Why Are Refrigerators More Complex Than Stoves?
42 replies · 8K views
TreyBien
Why is it so much easier to increase the temperature of something than it is to decrease the temperature?
Why are refrigerators more complex than stoves?
What are your thoughts on this?
Chestermiller said:
Does heat flow spontaneously from hot to cold, or from cold to hot?
Hot to cold.
The universe was hot, then cooled. Right? So going from hot to cold would seem more natural than going from cold to hot. Obviously, I'm missing something..
Perhaps start with what you mean by "harder"?
The specific heat capacity of water is the same if you are heating or cooling it :-)
The rate of heat transfer is proportional to the temperature difference. Even using liquid N2, the temperature difference can't be more than around 200 degrees. The temperature of a flame or red hot electrical element can be many hundreds of degrees in the other direction. And how easy is it to produce liquid Nitrogen? compared with turning on a heater?
A refrigerator needs to produce a cold sink by pumping heat away in a thermodynamic cycle; in the case of the domestic refrigerator, the temperature of that sink can't be much more than -30°C.
BUT - go out into deep space and it is 'easy' to cool things down!
TreyBien said:
Hot to cold.
What is your personal experience with heat spontaneously flowing from hot to cold vs cold to hot?
There is some faulty logic and definition here in this question.
I don't know what it means to be "easier". I find a stove to be more complicated than, say, a bucket of ice. I can easily cool something down by simply dipping it in ice. Isn't this easier than using a stove? Your comparison is vague, because one can easily use another "equipment" either to heat something or to cool something. Relying on such an external device makes the question and the premise ambiguous.
Now, one can ask why it takes less time to heat a fixed amount of a substance to some final temperature, versus the amount of time to get that substance from that final temperature back down. That has a bit more clarity to the question since you are using the time taken as a measure of something being "easier".
But without such explanation, there is no clear way to answer such a vague question.
Zz.
If I make a cup of tea and forget to drink it, when I come back later it has cooled to room temperature.
If I have a glass of ice and leave it on the counter, when I come back later it has melted.
It takes longer for the same amount of water to melt (cold to hot) than for the tea to cool (hot to cold).
I can boil water on the stove in minutes. It takes 1-2 hours to freeze the same amount of water in my refrigerator's freezer compartments.
My freezer's components and technology are more complicated (and more expensive) than my stove.
My curiosity relates to trying to understand entropy. Is hot to cold going from low to high entropy and cold to hot the opposite?
Does it require more energy to freeze 8oz of water than to heat it to boiling? I know that in the kitchen my more complicated and expensive refrigerator (freezer compartment) takes longer to freeze water than my stove requires to boil it.
There are several parameters at work here:
- The specific heat of water: This is the amount of heat that needs to be added to a given mass of liquid water to increase its temperature by one degree, or equivalently the amount of heat that must flow out of that mass to lower its temperature by one degree.
- The latent heat of fusion of water. This is the amount of heat that must be removed from a given mass of water at 0 degrees Celsius for it to turn into ice at the same temperature.
Google will find these values, and along with the initial temperature of the water they are sufficient to answer your question about freezing versus heating to boiling.
As for how long it takes to heat to boiling or freeze solid? That will depend on the rate at which heat moves into or out of the water and that in turn is dependent on the temperature difference between the water and the stove flame or the cold air in the freezer. This is the point that @sophiecentaur was making in post #6 above.
Also there is a big difference that hasn't been mentioned yet. A stove generates heat but a fridge transfers heat.
Ahh. So you are not someone who is unfamiliar with thermodynamics. What you are asking is "what is it about heat flow from cold to hot that is mechanistically so much different from heat flow from cold to hot?"
Not so - in both cases you have a mass of water at a given temperature in contact with a volume of gas at a different temperature. The source of the temperature difference is irrelevant to its effect on the water.
Again, you are confusing the efficiency of heating and cooling with the notion that doing one thing is easier than the other.
I can freeze a cup of water FASTER by dropping it into a vat of liquid nitrogen than to boil it by heating it with a candle. Any arguments here?
So using your logic, cooling water is easier than heating it.
Zz.
This thread isn't really about heat flow. At least the OP isn't.
It is much easier to generate heat than to transfer it. That IMHO explains why a stove is simpler than a fridge.
Of course there are other issues at play, as being discussed by others.
But indicating that a stove is simpler than a fridge has no relevance in whether heating is simpler than cooling. The OP simply picked two arbitrary examples. This is not an apples-to-apples comparison.
What is a closer comparison is this: put 1 cup of water in a metal beaker.
1. Place the metal beaker on a stove and heat it.
2. Place the metal beaker in a liquid nitrogen bath and cool it.
Those two are closer apples-to-apples comparison.
Zz.
It seems to me that there are two issues here:
1. When we put something hot in contact with something cold, why is the final temperature part way between the hot and cold?
2. When we put something hot in contact with something cold, why do we say that heat flowed from the hot thing to the cold thing, rather than cold flowing from the cold thing to the hot thing?
Trey: which, of these is closer to what you are asking?
The second. And, is the premise of my question erroneous? Is it or isn't it easier ( I.e., requires less energy) to increase temperature of something rather than lower it?
Well, I can quote the three laws but I clearly don't grasp them or I'd be able to answer my own question.
I'm no scientist, this much is clear or I'd be able to answer my own question. It is the second law I'm trying to better grasp. If entropy always increases and the universe is going from hot to cold, then it seems that going from hot to cold is "natural" ( my word) and cold to hot is both "unnatural " and in opposition to the second law.
So, yes, what is it chemically and physically about heat flow form hot to cold that is so much different than from cold to hot?
And, is the premise of my question wrong? (Why is it so much easier to increase the temperature of something vs. decreasing it?)
No. In terms of the energy transferred into the "thing", raising and lowering the temperature the same amount requires exactly the same amount of energy.
And as far as the input energy for the device goes, it is entirely dependent on the heating/cooling mechanism. For example, a gas stove might be 70% efficient, but a refrigerator has a coefficient of performance (similar to efficiency) of 300%! So by that measure, it is much, much easier to cool than heat.
In practice you heat up things by converting some other energy form (which is easier to transport and has high energy density) into heat, were you need it. The reverse process requires doing work, because heat doesn't spontaneously concentrate and convert itself into useful stored energy.
https://en.wikipedia.org/wiki/Laws_of_thermodynamics
The OP seems to have ignored many of the points that I've made in this thread, so this will be my last intrusion into this thread.
The problem here in the very beginning is (i) the faulty starting point, i.e. the OP made arbitrary comparison between the process of heating and cooling, and (ii) the conclusion derived from that faulty starting point.
This can be a lesson to many people, especially non-scientists, in how we devise a valid experiment to test a hypothesis. This is especially true when we want to make a comparison between two different processes, in this case, heating and cooling. Is it a fair comparison to heat something on a burner, and then compare that to cooling it in a refrigerator? I've posted on why it is not.
IF the whole issue here is to see how "easy" or "difficult" it is to heat or cool something, then the process of cooling and heating must be as close to be identical as possible. Otherwise, other factors will come in that has nothing to do with the physics of heating and cooling that substance. In other words, we want the heating and cooling of the object to be INDEPENDENT of the process that we use, so that we can get to the actual physics and detect if there are differences in the two processes that are NOT due to how we heat and cool it.
So, similar to what I've suggested before, here's what we can do:
1. Get a 1 kg mass of water in a metal vessel.
2. Let it come to thermal equilibrium at room temperature, say 20 C.
3. Immerse it in a heat bath that is at 30 C.
4. Record the time it takes for the water to get to 30 C.
5. Repeat the experiment, but this time, immerse it in a cold bath that is at 10 C.
6. Record time it takes for the water to come to 10 C.
7. Compare the time. If they are the same, then the process of heating and cooling is identical. If they are not, then you have something.
I pick the same temperature difference to heat and cool to make sure that the rate of heat loss or heat absorption due to surrounding temperature will be similar, i.e. one must make sure that external factors do not significantly affect the result.
If there is a noticeable difference in the time taken for cooling and heating, then this thread is valid. If not, then this thread is moot, because we will be trying to discuss why the unicorn has pink horn.
With that, I'm done!
Zz.
Wondering if you wouldn't entertain one more question on this concerning your experiment? In part 1, in the energy state of the water molecules at 20 C they are moving at some speed V20 and if you increase their temperature their kinetic energy goes up and their velocity changes to V30. In part 2, we start at V20 and end up with slower molecules moving V10. My question is and just to illustrate, suppose V30=30 and V20=20 then the change in kinetic energy during the part 1 is 900-400 = 500. In part 2, given the same ΔT, the kinetic energies changes from V20 to V10. Suppose V10 = 10 then the change in KE is 400-100 = 300. so, given the same ΔT we arrive at 2 different KE's. On one hand, ΔT gives a change of 500, on the other hand, the same ΔT gives a change of 300. Is the difference in these changes from V20 somehow related to the magnitude of the inter-molecular forces at these temperatures? If not, would you please clarify? Would these difference in velocities have some impact on the rate heating or cooling? (Also note, I have no idea what actual velocities are. I just picked some numbers to illustrate the question). Appreciate your time in advance. (EDIT: I guess I asked more than 1 question)
[snip a bunch of hypotheticals about molecular kinetic energy and intermolecular forces]
You are trying to explain the results of an experiment that you have not run using hypotheses that you have pulled from thin air and mechanisms that you do not understand.
You are certainly correct, hence my questions. Thank you for your reply.
What question?
Thank you for taking to time to respond to my inquiries.
As far as my knowledge on thermodynamics in nature;
Heat flows from hotter region to colder region.
Heat flow from colder region to hotter region request work done on system.
Consider reversibility. A heat engine produce work while heat flows from hotter region to colder region (naturally) if you want to reverse this flow direction;
you have to reverse the work. Instead of taken work from system you have to apply work to system.
In heating you just interact a hotter region with cooler region. you haven't do nothing else. But cooling you have to perform work on system
Therefore, "it is so much easier to increase the temperature of something than it is to decrease the temperature"
This makes no sense.
If I have a hot object and a cool object and I put them in contact, the hot one cools and the cool one warms. How can one say that one is easier than the other?
