Which reacted faster, foot or hand?
  • Thread starter Thread starter lostsummer
    hand
The discussion centers on the reaction times of the foot and hand, with an initial belief that the hand reacts faster due to its proximity to the brain. Participants seek clarification on how Newton's laws can explain this difference in reaction time. There is also a question regarding measurement accuracy, noting that the foot's distance to the ball was measured in centimeters while the ruler's measurement was in millimeters, suggesting visibility issues during measurement. Lastly, the conversation touches on the classification of both rockets and rulers as projectiles, despite their differing trajectories, indicating a need for more context to fully understand the underlying physics. Overall, the thread emphasizes the importance of clear problem statements in discussing physics concepts.
lostsummer
Hi ! I have many questions and I did try to answers them, but I want to know if I am incorrect.
1) Which reacted faster, foot or hand ? try to use Newton explanation
I think the hand will react faster because it is closer to the brain... to send signal, but I am not sure how to explain that with Newton laws ( 1st and 2nd )
2) Why was the distance betweeen the top of the foot and the ball only measured to the nearest centimeter, while the place that caught the ruler was measure to nearest millimeter?
My guess is that with the ruler I could see the measurement and when the ball drop on the foot, the measurement is off by some millimeter.
3) Explain why the rocket and the ruler are both projectiles, despite their different paths.
this question I HAVE No idea.
Hi lostsummer, welcome to PF. It would help us help you if you posted the statement of the problem with the underlying physical situation, instead of just the questions related to it. We are not mind readers, you know.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
