B Which one is correct? (the Matrix or Wave formulation of QM)
  • B
  • Thread starter Thread starter zoltrix
    Matrix Qm Wave
zoltrix
hello
matrix and wave formulation of QM are equivalent theories i.e they yield the same results
Which one is most frequentely used by professional scientists in solving real problems and why ?
For example, some systems can be considered perturbations of the harmonic oscillator, so it is computationally efficient to work in the discrete harmonic oscillator basis.
Roughly, the matrix version is the formulation in terms of energy eigenvectors and eigenstates. The two formulations are identical, so in practice one goes seamlessly between the two fomulations. One doesn't think of them as separate formulations nowadays, as thinking of them as separate formulations is more confusing and historical than helpful. They are the same formulation.
That's why Dirac's formulation after all is the most clear formulation, because it is formulating QT in a "representation free" way. Then whether you do "wave mechanics" or "matrix mechanics" is simply the same theory using different bases to solve some problem, and which one is more convenient depends on the problem you want to solve.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
11K
