Which Type of Semiconductor Has Higher Resistance: N-Type or P-Type?
N-type semiconductors have higher resistance due to the presence of bound electrons from doping, which can impede electron flow. In contrast, P-type semiconductors create holes that facilitate electron movement, making them generally more conductive. Both types of doping significantly reduce the resistivity of silicon compared to its intrinsic state. The conductivity of semiconductors is directly proportional to the number of free charge carriers, whether they are electrons or holes. Ultimately, doping increases conductivity and decreases resistance for both N-type and P-type semiconductors.
Windex
In terms of the semiconductor Silicon:
N types have on more free electron added to its structure from doping an impurity on it. Such as an arsenic impurity onto a pure intrinsic silicon crystalline structure.
However wouldn't it having one more electron inside of it that is bound to the arsenic atom make the ntype more resistant to electron flow from a power source with an emf/voltage/potential difference?
I also wonder about the vice versa for the P-type.
Wouldn't the P-Type be more conductive unlike the N-Type which i am assuming to be resistive?
Mainly because when doping something onto a silicon structure to make it a N-Type a hole is created. Thus allowing electrons to want to take that hole for transportational use.
Windex,
Adding impurities to metals (which already have loads of conduction electrons) increases their resistivity a little. The impurities just get in the way.
But the thing about silicon is that without the impurities, there are hardly any conduction electrons, at least at room temp and below. So adding even tiny amounts of a dopant impurity (either an n-type or p-type) reduces the resistivity by orders of magnitude.
When you dope silicon with penta-valent atoms, (i.e. n-type semicondoctor) then there will be an excess of electrons. When connect it to a power source, which can be viewed as an electron drain if you're looking from the positive charge, then this will tend to suck the free electrons from the semiconductor, and of course, the negative end which can be viewed as an electron sourse, will supply the semiconductor with the electrons needed for continuous 'sucking'.
For p-type, tetra-valent doping will creat a hole, which can be simply viewed as a positive charge. So when you connect it to a power supply, then electrons supplied from the negative end, will fall in the hole, and the pushed to the other end by the stream of electrons to be re-collected at the positive end of the source.
Hope i was clear :rolleyes:
ehh.
I was more going on the point that there is an open hole instead of an electron floating around in the p-type. Since ther is a whole, electrons would more likely be able to conduct better. However in the n-type, there is a bound electron put there by the impurity. Thus electrons that are being brought from a power source have to fight that electron. :approve:
Or else I'm being stupid.
I thought electrons liked to use other electrons holes as a pathway to getting somewhere faster.
Kinda like in sonic the hedgehog where you go through a speed door and you get a super speed boost to get done with the level faster. You could use the n-type which is not take the speedwarp door and fight through the badguys which is the bound electron put there by the impurity, or else you could take the p-type which would have less resistance and a speed door that gives you a boost and less badguys to fight. :-p
eh.
So basically. There is resistance added because of the impurity. But my question was. Which would be more resistant: N-type or P-type?
eh.
Having more electrons in the conduction band (which is what adding an N-type impurity does) or more holes in the valence band (from P-type dopants) only increases the conductivity. Your understanding of electron transport is a little off. The model that explains semiconductors well assumes that there is virtually no interaction between the electrons themselves, and it turns out that this is a good assumption to make. As a result, the conductivity is linearly proportional to the number of free charge carriers (per unit volume).
So in fact doping increases conductivity and reduces resistance, irrespective of whether it's N- or P-type.
Moral : Electron transport does not work like Sonic.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
