Which is better for concentrating sunlight ?
  • Context: Undergrad
  • Thread starter Thread starter anjanamurthy
    Sunlight
The discussion revolves around the efficiency of different configurations of parabolic reflectors for concentrating sunlight, specifically comparing central axis (Cassegrain) and off-axis designs. The context includes considerations for solar illumination projects that require sun tracking.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions which configuration is better for efficiency between central axis (Cassegrain) and off-axis reflectors.
  • Another participant suggests that for a simple solar reflector, efficiency largely depends on the effective area, noting that off-axis reflectors may have a slightly reduced area due to the projection shape, while Cassegrain systems may waste central area for a secondary reflector.
  • Several participants emphasize the importance of tracking accuracy and feasibility in determining which reflector type is better for direct solar illumination projects.
  • There are inquiries about the size of the object for sunlight concentration and the power requirements, indicating that these factors influence the choice of reflector configuration.
Participants express differing views on the efficiency and practicality of the two reflector types, with no consensus reached regarding which is definitively better for the specified application.
Participants have not fully defined the assumptions regarding tracking accuracy, power requirements, or the specific application context, which may affect the discussion outcomes.
anjanamurthy
which is better for concentrating sunlight ??
I m doing a project on solar illumination . I wanted to know which configuration of parabolic reflector/ collector is better in terms of efficiency - central axis (cassegrain) or off axis ??
Science news on Phys.org
For a simple solar reflector where no high quality image is required, it's largely down to the effective area of the reflector. This may be reduced for an off axis reflector by a small amount due to the projection turning a circle into an ellipse, with a slightly smaller area - but the Cassegrain system 'wastes' all that central area for the secondary reflector.
Well this is for a direct solar illumination project which requires tracking of sun. So if we consider that also .. which of the two would be better ??
In terms of tracking accuracy required and feasibility to track ...
What are your thoughts on reasons why one might be better over the other?
How well does need it to track? What size object do you want to concentrate the sunlight on? How much power do you want? (a few Watts or several kW?)
So far it's 'how long is a piece of string?'
  • · Replies 40 ·
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 21 ·
