Which of these have higher output per square unit*, phototransistors,
Phototransistors, photodiodes, and APD photodiodes each have distinct characteristics affecting their output per square unit. Phototransistors are sensitive but suffer from slow response times, manufacturing inconsistencies, and poor linearity. Photodiodes, particularly PIN types, offer a good balance of consistency and dynamic range, with performance heavily reliant on amplifier design. APD photodiodes can provide high photo-current per unit area when powered externally, although their gain may be lower than that of phototransistors. Ultimately, the choice depends on specific application requirements, including desired gain and efficiency.
m718
Which of these have higher output per square unit*, phototransistors, photodiodes or APD photodiodes.?
Each has it's unique properties.
Photo transistors are great for sensitivity, but everything else about them is bad. They're terribly slow, inconsistent during manufacture, and generally have poor linearity.
Photo diodes, especially the pin, are my favorite all around. They're fairly consistent, have a huge dynamic range, and if you're amplifier design is good, you can get great signal recovery. The trick is the amplifier. One amp is not good for all designs. Some amps give great bandwidth, but have poor noise characteristics. Some are of course the opposite. And then you have all the other considerations, like saturation and offset and such.
I can't tell you that much about avalanche diodes, because the only use I've ever had with them is for edge detection - and that design was prepackaged. I know that they're a triggered device, so don't expect to follow a linear signal with them. They also seem to be associated with high speed work, which is how I came across them.
Best luck,
Mike
It depends on what you mean by output: A straight photo-diode is what you would want for (photovoltaic) power generation. It can have very good quantum efficiency and packing factor but of course it provides no gain.
If an external power source is available, a photo-transistor can give you gain, possibly several hundred times, but its quantum efficiency may not be so good, and its packing factor generally won't be as good either, as the photosensitive area may form a relatively small part of the total device area.
Again provided a suitable external bias voltage, the APD might give the greatest photo-current per unit area. Depending on the technology used, the optimum gain may be quite a lot less than for the transistor, but the quantum efficiency and space occupation may be better.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
