2SO4 as diprotic is more acidic.
Poorly worded question.
Original question:
For the following pairs of compounds, predict which one will be the strongest acid
and justify your choice.
Answer:
Between HCl and H2SO4, H2SO4 has a lower pKa (~-9) than HCl (~7) and so it is a stronger acid compared to HCl.
I wanted to answer this question without using a pKa table so I tried comparing the electronegativity of the central atoms, and as wel as their inductive effects. Not sure if inductive effect would work though.
Also consider that resonance stabilization of the conjugate base occurs in H2SO4.
Apparently it depends on the source used. Kotrly & Sucha (Handbook of Chemical Equilibria in Analytical Chemistry) list sulfuric acid pKa1 as -3, Hulanicki (Reactions of acids and bases in analytical chemistry) lists pKa of HCl as -4.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
